How to set CAN-FD from classical CAN usage?
ソリューションへジャンプ
9,701件の閲覧回数
f-nelson
Hi NXP:
we have used classic CAN bus(2.0/fix 8byte data)in s32k312 platform, now we would like to upgrade
CAN-FD format. I set CAN-FD parameters(classical CAN 500Kbit/CAN-FD 2Mbit) and connect to PCAN device, but
I don't know how to modify project as CAN-FD loopback, please help us, thanks.
attachement file:
test_CAN.7z
9,622件の閲覧回数
Senlent
Hi@f-nelson
The project you provided was modified and the RTD version used is RTD 5.0.0.
5 返答(返信)
9,629件の閲覧回数
f-nelson
Hi NXP:
It is mistake about example. in my project, we have been using clock source of AIPS_PLAT_CLK
which is normal speed(30Mhz) and works. becuase I'd like to give you a example, so I didn't change
this clock setting. please modify this example code based on 20250210-test_can.7z for modify CAN to CAN-FD
(64byte and BRS enable), thanks.
9,623件の閲覧回数
Senlent
Hi@f-nelson
9,556件の閲覧回数
f-nelson
it's good example for CAN-FD, many thanks.
9,557件の閲覧回数
f-nelson
Hi Senlent:
9,689件の閲覧回数
Senlent
Hi@f-nelson
In your project, the flexcan module clock is set to 24MHz instead of 30MHz.
Please check the picture, I made some new modifications according to the 24MHz FlexCAN
clock for your reference.
%3CLINGO-SUB%20id%3D%22lingo-sub-2039816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%BE%93%E6%9D%A5%E3%81%AECAN%E4%BD%BF%E7%94%A8%E3%81%8B%E3%82%89CAN-FD%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFNXP%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3CBR%20%2F%3E%E5%BE%93%E6%9D%A5%E3%81%AECAN%E3%83%90%E3%82%B9(2.0%20%2F%20fix)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F8%E3%83%90%E3%82%A4%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF)S32K312%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%80%81%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3ECAN-FD%E5%BD%A2%E5%BC%8F%E3%80%82CAN-FD%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF(%E5%BE%93%E6%9D%A5%E3%81%AECAN%20500Kbit%2FCAN-FD%202Mbit)%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81PCAN%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92CAN-FD%E3%83%AB%E3%83%BC%E3%83%97%E3%83%90%E3%83%83%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%3CBR%20%2F%3EPCAN_setting-connecting.png%3CBR%20%2F%3Es32k312_can-fd_setting.png%3CBR%20%2F%3Etest_CAN.7z%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2041251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E5%BE%93%E6%9D%A5%E3%81%AECAN%E4%BD%BF%E7%94%A8%E6%B3%95%E3%81%8B%E3%82%89CAN-FD%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2041251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%8C%E3%81%AFCAN-FD%E3%81%AE%E8%89%AF%E3%81%84%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%81%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2041250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E5%BE%93%E6%9D%A5%E3%81%AECAN%E4%BD%BF%E7%94%A8%E6%B3%95%E3%81%8B%E3%82%89CAN-FD%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2041250%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%BB%E3%83%B3%E3%83%AC%E3%83%B3%E3%83%88%3A%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AFCAN-FD%E3%81%AE%E8%89%AF%E3%81%84%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%81%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2040483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%E5%BE%93%E6%9D%A5%E3%81%AECAN%E4%BD%BF%E7%94%A8%E6%B3%95%E3%81%8B%E3%82%89CAN-FD%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2040483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AFNXP%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%3CBR%20%2F%3E%E4%BE%8B%E3%82%92%E6%8C%99%E3%81%92%E3%82%8B%E3%81%AE%E3%81%AF%E9%96%93%E9%81%95%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%AA%E3%83%96AIPS_PLAT_CLK%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E9%80%9A%E5%B8%B8%E3%81%AE%E9%80%9F%E5%BA%A6(30Mhz)%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E3%82%92%E6%8C%99%E3%81%92%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%99%82%E8%A8%88%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%80%82%E3%81%93%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81CAN%20%E3%81%8B%E3%82%89%20CAN-FD%20%E3%81%B8%E3%81%AE%E5%A4%89%E6%9B%B420250210-test_can.7z%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E(64%E3%83%90%E3%82%A4%E3%83%88%E3%81%A8BRS%E3%81%8C%E6%9C%89%E5%8A%B9)%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
