How to run S32K344 OTA example
2,175 次查看
Steven_Cho
Hi support team,
I download and install S32K3_OTADEMO_0.8.0 example from the NXP website.
I use S32 Design Studio v3.5 to build the project but failed.
I found the readme mentions:
## SW Tools
- S32 Design Studio v3.4 with S32 Configuration Tools
- Real Time Drivers v1.0.0
Is it possible use S32 Design Studio v3.5 and Real Time Drivers v4.0.0 to build the S32K3_OTADEMO_0.8.0?
Another question is how this demo example download the new application to update? CAN? ethernet? wifi? bt? I didn’t see the description on the readme.
Thank you for your help.
2,141 次查看
davidtosenovjan
I would recommend to keep required SW tools as specified as least for initiale checks, you may download historical version of specified tools.
OTA is no about method of downloading of new application (that is application specific) but about possibily to switch between active and passive application under secure environment.
There are some trainings I could recommend to see.
https://www.nxp.com/design/training/automotive-security-and-over-the-air-ota-solution-with-s32k3-mcu...
https://www.nxp.com/design/training/automotive-mcu-security-and-ota-solution-with-cost-optimized-s32...
2,115 次查看
Steven_Cho
Okay, I may have misunderstood what OTA means.
Now I try to use Segger J-link to install HSE to custom board but I can't find the advanced option like PEMicro settings to select flash algorithm.
Dose Segger J-link no need select flash algorithm?
1,955 次查看
davidtosenovjan
Unfortunately I don't know the answer.
Please contact Segger support:
https://www.segger.com/support/technical-support/?utm_source=www&utm_medium=top_menu
