How to reconfig the Pin?
ソリューションへジャンプ
1,078件の閲覧回数
jx111
I'm using S32k118。I set PTA3 as a TXD pin used for LIN, but I want to reconfig the PTA3 pin as a GPIO. I use the "PINS_DRV_Init(1, g_pin_mux_PTA3)" to config the PTA3 pin, but it didn't work and occurs the problem. How to reconfig the pin?
1,073件の閲覧回数
PetrS
use functions PINS_DRV_SetMuxModeSel(), PINS_DRV_SetPinDirection() and other for reading/writing pin as per need.
BR, Petr
1,074件の閲覧回数
PetrS
BR, Petr
