How to receive multiple CAN message
6,017件の閲覧回数
RishikeshB
I am working on CAN on S32K148, i am receiving one time but I want to receive the same message multiple time how can we do it??
I have attached code along with received message screen shot.
4 返答(返信)
6,010件の閲覧回数
PetrS
in your code you called FLEXCAN_DRV_Send just once, so it is correct CAN tool received it just once too.
Call FLEXCAN_DRV_Send repeatedly to send message again. If using non-blocking function you should use FLEXCAN_DRV_GetTransferStatus to know if previous transfer was finished and Send/Receive can be called again.
BR, Petr
タグ(1)
6,004件の閲覧回数
RishikeshB
Hello I tried but did not receive the message multiple time can you please check
5,997件の閲覧回数
PetrS
6,007件の閲覧回数
RishikeshB
I have called function twice still no response,
can you please if possible add configuration from your end in code
