How to define multiple variables together to a specified address
2,046件の閲覧回数
HarryLe
use   __attribute__((section(".xxxxxx")))  is ok
But it only works on one variable.
There are now thousands of variables  need to be addressed,How to define multiple variables together to a specified address
1,930件の閲覧回数
stanish
Hi HarryLe,
I assume you are referning to S32 Design Studio for S32 Platform
NXP GCC for Arm Release based on gcc 6.3/9.2.0/10.2  supports:
#pragma GCC section (text|data|bss|rodata) ".name" pragma.
This pragma allows to redefine standard sections by user defined section
#pragma GCC section (text|data|bss|rodata) "default"
This pragma restores standard section
All the declaraions/code or data/const inbetween the pragmas will be placed to ".name" section.
For more information please see the NXP GCC compiler e.g. releasenotes.pdf (attched) ("C:\NXP\S32DS.3.5\S32DS\build_tools\gcc_v9.2\gcc-9.2-arm32-eabi\releasenotes.pdf")
Hope it helps.
Stan
