How to configure NVM partition directly using Segger?
2,586 次查看
venkatramanc
We are using an S32K144 microprocessor and want to use the FlexNVM memory block as EEPROM. The spec instructs to execute the NVM partition command using the FTFC module to configure and enable the FlexNVM part of flash memory for use as NVM.
I could do that by writing a small program that runs the partition command once and set up the NVM memory for use.
But, I want to know if we could configure this flex NVM partition directly through Segger using some configuration file.
I am looking for a simple way to enable the NVM during production process instead of running a special program that performs the NVM configuration.
Are there any alternate solutions for this?
1 回复
2,116 次查看
jonasbard
Is there any solution to flash the NVM via Segger J-Link?
