How to configure FlexCAN to avoid FLEXCAN_EVENT_RXFIFO_WARNING ?
2,432件の閲覧回数
1515190497
My Callback fuction :
void CAN_CallBack(uint8_t instance,
        flexcan_event_type_t eventType,
        uint32_t buffIdx,
        struct FlexCANState *driverState)
    if (eventType == FLEXCAN_EVENT_RXFIFO_COMPLETE)
        CAN_Analyse(&gsCAN_RXMsg);
        FLEXCAN_DRV_Receive(INST_CANCOM1, 7, &gsCAN_RXMsg);
when it recieve more than 8 frames data at the same time, the eventType will be FLEXCAN_EVENT_RXFIFO_WARNING, and then FLEXCAN_EVENT_RXFIFO_OVERFLOW.
タグ(1)
2,271件の閲覧回数
PetrS
to start receiving message into RXFIFO you need to use FLEXCAN_DRV_RxFifo() function. Within callback you use function for receiving into MB, moreover MB7, which is occupied by RXFIFO filter table. So try to use FLEXCAN_DRV_RxFifo(INST_CANCOM1,&gsCAN_RXMsg);
BR, Petr
