How to config S32K312 DMAMUX1 Source?
已解决
跳至解决方案
2,624 次查看
liangyouchao
From Chapter 13 of the S32K3XXRM.pdf document, we can see that the S32K312 supports DMAMUX1, but DMAMUX1 cannot be configured in the S32DS,I want to use LPUART2 via DMA, how do I configure it, looking forward to your reply
1 解答
2,610 次查看
PetrS
you would need to select Hardware Channel item to ch6-ch11. Then DMAMUX_1 sources becomes available to be selected.
BR, Petr
在原帖中查看解决方案
2 回复数
2,611 次查看
PetrS
BR, Petr
2,606 次查看
liangyouchao
Thank U, I get it.
