How to check stack size in s32k118 without os . compiler may be any
900 次查看
9860042625
1 回复
892 次查看
Alexis_A
Hello @9860042625,
There is not a tool that helps to monitor the stack usage but in the following link you can find this post that shows how to monitor the stack usage:
https://mcuoneclipse.com/2015/08/21/gnu-static-stack-usage-analysis/
Alexis Andalon
