How to Enable CSE (Cryptographic Service Engine) peripheral in S32R274RM Controller ?
1,707件の閲覧回数
MadharKhan
Iam using S32R274RM Controller and i want to implement CSE on it.
the values in the CSE Peripheral are in tristate(????) by default.
How can i enable this Peripheral ?
Thanks in Advance.
タグ(3)
1,694件の閲覧回数
lukaszadrapa
could you please confirm what is your part number? There are three configurations of the chip and only 'B' and 'S' configuration have CSE module.
See the datasheet, page 10, Table 2 and 3:
It's not necessary to enable the CSE. If you have the right part number, it should work without initialization.
Lukas
