How can i capture PWM duty cycle?
2,709 次查看
eautopower
Hi Okamies:
  How can i capture PWM duty cycle? Does SDK have the associated calling function? If yes, could you tell me which one?
Besides, I have another question:
 How do I modify the bootloader and APP momery addresses?
3 回复数
2,349 次查看
danielmartynek
Regarding the SDK, there is FTM_DRV_GetInputCaptureMeasurement() function that returns a value calculated from Channel (n, n+1) Value Registers based on the timer configuration.
This function returns Rising Edge Period Measurement in the example in Design Studio (S32K144_FTM_Signal_Measurement). This can be changed to Period On Measurement.
There is also an application note for the FlexTimer: Features and Operation Modes of FlexTimer Module on S32K
with software.
2,349 次查看
1462993357
Hi,Daniel Martynek
This"AN5303SW.zip" is invalid, can you share it again.thank you
2,349 次查看
danielmartynek
Hi [email protected],
You can find all the S32K1xx application notes here:
32-bit Automotive General Purpose MCUs | NXP
