High Drive Strength on S32K3
882 次查看
kscz
The S32K3XX reference manual talks about the "drive-strength enable" bits, but doesn't appear to define what this means - the closest reference I can find is that it seems correlated with maximum frequency supported by certain pins (page 42 of the S32K3XXRM/Section 4.4.1)
Is there something explicit in terms of maximum current draw or other things I should be aware of for why I should or should not enable "drive-strength"?
383 次查看
kscz
As I told the previous poster, I know which pins do and do not support "high drive strength," that is not the issue!
But fortunately, in the background you had the relevant chunk of information: in S32K3xx.pdf, Table 27. GPIO DC electrical specifications, appears to have what I need.
It looks like it doubles the output current of the pins to enable the "DSE = 0" vs "DSE = 1"  
5 回复数
772 次查看
Robin_Shen
The S32K3XX Reference Manual (S32K3XXRM) states that the Pad Type "GPIO-Standard" does not support high drive strength, whereas "GPIO-Standard Plus", "GPIO-Medium", and "GPIO-Fast" support high drive strength.
For GPIO Pad Type, please refer to the S32K344_IO Signal Table, specifically column H, in the Excel attachment S32K344_S32K324_S32K314_IOMUX.xlsx provided with the S32K3XXRM.
Robin
- If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
384 次查看
kscz
822 次查看
db16122
Hardware Design Guidelines for S32K39x, S32K37x and S32K36x Microcontrollers
858 次查看
db16122
GPIO-Standard: Switching up to 10 MHz High drive-strength not supported. Slew-rate control not supported.
GPIO-Standard plus: Switching up to 25 MHz  Supports high drive-strength. Slew-rate control not supported.
GPIO-Medium: Switching up to 50 MHz  Supports high drive-strength. Supports slew-rate control.
GPIO-Fast: Switching up to 120 MHz Supports high drive-strength. Supports slew-rate control.
838 次查看
kscz
Yes, that is exactly the text of the section I cited in my question. That doesn't tell me why I should or shouldn't enable "drive strength" - it just tells me that some pins support it, and that some switching rates are related to it.
If I were driving an LED with it, would it be capable of sinking more current? How much more current?
Is it purely a slew-rate change?
Is there a reason not to enable it, if the pin supports it? Will my chip dissipate more heat if I enable it?
%3CLINGO-SUB%20id%3D%22lingo-sub-2383578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3%20%E7%9A%84%E9%AB%98%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383578%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32K3XX%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E6%8F%90%E5%88%B0%E4%BA%86%E2%80%9C%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E4%BD%BF%E8%83%BD%E2%80%9D%E4%BD%8D%EF%BC%8C%E4%BD%86%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E5%AE%9A%E4%B9%89%E5%85%B6%E5%90%AB%E4%B9%89%E2%80%94%E2%80%94%E6%88%91%E8%83%BD%E6%89%BE%E5%88%B0%E7%9A%84%E6%9C%80%E6%8E%A5%E8%BF%91%E7%9A%84%E5%8F%82%E8%80%83%E8%B5%84%E6%96%99%E6%98%AF%EF%BC%8C%E5%AE%83%E4%BC%BC%E4%B9%8E%E4%B8%8E%E6%9F%90%E4%BA%9B%E5%BC%95%E8%84%9A%E6%94%AF%E6%8C%81%E7%9A%84%E6%9C%80%E5%A4%A7%E9%A2%91%E7%8E%87%E7%9B%B8%E5%85%B3%EF%BC%88S32K3XXRM%20%E7%AC%AC%2042%20%E9%A1%B5%2F%E7%AC%AC%204.4.1%20%E8%8A%82%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%85%B3%E4%BA%8E%E6%9C%80%E5%A4%A7%E7%94%B5%E6%B5%81%E6%B6%88%E8%80%97%E6%88%96%E5%85%B6%E4%BB%96%E6%96%B9%E9%9D%A2%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E6%98%8E%E7%A1%AE%E7%9A%84%E8%A7%84%E5%AE%9A%EF%BC%8C%E8%AE%A9%E6%88%91%E4%BA%86%E8%A7%A3%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E5%90%AF%E7%94%A8%E6%88%96%E4%B8%8D%E5%BA%94%E8%AF%A5%E5%90%AF%E7%94%A8%E2%80%9C%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E2%80%9D%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20High%20Drive%20Strength%20on%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383610%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGPIO%20%E6%A0%87%E5%87%86%EF%BC%9A%E5%BC%80%E5%85%B3%E9%A2%91%E7%8E%87%E6%9C%80%E9%AB%98%E5%8F%AF%E8%BE%BE%2010%20MHz%EF%BC%8C%E4%B8%8D%E6%94%AF%E6%8C%81%E9%AB%98%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E3%80%82%E4%B8%8D%E6%94%AF%E6%8C%81%E8%BD%AC%E6%8D%A2%E9%80%9F%E7%8E%87%E6%8E%A7%E5%88%B6%E3%80%82%3CBR%20%2F%3E%E2%80%94%3CBR%20%2F%3E%20GPIO%20%E6%A0%87%E5%87%86%E5%A2%9E%E5%BC%BA%E7%89%88%EF%BC%9A%E5%BC%80%E5%85%B3%E9%A2%91%E7%8E%87%E9%AB%98%E8%BE%BE%2025%20MHz%EF%BC%8C%E6%94%AF%E6%8C%81%E9%AB%98%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E3%80%82%E4%B8%8D%E6%94%AF%E6%8C%81%E8%BD%AC%E6%8D%A2%E9%80%9F%E7%8E%87%E6%8E%A7%E5%88%B6%E3%80%82%3CBR%20%2F%3E%E2%80%94%3CBR%20%2F%3E%20GPIO-%E4%B8%AD%E5%9E%8B%EF%BC%9A%E5%BC%80%E5%85%B3%E9%A2%91%E7%8E%87%E9%AB%98%E8%BE%BE%2050%20MHz%EF%BC%8C%E6%94%AF%E6%8C%81%E9%AB%98%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E3%80%82%E6%94%AF%E6%8C%81%E8%BD%AC%E6%8D%A2%E9%80%9F%E7%8E%87%E6%8E%A7%E5%88%B6%E3%80%82%3CBR%20%2F%3E%E2%80%94%3CBR%20%2F%3E%20GPIO-Fast%EF%BC%9A%E5%BC%80%E5%85%B3%E9%A2%91%E7%8E%87%E9%AB%98%E8%BE%BE%20120%20MHz%EF%BC%8C%E6%94%AF%E6%8C%81%E9%AB%98%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E3%80%82%E6%94%AF%E6%8C%81%E8%BD%AC%E6%8D%A2%E9%80%9F%E7%8E%87%E6%8E%A7%E5%88%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20High%20Drive%20Strength%20on%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%BF%99%E6%AD%A3%E6%98%AF%E6%88%91%E5%9C%A8%E9%97%AE%E9%A2%98%E4%B8%AD%E5%BC%95%E7%94%A8%E7%9A%84%E9%82%A3%E9%83%A8%E5%88%86%E5%86%85%E5%AE%B9%E7%9A%84%E5%8E%9F%E6%96%87%E3%80%82%E8%BF%99%E5%B9%B6%E6%B2%A1%E6%9C%89%E5%91%8A%E8%AF%89%E6%88%91%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E5%90%AF%E7%94%A8%E2%80%9C%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E2%80%9D%E2%80%94%E2%80%94%E5%AE%83%E5%8F%AA%E6%98%AF%E5%91%8A%E8%AF%89%E6%88%91%E6%9F%90%E4%BA%9B%E5%BC%95%E8%84%9A%E6%94%AF%E6%8C%81%E5%AE%83%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%9F%90%E4%BA%9B%E5%BC%80%E5%85%B3%E9%80%9F%E7%8E%87%E4%B8%8E%E5%AE%83%E6%9C%89%E5%85%B3%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%88%91%E7%94%A8%E5%AE%83%E9%A9%B1%E5%8A%A8%E4%B8%80%E4%B8%AALED%EF%BC%8C%E5%AE%83%E8%83%BD%E5%90%B8%E6%94%B6%E6%9B%B4%E5%A4%A7%E7%9A%84%E7%94%B5%E6%B5%81%E5%90%97%EF%BC%9F%E7%94%B5%E6%B5%81%E8%BF%98%E8%A6%81%E9%AB%98%E5%A4%9A%E5%B0%91%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%85%E4%BB%85%E6%98%AF%E8%BD%AC%E6%8D%A2%E9%80%9F%E7%8E%87%E7%9A%84%E5%8F%98%E5%8C%96%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E5%BC%95%E8%84%9A%E6%94%AF%E6%8C%81%EF%BC%8C%E6%9C%89%E4%BB%80%E4%B9%88%E7%90%86%E7%94%B1%E4%B8%8D%E5%90%AF%E7%94%A8%E5%AE%83%E5%91%A2%EF%BC%9F%E5%90%AF%E7%94%A8%E8%AF%A5%E5%8A%9F%E8%83%BD%E5%90%8E%EF%BC%8C%E6%88%91%E7%9A%84%E8%8A%AF%E7%89%87%E4%BC%9A%E6%95%A3%E5%8F%91%E6%9B%B4%E5%A4%9A%E7%83%AD%E9%87%8F%E5%90%97%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20High%20Drive%20Strength%20on%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH3%20id%3D%22toc-hId-2033795839%22%20id%3D%22toc-hId-2033794911%22%20id%3D%22toc-hId-2033794911%22%20id%3D%22toc-hId-2033794911%22%3E%3CSPAN%3ES32K39x%E3%80%81S32K37x%20%E5%92%8C%20S32K36x%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%E7%A1%AC%E4%BB%B6%E8%AE%BE%E8%AE%A1%E6%8C%87%E5%8D%97%3C%2FSPAN%3E%3C%2FH3%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20High%20Drive%20Strength%20on%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%3CSPAN%3ES32K3XX%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%20(S32K3XXRM)%3C%2FSPAN%3E%3CEM%20style%3D%22font-family%3A%20inherit%3B%22%3E%20%3C%2FEM%3E%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%E6%8C%87%E5%87%BA%EF%BC%8C%E2%80%9CGPIO-Standard%E2%80%9D%3C%2FSTRONG%3E%3CSPAN%3E%20%E7%84%8A%E7%9B%98%E7%B1%BB%E5%9E%8B%3C%2FSPAN%3E%3CSTRONG%20style%3D%22font-family%3A%20inherit%3B%22%3E%20%E4%B8%8D%E6%94%AF%E6%8C%81%E9%AB%98%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%EF%BC%8C%E8%80%8C%E2%80%9CGPIO-Standard%20Plus%E2%80%9D%E3%80%81%E2%80%9CGPIO-Medium%E2%80%9D%E5%92%8C%E2%80%9CGPIO-Fast%E2%80%9D%3C%2FSTRONG%3E%3CSPAN%3E%20%E7%84%8A%E7%9B%98%E7%B1%BB%E5%9E%8B%20%E6%94%AF%E6%8C%81%E9%AB%98%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%20GPIO%3CEM%3E%E7%84%8A%E7%9B%98%E7%B1%BB%E5%9E%8B%3C%2FEM%3E%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%80%83%3CSTRONG%3ES32K344_IO%20%E4%BF%A1%E5%8F%B7%E8%A1%A8%3C%2FSTRONG%3E%EF%BC%8C%E7%89%B9%E5%88%AB%E6%98%AF%3CSTRONG%3ES32K344_S32K324_S32K314_IOMUX.xlsx%3C%2FSTRONG%3E%E9%9A%8F%20S32K3XXRM%20%E6%8F%90%E4%BE%9B%E7%9A%84%20Excel%20%E9%99%84%E4%BB%B6%E4%B8%AD%E7%9A%84%3CSTRONG%3EH%20%E5%88%97%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22drive-strength%20high%20current%20Pad%20Type.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22drive-strength%20high%20current%20Pad%20Type.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22drive-strength%20high%20current%20Pad%20Type.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F389515iBD2707CB64409BDD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22drive-strength%20high%20current%20Pad%20Type.png%22%20alt%3D%22drive-strength%20high%20current%20Pad%20Type.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E7%BD%97%E5%AE%BE%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E7%AC%94%E8%AE%B0%EF%BC%9A%3CBR%20%2F%3E%20-%20%E5%A6%82%E6%9E%9C%E6%AD%A4%E5%B8%96%E8%A7%A3%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E2%80%9C%E6%8E%A5%E5%8F%97%E4%B8%BA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E2%80%9D%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3C%2FP%3E%0A%3CP%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E6%8C%81%E7%BB%AD%E5%85%B3%E6%B3%A8%E5%B8%96%E5%AD%90%EF%BC%8C%E4%BB%8E%E6%9C%80%E5%90%8E%E4%B8%80%E6%9D%A1%E5%9B%9E%E5%A4%8D%E5%8F%91%E5%87%BA%E5%90%8E%E6%8C%81%E7%BB%AD7%E5%91%A8%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%B9%8B%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8F%A6%E5%BC%80%E6%96%B0%E5%B8%96%E5%B9%B6%E5%BC%95%E7%94%A8%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2391271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20High%20Drive%20Strength%20on%20S32K3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2391271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%AD%A3%E5%A6%82%E6%88%91%E4%B9%8B%E5%89%8D%E5%91%8A%E8%AF%89%E8%BF%87%E7%9A%84%E5%B8%96%E5%AD%90%E4%B8%AD%E6%89%80%E8%BF%B0%EF%BC%8C%E6%88%91%E7%9F%A5%E9%81%93%E5%93%AA%E4%BA%9B%E5%BC%95%E8%84%9A%E6%94%AF%E6%8C%81%E2%80%9C%E9%AB%98%E9%A9%B1%E5%8A%A8%E5%BC%BA%E5%BA%A6%E2%80%9D%EF%BC%8C%E5%93%AA%E4%BA%9B%E4%B8%8D%E6%94%AF%E6%8C%81%EF%BC%8C%E8%BF%99%E4%B8%8D%E6%98%AF%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%86%E5%B9%B8%E8%BF%90%E7%9A%84%E6%98%AF%EF%BC%8C%E5%90%8E%E5%8F%B0%E5%B7%B2%E7%BB%8F%E6%9C%89%E4%BA%86%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%EF%BC%9A%E5%9C%A8%20S32K3xx.pdf%20%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%8C%E8%A1%A827%E3%80%82GPIO%E7%9B%B4%E6%B5%81%E7%94%B5%E6%B0%94%E8%A7%84%E6%A0%BC%EF%BC%8C%E4%BC%BC%E4%B9%8E%E7%AC%A6%E5%90%88%E6%88%91%E7%9A%84%E9%9C%80%E6%B1%82%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%AE%83%E5%B0%86%E5%BC%95%E8%84%9A%E7%9A%84%E8%BE%93%E5%87%BA%E7%94%B5%E6%B5%81%E5%8A%A0%E5%80%8D%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%AE%9E%E7%8E%B0%E2%80%9CDSE%20%3D%200%E2%80%9D%E8%80%8C%E4%B8%8D%E6%98%AF%E2%80%9CDSE%20%3D%201%E2%80%9D%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20From%202026-07-06%2009-18-58.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20From%202026-07-06%2009-18-58.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391381iB0B5EBD8B4CAF029%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%20From%202026-07-06%2009-18-58.png%22%20alt%3D%22Screenshot%20From%202026-07-06%2009-18-58.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Screenshot%20From%202026-07-06%2009-18-48.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20From%202026-07-06%2009-18-48.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391382i5D343D2F2CEBE668%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Screenshot%20From%202026-07-06%2009-18-48.png%22%20alt%3D%22Screenshot%20From%202026-07-06%2009-18-48.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
