HSE return "HSE_SRV_RSP_INVALID_PARAM" when request for HMAC verify job
WagdeoA
Hello Nxp team,
I have use case to use HMAC verify job. After triggering the job crypto driver throw DET and the response from HSE is "HSE_SRV_RSP_INVALID_PARAM".
I am not able to understand what wrong with my current configuration. could you please check attached config zip file?
Need support to resolve issue.
Aditya
lukaszadrapa
Hi @WagdeoA
There’s no problem in your configuration.
It works on my side. But one possible issue could be the length of tag (secondaryInputLength).
This can be found in function Crypto_Ipw_HmacVerify:
If redirection is disabled, it’s necessary to provide the length of tag in bits, not in bytes. Isn’t this the problem?
Lukas
lukaszadrapa
Hi @WagdeoA
Could you confirm which device, which RTD and which HSE firmware version you have?
Lukas
WagdeoA
Hi @lukaszadrapa ,
Details:
Device: S32K311
HSE FW: HSE_FW_S32K311_0_2_55_0
RTD: SW32K3_S32M27x_RTD_R21-11_6.0.0_QLP01
Aditya
lukaszadrapa
Hi @WagdeoA
Lukas
WagdeoA
Hi Lukas,
Sorry for late reply.
Yes, with length of tag in bits. It works at myside as well.
Thank you!
Aditya
