HSE firmware installation
vikmonti7804
     I want to install the HSE firmware, but i am facing one error with the package given C:\NXP\S32K3_HSE_DemoExamples_1_0_0\S32K3_HSE_DemoExamples\Device_Configuration\S32K344_HSE_FW_INSTALL.
error
make: *** [makefile:38: S32K312_HSE_FW_INSTALL.elf] Error 1
Kindly let me know the solution.
is there any firmware available for s32k312 for HSE fw installation?
Sanjana_k
Hello guys are you able to solve the error.If yes please help us with this
anakha
Does someone solve the problem?
I am issuing same steps with you. I tried both full_mem and ab_swap. both failed..
sandor_b
The "3.3.1 MU Installation steps by host in AB_SWAP configuration" chapter of HSE_B Firmware Reference Manual starts by the following lines:
"Write 0xA5 on register DCMRWP1 (0x402AC400, [24:31 bits]) followed by functional reset. This will set Bit 1 in HSE GPR (0x4039C028) indicating SBAF has activated MU0 for installation."
but it wasn't mentioned in this thread.
Is it necessary to set DCMRWP1 register or is it implemented somehow in the example?
Sandor
zkah
Has the problem been solved? What causes this? My side is also the status register can not be set "1", can you share how to solve?
sandor_b
I think I found a solution. In the memory view, the byte order will be reversed if you select "Hex" or "Hex Integer". The register was set for me, but these views confused me.
vikmonti7804
Hi Lucas,
           Can you please share your main program.
i have only one board with me and its new one.
lukaszadrapa
Attached is whole project.
vikmonti7804
HI,
  the Firmware for the s32k312 is only the file like interface and host, it is not complete project which can flash the HSE firmware binary to controller like s32k344 hse demo example.
I am facing a issue to flash the HSE firmware binry to cntroller as NXP provided only .bin file, i have used the PE micro and eval board built in debugger which is unable to do so, it can support only .elf and .hex file. kindly help me to flash the .bin to controller.
lukaszadrapa
The firmware is provided in encrypted form as a binary file. Yes, HSE FW installation package contains only the binary (pink) file and corresponding API headers.
For Lauterbach users, there's also HSE DEMOAPP which helps to install the firmware and examine HSE features:
But notice that the demo works with Lauterbach debugger only. It won't work with Pemicro.
As you can read in the mentioned application note or in HSE FW RM, the firmware can be installed with or without IVT.
Installation without IVT is easier but you need a tool which is able to load raw binary file to the flash which is not the case of Pemicro debugger. In this case, "with IVT" method is more convenient.
We do not provide S32K344_HSE_FW_INSTALL for each derivative. This is just an example showing how it can be done and it's up to users to create own solution (each customer has different requirements and production tools/capabilities).
What to do:
You can create new application project directly for S32K312 in S32 Design Studio. Then copy the source files from S32K344_HSE_FW_INSTALL, update HseFwHeader_StartAddress in boot_header.c. Then modify the linker file - use linker file from S32K344_HSE_FW_INSTALL as a template. If you read the readme.md file as I suggested earlier, there must be a link to the bin/pink file, so it is linked to the project.
Then, the code will only enable HSE feature flag by programming any value different from 0xFFFFFFFFFFFFFFFF at address 0x1B000000. Then all the conditions for installation are satisfied - HSE feature flag is enabled, IVT points to valid pink image in flash, so SBAF will install the firmware after next reset.
Lukas
vikmonti7804
Hi ,
  If I am able to install the HSE firmware successfully, how to verify this firmware is installed in the secure memory correctly or successfully in the memory.
please let me know any method or check the memory?
Thank You
lukaszadrapa
You can check bit 0 in HSE GPR status register at 0x4039C028. If it is '1', it means that "HSE FW is present and SBAF Booted HSE Firmware".
You can find this in HSE_B Firmware Reference Manual rev 2.2.
Lukas
vikmonti7804
Hi Lucas ,
         I am not able to see this register in any peripheral window in S32DS, Can you please tell me exactly where i can see.
i can see the value 0xC1010000 at 0x4039C028 address.
lukaszadrapa
I don't think the HSE GPR is defined in peripheral structure, so it's necessary to check the memory directly. If you can see 0xC1010000 at 0x4039C028, the HSE FW is obviously not installed.
Is the HSE feature flash at 0x1B000000 programmed?
And one more thing - I can remember that that if you use "without IVT" method to install the firmware, there can't be valid IVT in the flash. Otherwise it does not work. If you loaded the pink/bin file together with some project, it's necessary to remove the IVT. Or "with IVT" method must be used.
Lukas
vikmonti7804
     I am just following the example code given for the s32k344, so i created same project for the s32k312 and imported the binary from the linker file, i see the 0xAABBCCDD  at 0x1B000000 location in memory window, what can be the problem. Every thing is same as per the example code as s32k344, only i changed the memory location in linker file. Can you please help on urgent basis, or can we connect online for debugging purpose on small call.
please find the snippet of the linker file and program.
vikmonti7804_0-1708531086237.pngvikmonti7804_1-1708531115954.pngvikmonti7804_2-1708531147534.png
Sanjana_k
#hello@vikmonti7804  did u get the solution for the above problem that is programm getting stuck at below ..please hep us
if yes please please help us we are trying alot still we are not getting what to do ?
Thank u
vikmonti7804
          kindly check the image attached, the header of the AB_Swap is also there in the memory so it means the firmware is flashed in the memory, the utest area has value AABBCCDDDDCCBBAA it means utest is enabled, the HSE GPR register bit 0 is not getting set, i dont know why? it means after reset the SBAF is not installing the hse firmware in secure memory region.
kindly help on urgent basis.
lukaszadrapa
Hi @vikmonti7804
could you please share that project? I will test it on my side.
Lukas
vikmonti7804
Please find the project.
lukaszadrapa
Small problem on my side - I found that I already have firmware 2.6.0 on both my boards and it can't be erased (this feature was added in version 2.40.0). I will get brand new board on Monday and I will test it.
I checked the project anyway and I can see nothing wrong. I would just not program the HSE feature flag unconditionally after each reset.
I will let you know the results of my test on Monday.
Lukas
vikmonti7804
Hi Lucas
   Any update on this?
%3CLINGO-SUB%20id%3D%22lingo-sub-1808863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1808863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BI%20want%20to%20install%20the%20HSE%20firmware%2C%20but%20i%20am%20facing%20one%20error%20with%20the%20package%20given%26nbsp%3BC%3A%5CNXP%5CS32K3_HSE_DemoExamples_1_0_0%5CS32K3_HSE_DemoExamples%5CDevice_Configuration%5CS32K344_HSE_FW_INSTALL.%3C%2FP%3E%3CP%3Eerror%3C%2FP%3E%3CP%3Emake%3A%20***%20%5Bmakefile%3A38%3A%20S32K312_HSE_FW_INSTALL.elf%5D%20Error%201%3C%2FP%3E%3CP%3EKindly%20let%20me%20know%20the%20solution.%3C%2FP%3E%3CP%3Eis%20there%20any%20firmware%20available%20for%20s32k312%20for%20HSE%20fw%20installation%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20guys%20are%20you%20able%20to%20solve%20the%20error.If%20yes%20please%20help%20us%20with%20this%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDoes%20someone%20solve%20the%20problem%3F%26nbsp%3B%3C%2FP%3E%3CP%3EI%20am%20issuing%20same%20steps%20with%20you.%20I%20tried%20both%20full_mem%20and%20ab_swap.%20both%20failed..%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EI%20think%20I%20found%20a%20solution.%20In%20the%20memory%20view%2C%20the%20byte%20order%20will%20be%20reversed%20if%20you%20select%20%22Hex%22%20or%20%22Hex%20Integer%22.%20The%20register%20was%20set%20for%20me%2C%20but%20these%20views%20confused%20me.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20%223.3.1%20MU%20Installation%20steps%20by%20host%20in%20AB_SWAP%20configuration%22%20chapter%20of%20HSE_B%20Firmware%20Reference%20Manual%20starts%20by%20the%20following%20lines%3A%3C%2FP%3E%3CP%3E%22Write%200xA5%20on%20register%20DCMRWP1%20(0x402AC400%2C%20%5B24%3A31%20bits%5D)%20followed%20by%20functional%20reset.%20This%20will%20set%20Bit%201%20in%20HSE%20GPR%20(0x4039C028)%20indicating%20SBAF%20has%20activated%20MU0%20for%20installation.%22%3C%2FP%3E%3CP%3Ebut%20it%20wasn't%20mentioned%20in%20this%20thread.%3C%2FP%3E%3CP%3EIs%20it%20necessary%20to%20set%26nbsp%3BDCMRWP1%20register%20or%20is%20it%20implemented%20somehow%20in%20the%20example%3F%3C%2FP%3E%3CP%3ERegards%2C%3CBR%20%2F%3ESandor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3CBR%20%2F%3E%3CBR%20%2F%3EAny%20update%20here%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1973145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHas%20the%20problem%20been%20solved%3F%20What%20causes%20this%3F%20My%20side%20is%20also%20the%20status%20register%20can%20not%20be%20set%20%221%22%2C%20can%20you%20share%20how%20to%20solve%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EI%20performed%20HSE%20FW%20erase%20as%20you%20mentioned%2C%20and%20it%20worked.%20However%2C%20I%20can%20not%20install%20it%20back.%20How%20to%20install%20HSE%20FW%20again%3F%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EYetkin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%26nbsp%3B!%3CBR%20%2F%3E%3CBR%20%2F%3ERegarding%20the%20discussion%2C%20I'm%20trying%20to%20swap%20the%20S32K344%20board%20as%20well.%20I%20followed%20the%20following%20steps%3A%3CBR%20%2F%3E1)%20Download%20the%26nbsp%3BS32K3_HSE_DemoExamples_1_0_0%2C%20went%20for%20the%20a%2Fb%20swap%2C%20changed%20the%20linker%20file%20by%20adding%20the%20.pink%20file.%3CBR%20%2F%3E%3CBR%20%2F%3E2)%20I%20compiled%20the%20project%20and%20ran%20it%2C%20in%20run%20time%2C%20the%20code%20keeps%20on%20the%20following%20step%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20Wait%20for%20HSE%20to%20initialize(read%20status%20bits)%20after%20installation%20*%2F%3CBR%20%2F%3Ewhile((HSE_STATUS_INIT_OK%20%26amp%3B%20HSE_MU_GetHseStatus(0))%20%3D%3D%200)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EgInstallHSEFwTest%20%3D%20FW_NOT_INSTALLED%3B%3CBR%20%2F%3E%2F*%20Please%20generate%20a%20reset%20to%20allow%20installation%20*%2F%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E3)%20I%20tried%20to%20both%20push%20the%20RST%20button%20on%20the%20board%20and%20also%20powering%20it%20off%20and%20on%20again%2C%20but%20apparently%20it%20isn%60t%20changing%20anything.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EDid%20I%20forget%20a%20step%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1818321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1818321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20Lucas%20%2C%20when%20can%20we%20connect%2C%20please%20provide%20time%20and%20link%20to%20connect.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20running%20out%20of%20time%20today%20but%20tomorrow%20morning%20should%20be%20ok.%20I%20will%20let%20you%20know%20early%20in%20the%20morning%20when%20I'm%20available.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOr%20you%20can%20create%26nbsp%3B%20video%20for%20the%20debug%20settings%20and%20debugging%20the%20firmware%20and%20then%20share%20with%20me.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lucas%20%2C%20i%20tried%20but%20its%20same.%3C%2FP%3E%3CP%3ECan%20we%20connect%20for%20a%20call%20hardly%2010%20minutes%20if%20possible%3F%20please%20let%20me%20know%20so%20i%20will%20share%20the%20invite.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThere's%20elf%20file%20in%20the%20project%20I%20already%20shared%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2FS32K%2F32120%2F1%2FHSE_Install_FW.zip%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2FS32K%2F32120%2F1%2FHSE_Install_FW.zip%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EI%20compared%20the%20elf%20with%20my%20current%20project%20which%20I%20tested%20today%20and%20it's%20identical%2C%20no%20changes.%3C%2FP%3E%0A%3CP%3EI%20had%20brand%20new%20chip%2C%20so%20I%20used%20default%20hse_disabled%20version.%20If%20HSE%20feature%20flash%20is%20already%20enabled%20but%20HSE%20FW%20is%20not%20installed%20yet%2C%20you%20should%20use%20hse_enabled.%20And%20once%20AB%20swap%20is%20installed%2C%20you%20should%20use%20ab_swap.%20But%20I%20don't%20think%20this%20could%20be%20wrong%20because%20Pemicro%20should%20show%20some%20error%20if%20it%20can't%20erase%20or%20program%20the%20flash.%20Even%20if%20you%20use%20hse_disabled%20when%20HSE%20feature%20flag%20is%20programmed%2C%20it%20will%20probably%20still%20work.%20%3C%2FP%3E%0A%3CP%3ETo%20install%20the%20firmware%20also%20to%20passive%20block%2C%20two%20resets%20are%20needed%20(or%20two%20power%20cycles%2C%20it%20doesn't%20matter)%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265542i88AD2B7FA35E3A27%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709119050485.png%22%20alt%3D%22lukaszadrapa_0-1709119050485.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lucas%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BThanks%20for%20your%20reply%2C%3C%2FP%3E%3CP%3ECan%20you%20please%20share%20your%20.elf%20file.%3C%2FP%3E%3CP%3EWhy%20you%20power%20cycled%20the%20board%202%20time%2C%20is%20it%20mandatory%20to%20reset%20is%202%20time%20or%20power%20on%202%20times%3F%3C%2FP%3E%3CP%3Ewhat%20was%20the%20setting%20during%20flash%2C%20is%20it%20ab_sawp.arp%20or%20hse_enabled.arp%20in%20the%20advance%20setting%3F%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20used%20another%20brand%20new%20board%20for%20my%20test%20and%20I%20used%20exactly%20the%20same%20project%20I%20sent%20you%20earlier.%20I%20loaded%20the%20project%20by%20S32DS%20via%20in-built%20Pemicro%20OpenSDA%20interface%2C%20run%20the%20project%2C%20power%20cycled%20the%20board%202x%20and%20then%20I%20can%20see%20that%20the%20bit%20in%20HSE%20GPR%20is%20set%20and%20FW%20is%20installed.%3C%2FP%3E%0A%3CP%3EOnce%20the%20HSE%20FW%20is%20installed%2C%20it's%20necessary%20to%20change%20the%20flash%20algorithm%20in%20Pemicro%20settings%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265527iB7ECE6479C2728D4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709113020433.png%22%20alt%3D%22lukaszadrapa_0-1709113020433.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EThat's%20because%20some%20parts%20of%20flash%20are%20allocated%20for%20HSE%20when%20the%20HSE%20feature%20flag%20is%20enabled%20or%20when%20AB%20swap%20FW%20is%20installed.%20Pemicro%20needs%20to%20be%20informed%20about%20this.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20Lucas%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20I%20tried%20with%20different%20board%20with%20same%20firmware%20project%20what%20you%20shared%20but%20the%20result%20is%20same%20as%20earlier.%20Last%20bit%20of%20the%20HSE%20GPR%20register%20is%20not%20getting%20set.%3C%2FP%3E%3CP%3ECan%20you%20please%20try%20with%20PE%20Micro%20debugger%20and%20try%20to%20find%20the%20root%20cause%20of%20the%20problem.%3C%2FP%3E%3CP%3EWe%20dont%20have%20lauterbach%20debugger%20here.%3C%2FP%3E%3CP%3Ei%20am%20sharing%20the%20picture%20of%20the%20memory%20with%20different%20board.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265454i8351747C6E419CCD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1709101778843.png%22%20alt%3D%22vikmonti7804_0-1709101778843.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265455iA1255ADD2EB4FAF8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_1-1709101788067.png%22%20alt%3D%22vikmonti7804_1-1709101788067.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265456iF2433A8B8FFF8C54%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_2-1709101802879.png%22%20alt%3D%22vikmonti7804_2-1709101802879.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lucas%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BI%20dont%20have%20debugger%20PE%20micro.%20Does%20this%20trace32%20power%20view%20works%20with%20PE%20micro%3F%3C%2FP%3E%3CP%3EHow%20to%20trigger%26nbsp%3B%3CSPAN%3Ethe%20service%20via%20MU%20in%20debugger%20with%20PE%20micro%20and%20s32DS%3F%20is%20there%20any%20example%20code%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHow%20can%20i%20erase%20the%20controller%20with%20S32DS%3F%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EIs%20there%20any%20example%20code%20or%20should%20i%20use%20the%20API%20FLASH_EraseBlock(dst)%3B%20%3F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20is%20new%20feature%20and%20I%20didn't%20find%20API%20for%20that%20in%20RTD%20or%20in%20HSE%20DEMO%20examples.%20So%2C%20I%20used%20minimalist%20option%20and%20I%20simply%20triggered%20the%20service%20via%20MU%20in%20debugger.%20Here%20is%20the%20description%20of%20the%20service%20from%20API%20manual%3A%3C%2FP%3E%0A%3CP%3Ec%3A%5CNXP%5CHSE_FW_S32K312_0_2_40_0%5Cdocs%5CS32K312_HSE_Service_API_Reference_Manual.pdf%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265258i86AB0A9FB93402DB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709023598929.png%22%20alt%3D%22lukaszadrapa_0-1709023598929.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265259i11E1CBCABDAB8DF6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_1-1709023606522.png%22%20alt%3D%22lukaszadrapa_1-1709023606522.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESo%2C%20the%20service%20ID%20is%200x57%20and%20no%20parameters%20are%20needed.%3C%2FP%3E%0A%3CP%3EJust%20write%200x57%20somewhere%20to%20RAM%20and%20then%20write%20address%20of%20this%20RAM%20word%20to%20Message%20Unit%20MU_0%2C%20register%20TR%5B1%5D.%20That's%20all.%20Then%20you%20will%20see%20the%20response%20in%20RR%5B1%5D.%20If%20the%20HSE%20FW%20was%20installed%2C%20you%20should%20get%20HSE_SRV_RSP_OK%20which%20is%20value%200x55A5AA33.%3C%2FP%3E%0A%3CP%3EHere's%20how%20it%20looks%20in%20my%20debugger%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265263i93C8A450B5ABE75B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_2-1709023848154.png%22%20alt%3D%22lukaszadrapa_2-1709023848154.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20trying%20to%20use%20FLASH_EraseBlock((uint32_t*)HSE_SRV_ID_ERASE_FW)%3B%20but%20it%20goes%20into%20the%20hard%20fault.%3C%2FP%3E%3CP%3ECan%20you%20please%20explain%20the%20steps%20to%20erase%20the%20memory.%26nbsp%3B%3C%2FP%3E%3CP%3EShould%20i%20comment%20the%20import%20of%20the%20hse%20fw%20file%20in%20linker%20file%20befor%20applying%20this%20erase%3F%3C%2FP%3E%3CP%3Ehow%20it%20will%20be%20done%2C%20please%20explain.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lucas%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BWhich%20api%20you%20had%20used%20to%20erase%20the%20controller%20with%26nbsp%3B%3CSPAN%3EHSE_SRV_ID_ERASE_FW%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPlease%20provide%20the%20API%20.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAttached%20is%20whole%20project.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDis%20you%20used%20the%20project%20which%20i%20shared%20with%20you%3F%3C%2FP%3E%3CP%3EKindly%20share%20your%20main%20program%20with%20me.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lucas%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BCan%20you%20please%20share%20your%20main%20program.%3C%2FP%3E%3CP%3Ei%20have%20only%20one%20board%20with%20me%20and%20its%20new%20one.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20got%20new%20board%20right%20now.%20Here's%20the%20result%20of%20my%20test%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265036i6562E61CB478184D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1708948550506.png%22%20alt%3D%22lukaszadrapa_0-1708948550506.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EI%20was%20able%20to%20successfully%20install%20the%20firmware%20using%20your%20project.%20I%20just%20uncommented%20checking%20of%20the%20HSE%20feature%20flag.%20That%20was%20the%20only%20change%20I%20did.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAfter%20that%2C%20I%20could%20successfully%20erase%20the%20firmware%20using%20service%20HSE_SRV_ID_ERASE_FW.%3C%2FP%3E%0A%3CP%3EI'm%20still%20not%20sure%20why%20it%20does%20not%20work%20on%20your%20side.%20Do%20you%20have%20more%20boards%3F%20Are%20all%20of%20them%20showing%20the%20same%20behavior%3F%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lucas%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3BAny%20update%20on%20this%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1814467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1814467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20tried%20the%20firmware%20with%20the%20condition%20on%20the%20feature%20flag%26nbsp%3B%20but%20again%20the%20hse%20gpr%20resgiter%20is%20not%20getting%20updated.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264721iA4F29D438A1284BD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1708676777819.png%22%20alt%3D%22vikmonti7804_0-1708676777819.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1814437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1814437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESmall%20problem%20on%20my%20side%20-%20I%20found%20that%20I%20already%20have%20firmware%202.6.0%20on%20both%20my%20boards%20and%20it%20can't%20be%20erased%20(this%20feature%20was%20added%20in%20version%202.40.0).%20I%20will%20get%20brand%20new%20board%20on%20Monday%20and%20I%20will%20test%20it.%3C%2FP%3E%0A%3CP%3EI%20checked%20the%20project%20anyway%20and%20I%20can%20see%20nothing%20wrong.%20I%20would%20just%20not%20program%20the%20HSE%20feature%20flag%20unconditionally%20after%20each%20reset.%3C%2FP%3E%0A%3CP%3EI%20will%20let%20you%20know%20the%20results%20of%20my%20test%20on%20Monday.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20debug%20it%20and%20check%20why%20hse%20gpr%20register%20bit%20is%20not%20getting%20set%20and%20installation%20is%26nbsp%3B%20not%20completing%20by%20sbaf.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20find%20the%20project.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224860%22%20target%3D%22_blank%22%3E%40vikmonti7804%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ecould%20you%20please%20share%20that%20project%3F%20I%20will%20test%20it%20on%20my%20side.%3C%2FP%3E%0A%3CP%3EThanks%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20kindly%20check%20the%20image%20attached%2C%20the%20header%20of%20the%20AB_Swap%20is%20also%20there%20in%20the%20memory%20so%20it%20means%20the%20firmware%20is%20flashed%20in%20the%20memory%2C%20the%20utest%20area%20has%20value%20AABBCCDDDDCCBBAA%20it%20means%20utest%20is%20enabled%2C%20the%20HSE%20GPR%20register%20bit%200%20is%20not%20getting%20set%2C%20i%20dont%20know%20why%3F%20it%20means%20after%20reset%20the%20SBAF%20is%20not%20installing%20the%20hse%20firmware%20in%20secure%20memory%20region.%3C%2FP%3E%3CP%3Ekindly%20help%20on%20urgent%20basis.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264536i89A663620CCD852C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1708596640252.png%22%20alt%3D%22vikmonti7804_0-1708596640252.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BI%20am%20just%20following%20the%20example%20code%20given%20for%20the%20s32k344%2C%20so%20i%20created%20same%20project%20for%20the%20s32k312%20and%20imported%20the%20binary%20from%20the%20linker%20file%2C%20i%20see%20the%26nbsp%3B0xAABBCCDD%26nbsp%3B%20at%200x1B000000%20location%20in%20memory%20window%2C%20what%20can%20be%20the%20problem.%20Every%20thing%20is%20same%20as%20per%20the%20example%20code%20as%20s32k344%2C%20only%20i%20changed%20the%20memory%20location%20in%20linker%20file.%20Can%20you%20please%20help%20on%20urgent%20basis%2C%20or%20can%20we%20connect%20online%20for%20debugging%20purpose%20on%20small%20call.%3C%2FP%3E%3CP%3Eplease%20find%20the%20snippet%20of%20the%20linker%20file%20and%20program.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264315iE0EDA2AD10EFECE3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1708531086237.png%22%20alt%3D%22vikmonti7804_0-1708531086237.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264316iFEF84EEEF1A434E6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_1-1708531115954.png%22%20alt%3D%22vikmonti7804_1-1708531115954.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264317iF134C0887931C929%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_2-1708531147534.png%22%20alt%3D%22vikmonti7804_2-1708531147534.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20don't%20think%20the%20HSE%20GPR%20is%20defined%20in%20peripheral%20structure%2C%20so%20it's%20necessary%20to%20check%20the%20memory%20directly.%20If%20you%20can%20see%200xC1010000%20at%200x4039C028%2C%20the%20HSE%20FW%20is%20obviously%20not%20installed.%3C%2FP%3E%0A%3CP%3EIs%20the%20HSE%20feature%20flash%20at%200x1B000000%20programmed%3F%3C%2FP%3E%0A%3CP%3EAnd%20one%20more%20thing%20-%20I%20can%20remember%20that%20that%20if%20you%20use%20%22without%20IVT%22%20method%20to%20install%20the%20firmware%2C%20there%20can't%20be%20valid%20IVT%20in%20the%20flash.%20Otherwise%20it%20does%20not%20work.%20If%20you%20loaded%20the%20pink%2Fbin%20file%20together%20with%20some%20project%2C%20it's%20necessary%20to%20remove%20the%20IVT.%20Or%20%22with%20IVT%22%20method%20must%20be%20used.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Lucas%20%2C%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BI%20am%20not%20able%20to%20see%20this%20register%20in%20any%20peripheral%20window%20in%20S32DS%2C%20Can%20you%20please%20tell%20me%20exactly%20where%20i%20can%20see.%3C%2FP%3E%3CP%3Ei%20can%20see%20the%20value%200xC1010000%20at%26nbsp%3B%3CSPAN%3E0x4039C028%20address.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3BActually%20i%20have%20created%20a%20project%20for%20s32k312%26nbsp%3B%20but%20when%20i%20am%20running%20it%20in%20debug%20mde%20i%20see%20it%20directly%20jumping%20to%20default%20hander%20not%20going%20into%20main%2C%20can%20you%20please%20help%20with%20this%20issue%2C%20why%20this%20is%20happening.%3C%2FP%3E%3CP%3Ei%20see%20the%20binary%20is%20place%20in%20flash%20but%20utest%20is%20not%20enabled%20due%20to%20not%20going%20into%20main.%3C%2FP%3E%3CP%3Ekindly%20help.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20can%20check%20bit%200%20in%20HSE%20GPR%20status%20register%20at%200x4039C028.%20If%20it%20is%20'1'%2C%20it%20means%20that%20%22HSE%20FW%20is%20present%20and%20SBAF%20Booted%20HSE%20Firmware%22.%3C%2FP%3E%0A%3CP%3EYou%20can%20find%20this%20in%20HSE_B%20Firmware%20Reference%20Manual%20rev%202.2.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1811847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1811847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20If%20I%20am%20able%20to%20install%20the%20HSE%20firmware%20successfully%2C%20how%20to%20verify%20this%20firmware%20is%20installed%20in%20the%20secure%20memory%20correctly%20or%20successfully%20in%20the%20memory.%3C%2FP%3E%3CP%3Eplease%20let%20me%20know%20any%20method%20or%20check%20the%20memory%3F%3C%2FP%3E%3CP%3EThank%20You%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1809755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1809755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20firmware%20is%20provided%20in%20encrypted%20form%20as%20a%20binary%20file.%20Yes%2C%20HSE%20FW%20installation%20package%20contains%20only%20the%20binary%20(pink)%20file%20and%20corresponding%20API%20headers.%3C%2FP%3E%0A%3CP%3EFor%20Lauterbach%20users%2C%20there's%20also%20HSE%20DEMOAPP%20which%20helps%20to%20install%20the%20firmware%20and%20examine%20HSE%20features%3A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F263436i6D824F1E7A23ED65%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1708065109693.png%22%20alt%3D%22lukaszadrapa_0-1708065109693.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBut%20notice%20that%20the%20demo%20works%20with%20Lauterbach%20debugger%20only.%20It%20won't%20work%20with%20Pemicro.%3C%2FP%3E%0A%3CP%3EAs%20you%20can%20read%20in%20the%20mentioned%20application%20note%20or%20in%20HSE%20FW%20RM%2C%20the%20firmware%20can%20be%20installed%20with%20or%20without%20IVT.%3C%2FP%3E%0A%3CP%3EInstallation%20without%20IVT%20is%20easier%20but%20you%20need%20a%20tool%20which%20is%20able%20to%20load%20raw%20binary%20file%20to%20the%20flash%20which%20is%20not%20the%20case%20of%20Pemicro%20debugger.%20In%20this%20case%2C%20%22with%20IVT%22%20method%20is%20more%20convenient.%3C%2FP%3E%0A%3CP%3EWe%20do%20not%20provide%20S32K344_HSE_FW_INSTALL%20for%20each%20derivative.%20This%20is%20just%20an%20example%20showing%20how%20it%20can%20be%20done%20and%20it's%20up%20to%20users%20to%20create%20own%20solution%20(each%20customer%20has%20different%20requirements%20and%20production%20tools%2Fcapabilities).%3C%2FP%3E%0A%3CP%3EWhat%20to%20do%3A%3CBR%20%2F%3EYou%20can%20create%20new%20application%20project%20directly%20for%20S32K312%20in%20S32%20Design%20Studio.%20Then%20copy%20the%20source%20files%20from%20S32K344_HSE_FW_INSTALL%2C%20update%20HseFwHeader_StartAddress%20in%20boot_header.c.%20Then%20modify%20the%20linker%20file%20-%20use%20linker%20file%20from%20S32K344_HSE_FW_INSTALL%20as%20a%20template.%20If%20you%20read%20the%20readme.md%20file%20as%20I%20suggested%20earlier%2C%20there%20must%20be%20a%20link%20to%20the%20bin%2Fpink%20file%2C%20so%20it%20is%20linked%20to%20the%20project.%3C%2FP%3E%0A%3CP%3EThen%2C%20the%20code%20will%20only%20enable%20HSE%20feature%20flag%20by%20programming%20any%20value%20different%20from%200xFFFFFFFFFFFFFFFF%20at%20address%200x1B000000.%20Then%20all%20the%20conditions%20for%20installation%20are%20satisfied%20-%20HSE%20feature%20flag%20is%20enabled%2C%20IVT%20points%20to%20valid%20pink%20image%20in%20flash%2C%20so%20SBAF%20will%20install%20the%20firmware%20after%20next%20reset.%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1809037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1809037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%20the%20Firmware%20for%20the%20s32k312%20is%20only%20the%20file%20like%20interface%20and%20host%2C%20it%20is%20not%20complete%20project%20which%20can%20flash%20the%20HSE%20firmware%20binary%20to%20controller%20like%20s32k344%20hse%20demo%20example.%3C%2FP%3E%3CP%3EI%20am%20facing%20a%20issue%20to%20flash%20the%20HSE%20firmware%20binry%20to%20cntroller%20as%20NXP%20provided%20only%20.bin%20file%2C%20i%20have%20used%20the%20PE%20micro%20and%20eval%20board%20built%20in%20debugger%20which%20is%20unable%20to%20do%20so%2C%20it%20can%20support%20only%20.elf%20and%20.hex%20file.%20kindly%20help%20me%20to%20flash%20the%20.bin%20to%20controller.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1809034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1809034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%2C%3C%2FP%3E%3CP%3E%26nbsp%3BThe%20HSE%20firmware%20package%20foe%20the%20S32K312%20is%20only%20having%20the%20bin%20files%20and%20some%20interface%20and%20host%20files%20for%20the%20creation%20of%20the%20project.%20It%20is%20not%20the%20complete%20project%20like%20HSE%20demo%20example%20for%20s32k344.%3C%2FP%3E%3CP%3EI%20am%20also%20facing%20the%20issue%20to%20flash%20this%20binary%20of%20HSE%20firmware%20with%20the%20eval%20board%20debugger%20as%20well%20as%20PE%20micro%20debugger%20because%20it%20supports%20only%20.elf%20and%20hex%20file.%20kindly%20help%20me%20to%20flash%20the%20binary%20to%20the%20eval%20board.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1808928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1808928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224860%22%20target%3D%22_blank%22%3E%40vikmonti7804%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20HSE%20FW%20can%20be%20found%20in%20S32K3%20Standard%20Software%20package%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EOpen%20the%20%22Automotive%20SW%20-%20S32K3%20-%20HSE%20Firmware%22%20and%20you%20will%20see%20all%20available%20versions%20including%20version%20for%20S32K312.%3C%2FP%3E%0A%3CP%3EMentioned%20example%20S32K344_HSE_FW_INSTALL%20shows%20an%20option%20how%20to%20install%20the%20firmware.%20I%20recommend%20to%20read%20the%20description%3A%3CBR%20%2F%3Ec%3A%5CNXP%5CS32K3_HSE_DemoExamples_1_0_0%5CS32K3_HSE_DemoExamples%5CDevice_Configuration%5CS32K344_HSE_FW_INSTALL%5CReadme.md%3C%2FP%3E%0A%3CP%3EWe%20also%20provide%20document%20AN744810%20%E2%80%9CHSE%20FW%20install%20for%20S32K3xx%E2%80%9D%20which%20describes%20how%20to%20install%20the%20firmware.%20It%20can%20be%20found%20in%20Documentation%20in%20Secure%20Files%20section%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fs32-automotive-platform%2Fs32k-auto-general-purpose-mcus%2Fs32k3-microcontrollers-for-automotive-general-purpose%3AS32K3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fs32-automotive-platform%2Fs32k-auto-general-purpose-mcus%2Fs32k3-microcontrollers-for-automotive-general-purpose%3AS32K3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%23hello%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224860%22%20target%3D%22_blank%22%3E%40vikmonti7804%3C%2FA%3E%26nbsp%3B%20did%20u%20get%20the%20solution%20for%20the%20above%20problem%20that%20is%20programm%20getting%20stuck%20at%20below%20..please%20hep%20us%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368644i592958693E4B6065%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sanjana_k_0-1764857943379.png%22%20alt%3D%22Sanjana_k_0-1764857943379.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eif%20yes%20please%20please%20help%20us%20we%20are%20trying%20alot%20still%20we%20are%20not%20getting%20what%20to%20do%20%3F%3C%2FP%3E%3CP%3EThank%20u%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%23Hello%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EPlease%20help%20us%20we%20need%20your%20help.%20Our%20HSE%20firmware%20is%20flashed%20successfully%2C%20but%20the%20firmware%20is%20%3CSTRONG%3Enot%20starting%3C%2FSTRONG%3E%20after%20flashing.%3CBR%20%2F%3EThe%20system%20gets%20stuck%20at%20the%20same%20point%20every%20time%20and%20does%20not%20continue%20execution.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368643iAB002B507DAF0A5F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sanjana_k_1-1764857212653.png%22%20alt%3D%22Sanjana_k_1-1764857212653.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20am%20not%20sure%20why%20this%20is%20happening.%3C%2FP%3E%3CP%3EI%20have%20a%20few%20doubts%3A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EBefore%20flashing%20the%20firmware%2C%20do%20we%20need%20to%20run%20any%20other%20project%20like%20the%20Key%20Catalog%20example%20or%20any%20prerequisite%20configuration%3F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EEarlier%2C%20we%20had%20flashed%20%3CSTRONG%3EHSE%20Firmware%20version%202.1%3C%2FSTRONG%3E%2C%20but%20now%20we%20changed%20the%20firmware%20to%20%3CSTRONG%3Eversion%202.55%3C%2FSTRONG%3E.%3CBR%20%2F%3ECould%20this%20version%20change%20cause%20the%20issue%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EThe%20%3CSTRONG%3ESBUF%20version%20we%20are%20reading%20is%200x00500000%3C%2FSTRONG%3E.%3CBR%20%2F%3EIs%20this%20expected%20for%20firmware%20version%202.55%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EDo%20we%20need%20to%20make%20any%20specific%20changes%20in%20the%20%3CSTRONG%3EHSE_FW_INSTALL%20application%20code%3C%2FSTRONG%3E%20when%20updating%20to%20the%20new%20firmware%20version%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3Ewe%20have%20API%20provided%20along%20with%20firmware%20where%20we%20need%20to%20use%20them%20%3F%3C%2FLI%3E%3C%2FOL%3E%3CP%3EPlease%20please%20guide%20us%20on%20what%20might%20be%20causing%20the%20firmware%20not%20to%20start.%3C%2FP%3E%3CP%3EThank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%3C%2FP%3E%3CP%3Eplease%20help%20us%20our%20firmware%20code%20itself%20stucking%20at%26nbsp%3B%20i%20dont%20know%20why%20this%20is%20happening%20please%20help%20us%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368640iC3DE810D0B7AFC41%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sanjana_k_0-1764856626000.png%22%20alt%3D%22Sanjana_k_0-1764856626000.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Efirmware%20flshing%20i%20did%20and%20verified%20i%20dont%20know%20why%20my%20firmware%20is%20not%20initiating%20..please%20help%20us%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20u%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%23%20Hello%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243050%22%20target%3D%22_blank%22%3E%40sandor_b%3C%2FA%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EDid%20you%20receive%20any%20update%20regarding%20this%20issue%3F%3CBR%20%2F%3EWe%20are%20also%20facing%20the%20same%20problem%20%E2%80%94%20our%20program%20is%20getting%20stuck%20at%20that%20line.%3CBR%20%2F%3EIf%20you%20have%20found%20a%20solution%2C%20could%20you%20please%20share%20it%3F%20It%20would%20really%3C%2FP%3E%3C%2FLINGO-BODY%3E
