HSE firmware installation
40,006 次查看
vikmonti7804
     I want to install the HSE firmware, but i am facing one error with the package given C:\NXP\S32K3_HSE_DemoExamples_1_0_0\S32K3_HSE_DemoExamples\Device_Configuration\S32K344_HSE_FW_INSTALL.
error
make: *** [makefile:38: S32K312_HSE_FW_INSTALL.elf] Error 1
Kindly let me know the solution.
is there any firmware available for s32k312 for HSE fw installation?
45 回复数
10,445 次查看
Sanjana_k
Hello guys are you able to solve the error.If yes please help us with this
11,675 次查看
anakha
Does someone solve the problem?
I am issuing same steps with you. I tried both full_mem and ab_swap. both failed..
22,258 次查看
sandor_b
The "3.3.1 MU Installation steps by host in AB_SWAP configuration" chapter of HSE_B Firmware Reference Manual starts by the following lines:
"Write 0xA5 on register DCMRWP1 (0x402AC400, [24:31 bits]) followed by functional reset. This will set Bit 1 in HSE GPR (0x4039C028) indicating SBAF has activated MU0 for installation."
but it wasn't mentioned in this thread.
Is it necessary to set DCMRWP1 register or is it implemented somehow in the example?
Sandor
22,757 次查看
zkah
Has the problem been solved? What causes this? My side is also the status register can not be set "1", can you share how to solve?
22,213 次查看
sandor_b
I think I found a solution. In the memory view, the byte order will be reversed if you select "Hex" or "Hex Integer". The register was set for me, but these views confused me.
26,829 次查看
vikmonti7804
Hi Lucas,
           Can you please share your main program.
i have only one board with me and its new one.
26,819 次查看
lukaszadrapa
Attached is whole project.
27,289 次查看
vikmonti7804
HI,
  the Firmware for the s32k312 is only the file like interface and host, it is not complete project which can flash the HSE firmware binary to controller like s32k344 hse demo example.
I am facing a issue to flash the HSE firmware binry to cntroller as NXP provided only .bin file, i have used the PE micro and eval board built in debugger which is unable to do so, it can support only .elf and .hex file. kindly help me to flash the .bin to controller.
27,278 次查看
lukaszadrapa
The firmware is provided in encrypted form as a binary file. Yes, HSE FW installation package contains only the binary (pink) file and corresponding API headers.
For Lauterbach users, there's also HSE DEMOAPP which helps to install the firmware and examine HSE features:
But notice that the demo works with Lauterbach debugger only. It won't work with Pemicro.
As you can read in the mentioned application note or in HSE FW RM, the firmware can be installed with or without IVT.
Installation without IVT is easier but you need a tool which is able to load raw binary file to the flash which is not the case of Pemicro debugger. In this case, "with IVT" method is more convenient.
We do not provide S32K344_HSE_FW_INSTALL for each derivative. This is just an example showing how it can be done and it's up to users to create own solution (each customer has different requirements and production tools/capabilities).
What to do:
You can create new application project directly for S32K312 in S32 Design Studio. Then copy the source files from S32K344_HSE_FW_INSTALL, update HseFwHeader_StartAddress in boot_header.c. Then modify the linker file - use linker file from S32K344_HSE_FW_INSTALL as a template. If you read the readme.md file as I suggested earlier, there must be a link to the bin/pink file, so it is linked to the project.
Then, the code will only enable HSE feature flag by programming any value different from 0xFFFFFFFFFFFFFFFF at address 0x1B000000. Then all the conditions for installation are satisfied - HSE feature flag is enabled, IVT points to valid pink image in flash, so SBAF will install the firmware after next reset.
Lukas
27,184 次查看
vikmonti7804
Hi ,
  If I am able to install the HSE firmware successfully, how to verify this firmware is installed in the secure memory correctly or successfully in the memory.
please let me know any method or check the memory?
Thank You
27,180 次查看
lukaszadrapa
You can check bit 0 in HSE GPR status register at 0x4039C028. If it is '1', it means that "HSE FW is present and SBAF Booted HSE Firmware".
You can find this in HSE_B Firmware Reference Manual rev 2.2.
Lukas
27,147 次查看
vikmonti7804
Hi Lucas ,
         I am not able to see this register in any peripheral window in S32DS, Can you please tell me exactly where i can see.
i can see the value 0xC1010000 at 0x4039C028 address.
27,135 次查看
lukaszadrapa
I don't think the HSE GPR is defined in peripheral structure, so it's necessary to check the memory directly. If you can see 0xC1010000 at 0x4039C028, the HSE FW is obviously not installed.
Is the HSE feature flash at 0x1B000000 programmed?
And one more thing - I can remember that that if you use "without IVT" method to install the firmware, there can't be valid IVT in the flash. Otherwise it does not work. If you loaded the pink/bin file together with some project, it's necessary to remove the IVT. Or "with IVT" method must be used.
Lukas
27,128 次查看
vikmonti7804
     I am just following the example code given for the s32k344, so i created same project for the s32k312 and imported the binary from the linker file, i see the 0xAABBCCDD  at 0x1B000000 location in memory window, what can be the problem. Every thing is same as per the example code as s32k344, only i changed the memory location in linker file. Can you please help on urgent basis, or can we connect online for debugging purpose on small call.
please find the snippet of the linker file and program.
vikmonti7804_0-1708531086237.pngvikmonti7804_1-1708531115954.pngvikmonti7804_2-1708531147534.png
9,734 次查看
Sanjana_k
#hello@vikmonti7804  did u get the solution for the above problem that is programm getting stuck at below ..please hep us
if yes please please help us we are trying alot still we are not getting what to do ?
Thank u
27,082 次查看
vikmonti7804
          kindly check the image attached, the header of the AB_Swap is also there in the memory so it means the firmware is flashed in the memory, the utest area has value AABBCCDDDDCCBBAA it means utest is enabled, the HSE GPR register bit 0 is not getting set, i dont know why? it means after reset the SBAF is not installing the hse firmware in secure memory region.
kindly help on urgent basis.
标记 (1)
27,078 次查看
lukaszadrapa
Hi @vikmonti7804
could you please share that project? I will test it on my side.
Lukas
27,072 次查看
vikmonti7804
Please find the project.
26,980 次查看
lukaszadrapa
Small problem on my side - I found that I already have firmware 2.6.0 on both my boards and it can't be erased (this feature was added in version 2.40.0). I will get brand new board on Monday and I will test it.
I checked the project anyway and I can see nothing wrong. I would just not program the HSE feature flag unconditionally after each reset.
I will let you know the results of my test on Monday.
Lukas
26,889 次查看
vikmonti7804
Hi Lucas
   Any update on this?
标记 (1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1808863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%AE%89%E8%A3%85%20HSE%20%E5%9B%BA%E4%BB%B6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1808863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%AE%89%E8%A3%85%20HSE%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E4%BD%86%E6%98%AF%E7%BB%99%E5%87%BA%E7%9A%84%E4%BB%A3%E7%A0%81%E5%8C%85%E5%87%BA%E7%8E%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%20C%3A%5CNXP%5CS32K3_HSE_DemoExamples_1_0_0%5CS32K3_HSE_DemoExamples%5CDevice_Configuration%5CS32K344_HSE_FW_INSTALL.%3C%2FP%3E%3CP%3E%E9%94%99%E8%AF%AF%3C%2FP%3E%3CP%3Emake%EF%BC%9A***%20%5Bmakefile%3A38%3A%20S32K312_HSE_FW_INSTALL.elf%5D%20%E9%94%99%E8%AF%AF%201%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E7%94%A8%E4%BA%8E%E5%AE%89%E8%A3%85%20HSE%20fw%20%E7%9A%84%20s32k312%20%E5%9B%BA%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200576%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E4%BB%AC%E5%A5%BD%EF%BC%8C%E4%BD%A0%E4%BB%AC%E8%83%BD%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E8%83%BD%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172865%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%89%E4%BA%BA%E8%83%BD%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%8F%91%E5%B8%83%E4%B8%8E%E6%82%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%E6%88%91%E5%90%8C%E6%97%B6%E5%B0%9D%E8%AF%95%E4%BA%86%20full_mem%20%E5%92%8C%20ab_swap%E3%80%82%E9%83%BD%E5%A4%B1%E8%B4%A5%E4%BA%86%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%88%91%E6%83%B3%E6%88%91%E6%89%BE%E5%88%B0%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E4%BA%86%E3%80%82%E5%9C%A8%E5%86%85%E5%AD%98%E8%A7%86%E5%9B%BE%E4%B8%AD%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E9%80%89%E6%8B%A9%20%22%20%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%20%22%20%E6%88%96%20%22%20%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E6%95%B4%E6%95%B0%20%22%EF%BC%8C%E5%88%99%E5%AD%97%E8%8A%82%E9%A1%BA%E5%BA%8F%E5%B0%86%E7%9B%B8%E5%8F%8D%E3%80%82%E7%99%BB%E8%AE%B0%E5%86%8C%E6%98%AF%E4%B8%BA%E6%88%91%E8%AE%BE%E7%BD%AE%E7%9A%84%EF%BC%8C%E4%BD%86%E8%BF%99%E4%BA%9B%E8%A7%82%E7%82%B9%E8%AE%A9%E6%88%91%E5%9B%B0%E6%83%91%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3EHSE_B%20%E5%9B%BA%E4%BB%B6%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%9A%84%20%22%203.3.1%20MU%20%E5%9C%A8%20AB_SWAP%20%E9%85%8D%E7%BD%AE%E4%B8%AD%E6%8C%89%E4%B8%BB%E6%9C%BA%E5%88%86%E5%88%97%E7%9A%84%E5%AE%89%E8%A3%85%E6%AD%A5%E9%AA%A4%20%22%20%E7%AB%A0%E8%8A%82%E4%BB%8E%E4%BB%A5%E4%B8%8B%E5%87%A0%E8%A1%8C%E5%BC%80%E5%A7%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%22%20%E5%9C%A8%E5%AF%84%E5%AD%98%E5%99%A8%20DCMRWP1%EF%BC%880x402AC400%EF%BC%8C%5B24%3A31%20%E4%BD%8D%5D%EF%BC%89%E4%B8%8A%E5%86%99%E5%85%A5%200xA5%EF%BC%8C%E7%84%B6%E5%90%8E%E8%BF%9B%E8%A1%8C%E5%8A%9F%E8%83%BD%20RESET%E3%80%82%E8%BF%99%E5%B0%86%E8%AE%BE%E7%BD%AE%20HSE%20GPR%20(0x4039C028)%20%E4%B8%AD%E7%9A%84%E4%BD%8D%201%EF%BC%8C%E8%A1%A8%E6%98%8E%20SBAF%20%E5%B7%B2%E6%BF%80%E6%B4%BB%20MU0%20%E8%BF%9B%E8%A1%8C%E5%AE%89%E8%A3%85%E3%80%82%22%3C%2FP%3E%3CP%3E%E4%BD%86%E6%9C%AC%E4%B8%BB%E9%A2%98%E4%B8%AD%E5%B9%B6%E6%9C%AA%E6%8F%90%E5%8F%8A%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%BF%85%E9%A1%BB%E8%AE%BE%E7%BD%AE%20DCMRWP1%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E8%BF%98%E6%98%AF%E5%9C%A8%E7%A4%BA%E4%BE%8B%E4%B8%AD%E4%BB%A5%E6%9F%90%E7%A7%8D%E6%96%B9%E5%BC%8F%E5%AE%9E%E7%8E%B0%E4%BA%86%E8%AE%BE%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3ESandor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%BF%99%E9%87%8C%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B0%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1973145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%97%AE%E9%A2%98%E8%A7%A3%E5%86%B3%E4%BA%86%E5%90%97%EF%BC%9F%E8%BF%99%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E9%80%A0%E6%88%90%E7%9A%84%EF%BC%9F%E6%88%91%E8%BF%99%E8%BE%B9%E4%B9%9F%E6%98%AF%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%A0%E6%B3%95%E8%AE%BE%E7%BD%AE%221%22%20%EF%BC%8C%E6%82%A8%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1910374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1910374%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%8C%89%E7%85%A7%E4%BD%A0%E6%8F%90%E5%88%B0%E7%9A%84%E6%96%B9%E6%B3%95%E8%BF%9B%E8%A1%8C%E4%BA%86%20HSE%20FW%20%E6%B8%85%E9%99%A4%EF%BC%8C%E7%BB%93%E6%9E%9C%E6%88%90%E5%8A%9F%E4%BA%86%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%B0%86%E5%85%B6%E5%AE%89%E8%A3%85%E5%9B%9E%E5%8E%BB%E3%80%82%E5%A6%82%E4%BD%95%E9%87%8D%E6%96%B0%E5%AE%89%E8%A3%85%20HSE%20FW%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%8F%B6%E7%89%B9%E9%87%91%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1856957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1856957%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%85%B3%E4%BA%8E%E8%AE%A8%E8%AE%BA%EF%BC%8C%E6%88%91%E4%B9%9F%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%9B%B4%E6%8D%A2%20S32K344%20%E6%9D%BF%E3%80%82%E6%88%91%E6%8C%89%E7%85%A7%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%93%8D%E4%BD%9C%EF%BC%9A%3CBR%20%2F%3E1)%20%E4%B8%8B%E8%BD%BD%20S32K3_HSE_DemoExamples_1_0_0%EF%BC%8C%E8%BF%9B%E8%A1%8C%20a%2Fb%20%E4%BA%A4%E6%8D%A2%EF%BC%8C%E9%80%9A%E8%BF%87%E6%B7%BB%E5%8A%A0%20.pink%20%E6%9D%A5%E6%9B%B4%E6%94%B9%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E3%80%82%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E2)%20%E6%88%91%E7%BC%96%E8%AF%91%E4%BA%86%E9%A1%B9%E7%9B%AE%E5%B9%B6%E8%BF%90%E8%A1%8C%E4%BA%86%E5%AE%83%EF%BC%8C%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E4%BB%A3%E7%A0%81%E4%BF%9D%E6%8C%81%E4%BB%A5%E4%B8%8B%E6%AD%A5%E9%AA%A4%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20%E5%AE%89%E8%A3%85%E5%90%8E%E7%AD%89%E5%BE%85%20HSE%20%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%E4%BD%8D%EF%BC%89*%2F%20while%20((HSE_STATUS_INIT_OK%20%26amp%3B%20HSE_mu_gethseStatus%20(0))%20%3D%3D%200)%20%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3EginstallHSEFWTEST%20%3D%20FW_NOT_INSTALLED%3B%20%3CBR%20%2F%3E%20%2F*%20%E8%AF%B7%20RESET%20%E4%BB%A5%E5%85%81%E8%AE%B8%E5%AE%89%E8%A3%85%20*%2F%3CBR%20%2F%3E%7D%20%3CBR%20%2F%3E%20%3CBR%20%2F%3E%203)%20%E6%88%91%E8%AF%95%E7%9D%80%E6%97%A2%E6%8C%89%E4%B8%8B%E6%9D%BF%E4%B8%8A%E7%9A%84%20RST%20%E6%8C%89%E9%92%AE%EF%BC%8C%3CBR%20%2F%3E%E5%8F%88%E6%83%B3%E6%8A%8A%E5%AE%83%E5%85%B3%E6%8E%89%E7%84%B6%E5%90%8E%E5%86%8D%E6%89%93%E5%BC%80%EF%BC%8C%E4%BD%86%E6%98%BE%E7%84%B6%E5%AE%83%E5%B9%B6%E6%B2%A1%E6%9C%89%E6%94%B9%E5%8F%98%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%BF%98%E4%BA%86%E4%B8%80%E4%B8%AA%E6%AD%A5%E9%AA%A4%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1818321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1818321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E4%BB%80%E4%B9%88%E6%97%B6%E5%80%99%E8%83%BD%E8%81%94%E7%B3%BB%E4%B8%8A%EF%BC%8C%E8%AF%B7%E6%8F%90%E4%BE%9B%E8%81%94%E7%B3%BB%E7%9A%84%E6%97%B6%E9%97%B4%E5%92%8C%E9%93%BE%E6%8E%A5%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817457%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%8A%E5%A4%A9%E6%B2%A1%E6%97%B6%E9%97%B4%E4%BA%86%EF%BC%8C%E4%BD%86%E6%98%8E%E5%A4%A9%E6%97%A9%E4%B8%8A%E5%BA%94%E8%AF%A5%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%98%8E%E5%A4%A9%E4%B8%80%E6%97%A9%E6%9C%89%E7%A9%BA%E5%B0%B1%E4%BC%9A%E9%80%9A%E7%9F%A5%E4%BD%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%96%E8%80%85%E4%BD%A0%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%88%B6%E4%BD%9C%E8%B0%83%E8%AF%95%E8%AE%BE%E7%BD%AE%E5%92%8C%E8%B0%83%E8%AF%95%E5%9B%BA%E4%BB%B6%E7%9A%84%E8%A7%86%E9%A2%91%EF%BC%8C%E7%84%B6%E5%90%8E%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817449%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%EF%BC%8C%E6%88%91%E8%AF%95%E8%BF%87%E4%BA%86%EF%BC%8C%E4%BD%86%E8%BF%98%E6%98%AF%E4%B8%80%E6%A0%B7%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E5%8F%AF%E8%83%BD%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%88%91%E4%BB%AC%E8%83%BD%E5%9C%A8%2010%20%E5%88%86%E9%92%9F%E5%86%85%E9%80%9A%E8%AF%9D%E5%90%97%EF%BC%9F%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E5%88%86%E4%BA%AB%E9%82%80%E8%AF%B7%E5%87%BD%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%88%86%E4%BA%AB%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E6%9C%89%E4%B8%80%E4%B8%AA%E7%B2%BE%E7%81%B5%E6%96%87%E4%BB%B6%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2FS32K%2F32120%2F1%2FHSE_Install_FW.zip%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fpwmxy87654%2Fattachments%2Fpwmxy87654%2FS32K%2F32120%2F1%2FHSE_Install_FW.zip%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%86%E5%B0%8F%E7%B2%BE%E7%81%B5%E4%B8%8E%E6%88%91%E4%BB%8A%E5%A4%A9%E6%B5%8B%E8%AF%95%E7%9A%84%E5%BD%93%E5%89%8D%E9%A1%B9%E7%9B%AE%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%AF%94%E8%BE%83%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%AE%8C%E5%85%A8%E7%9B%B8%E5%90%8C%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9A%84%E8%8A%AF%E7%89%87%E6%98%AF%E5%85%A8%E6%96%B0%E7%9A%84%EF%BC%8C%E6%89%80%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%BA%86%E9%BB%98%E8%AE%A4%E7%9A%84%20hse_disabled%20%E7%89%88%E6%9C%AC%E3%80%82%E5%A6%82%E6%9E%9C%E5%B7%B2%E5%90%AF%E7%94%A8%20HSE%20%E5%8A%9F%E8%83%BD%E9%97%AA%E5%AD%98%EF%BC%8C%E4%BD%86%E5%B0%9A%E6%9C%AA%E5%AE%89%E8%A3%85%20HSE%20FW%EF%BC%8C%E5%88%99%E5%BA%94%E4%BD%BF%E7%94%A8%20hse_enabled%E3%80%82%E4%B8%80%E6%97%A6%E5%AE%89%E8%A3%85%E4%BA%86%20AB%20swap%EF%BC%8C%E5%B0%B1%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20ab_swap%E3%80%82%E4%BD%86%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%8D%E5%8F%AF%E8%83%BD%E5%87%BA%E9%94%99%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%A6%82%E6%9E%9C%20Pemicro%20%E6%97%A0%E6%B3%95%E6%93%A6%E9%99%A4%E6%88%96%E7%BC%96%E7%A8%8B%E9%97%AA%E5%AD%98%EF%BC%8C%E5%AE%83%E5%BA%94%E8%AF%A5%E4%BC%9A%E6%98%BE%E7%A4%BA%E4%B8%80%E4%BA%9B%E9%94%99%E8%AF%AF%E3%80%82%E5%8D%B3%E4%BD%BF%E5%9C%A8%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E7%BC%96%E7%A8%8B%E6%97%B6%E4%BD%BF%E7%94%A8%20hse_disabled%EF%BC%8C%E5%AE%83%E5%8F%AF%E8%83%BD%E4%BB%8D%E7%84%B6%E6%9C%89%E6%95%88%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E5%B0%86%E5%9B%BA%E4%BB%B6%E4%B9%9F%E5%AE%89%E8%A3%85%E5%88%B0%E8%A2%AB%E5%8A%A8%E6%A8%A1%E5%9D%97%EF%BC%8C%E9%9C%80%E8%A6%81%E8%BF%9B%E8%A1%8C%E4%B8%A4%E6%AC%A1%20RESET%EF%BC%88%E6%88%96%E8%80%85%E4%B8%A4%E6%AC%A1%E9%80%9A%E7%94%B5%EF%BC%8C%E6%B2%A1%E5%85%B3%E7%B3%BB%EF%BC%89%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709119050485.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265542i88AD2B7FA35E3A27%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709119050485.png%22%20alt%3D%22lukaszadrapa_0-1709119050485.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%81%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%88%86%E4%BA%AB%E6%82%A8%E7%9A%84%20.elf%E9%94%89%E5%88%80%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BD%A0%E9%87%8D%E5%90%AF%E6%9D%BF%202%20%E6%AC%A1%EF%BC%8C%E6%98%AF%E5%BF%85%E9%A1%BB%20RESET%202%20%E6%AC%A1%E8%BF%98%E6%98%AF%E5%BC%80%E6%9C%BA%202%20%E6%AC%A1%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%97%AA%E5%AD%98%E6%97%B6%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%8C%E6%98%AF%E9%AB%98%E7%BA%A7%E8%AE%BE%E7%BD%AE%E4%B8%AD%E7%9A%84%20ab_sawp.arp%20%E8%BF%98%E6%98%AF%20hse_enabled.arp%EF%BC%9F%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%94%A8%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%85%A8%E6%96%B0%E7%9A%84%E6%9D%BF%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%8E%E4%B9%8B%E5%89%8D%E5%8F%91%E7%BB%99%E4%BD%A0%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%AE%8C%E5%85%A8%E4%B8%80%E6%A0%B7%E3%80%82%E6%88%91%E9%80%9A%E8%BF%87%E5%86%85%E7%BD%AE%E7%9A%84%20Pemicro%20OpenSDA%20%E6%8E%A5%E5%8F%A3%E9%80%9A%E8%BF%87%20S32DS%20%E5%8A%A0%E8%BD%BD%E4%BA%86%E9%A1%B9%E7%9B%AE%EF%BC%8C%E8%BF%90%E8%A1%8C%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%AF%B9%E7%94%B5%E8%B7%AF%E6%9D%BF%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%B8%A4%E6%AC%A1%E9%80%9A%E7%94%B5%EF%BC%8C%E7%84%B6%E5%90%8E%E6%88%91%E5%B0%B1%E8%83%BD%E7%9C%8B%E5%88%B0%20HSE%20GPR%20%E4%B8%AD%E7%9A%84%E4%BD%8D%E5%B7%B2%E7%BB%8F%E8%AE%BE%E7%BD%AE%E5%A5%BD%E4%BA%86%EF%BC%8C%E5%9B%BA%E4%BB%B6%E4%B9%9F%E5%AE%89%E8%A3%85%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AE%89%E8%A3%85%20HSE%20FW%20%E5%90%8E%EF%BC%8C%E9%9C%80%E8%A6%81%E5%9C%A8%20Pemicro%20%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%9B%B4%E6%94%B9%E9%97%AA%E5%AD%98%E7%AE%97%E6%B3%95%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709113020433.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265527iB7ECE6479C2728D4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709113020433.png%22%20alt%3D%22lukaszadrapa_0-1709113020433.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E5%9B%A0%E4%B8%BA%E5%BD%93%E5%90%AF%E7%94%A8%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E6%88%96%E5%AE%89%E8%A3%85%20AB%20swap%20FW%20%E6%97%B6%EF%BC%8C%E9%97%AA%E5%AD%98%E7%9A%84%E6%9F%90%E4%BA%9B%E9%83%A8%E5%88%86%E4%BC%9A%E8%A2%AB%E5%88%86%E9%85%8D%E7%BB%99%20HSE%E3%80%82%E9%9C%80%E8%A6%81%E5%90%91%20Pemicro%20%E9%80%9A%E6%8A%A5%E6%AD%A4%E4%BA%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E4%B8%8E%E6%82%A8%E5%85%B1%E4%BA%AB%E7%9A%84%E7%9B%B8%E5%90%8C%E5%9B%BA%E4%BB%B6%E9%A1%B9%E7%9B%AE%E7%9A%84%E4%B8%8D%E5%90%8C%E6%9D%BF%EF%BC%8C%E4%BD%86%E7%BB%93%E6%9E%9C%E4%B8%8E%E4%B9%8B%E5%89%8D%E7%9B%B8%E5%90%8C%E3%80%82HSE%20GPR%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E6%9C%80%E5%90%8E%E4%B8%80%E4%BD%8D%E6%9C%AA%E8%A2%AB%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E4%BD%BF%E7%94%A8%20PE%20Micro%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9B%E8%A1%8C%E5%B0%9D%E8%AF%95%EF%BC%8C%E6%89%BE%E5%87%BA%E9%97%AE%E9%A2%98%E7%9A%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%BF%99%E9%87%8C%E6%B2%A1%E6%9C%89%E5%8A%B3%E7%89%B9%E5%B7%B4%E8%B5%AB%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E6%9D%BF%E5%88%86%E4%BA%AB%E5%86%85%E5%AD%98%E7%9A%84%E5%9B%BE%E7%89%87%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1709101778843.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265454i8351747C6E419CCD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1709101778843.png%22%20alt%3D%22vikmonti7804_0-1709101778843.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1709101788067.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265455iA1255ADD2EB4FAF8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_1-1709101788067.png%22%20alt%3D%22vikmonti7804_1-1709101788067.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1709101802879.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265456iF2433A8B8FFF8C54%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_2-1709101802879.png%22%20alt%3D%22vikmonti7804_2-1709101802879.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%E6%88%91%E6%B2%A1%E6%9C%89%E8%B0%83%E8%AF%95%E5%99%A8%20PE%20micro%E3%80%82%E8%BF%99%E7%A7%8D%20trace32%20%E7%94%B5%E6%BA%90%E8%A7%86%E5%9B%BE%E6%98%AF%E5%90%A6%E9%80%82%E7%94%A8%E4%BA%8E%20PE%20micro%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%9C%A8%3CSPAN%3E%E5%B8%A6%E6%9C%89%20PE%20micro%20%E5%92%8C%20S32D%20%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%E9%80%9A%E8%BF%87%20MU%20%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E6%9C%8D%E5%8A%A1%EF%BC%9F%E6%9C%89%E4%BB%BB%E4%BD%95%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%20S32DS%20%E6%93%A6%E9%99%A4%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%9F%20%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%88%96%E8%80%85%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%20API%20FLASH_EraseBlock(dst)%3B%20%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816382%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%96%B0%E5%8A%9F%E8%83%BD%EF%BC%8C%E6%88%91%E5%9C%A8%20RTD%20%E6%88%96%20HSE%20DEMO%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E9%83%BD%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E7%9B%B8%E5%85%B3%E7%9A%84%20API%E3%80%82%E6%89%80%E4%BB%A5%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E6%9E%81%E7%AE%80%E4%B8%BB%E4%B9%89%E9%80%89%E9%A1%B9%EF%BC%8C%E6%88%91%E5%8F%AA%E6%98%AF%E9%80%9A%E8%BF%87%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%E7%9A%84MU%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E4%BA%86%E6%9C%8D%E5%8A%A1%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%20API%20%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E6%9C%8D%E5%8A%A1%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%0A%3CP%3Ec%3A%5CNXP%5CHSE_FW_S32K312_0_2_40_0%5Cdocs%5CS32K312_HSE_Service_API_Reference_Manual.pdf%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1709023598929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265258i86AB0A9FB93402DB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1709023598929.png%22%20alt%3D%22lukaszadrapa_0-1709023598929.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_1-1709023606522.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265259i11E1CBCABDAB8DF6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_1-1709023606522.png%22%20alt%3D%22lukaszadrapa_1-1709023606522.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%9C%8D%E5%8A%A1%20ID%20%E6%98%AF%200x57%EF%BC%8C%E4%B8%8D%E9%9C%80%E8%A6%81%E4%BB%BB%E4%BD%95%E5%8F%82%E6%95%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8F%AA%E9%9C%80%E5%B0%86%200x57%20%E5%86%99%E5%85%A5%20RAM%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%20RAM%20%E5%AD%97%E7%9A%84%E5%9C%B0%E5%9D%80%E5%86%99%E5%85%A5%E4%BF%A1%E6%81%AF%E5%8D%95%E5%85%83%20MU_0%EF%BC%8C%E5%AF%84%E5%AD%98%E5%99%A8%20TR%5B1%5D%E3%80%82%E4%BB%85%E6%AD%A4%E8%80%8C%E5%B7%B2%E3%80%82%E7%84%B6%E5%90%8E%E6%82%A8%E5%B0%86%E5%9C%A8%20RR%5B1%5D%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E5%93%8D%E5%BA%94%E3%80%82%E5%A6%82%E6%9E%9C%E5%B7%B2%E5%AE%89%E8%A3%85%20HSE%20FW%EF%BC%8C%E5%88%99%E5%BA%94%E5%BE%97%E5%88%B0%20HSE_SRV_RSP_OK%EF%BC%8C%E5%85%B6%E5%80%BC%E4%B8%BA%200x55A5AA33%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%88%91%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%E7%9A%84%E6%98%BE%E7%A4%BA%E6%95%88%E6%9E%9C%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_2-1709023848154.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265263i93C8A450B5ABE75B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_2-1709023848154.png%22%20alt%3D%22lukaszadrapa_2-1709023848154.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816209%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%AF%95%E5%9B%BE%E4%BD%BF%E7%94%A8%20FLASH_EraseBlock((uint32_t*)HSE_SRV_ID_ERASE_FW)%3B%EF%BC%8C%E4%BD%86%E5%AE%83%E8%BF%9B%E5%85%A5%E4%BA%86%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E8%A7%A3%E9%87%8A%E6%B8%85%E9%99%A4%E5%86%85%E5%AD%98%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%20%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%B8%85%E9%99%A4%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E5%BA%94%E8%AF%A5%E5%9C%A8%20linker%20%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AF%B9%20hse%20fw%20%E6%96%87%E4%BB%B6%E7%9A%84%E5%AF%BC%E5%85%A5%E8%BF%9B%E8%A1%8C%E6%B3%A8%E9%87%8A%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%AE%9E%E7%8E%B0%EF%BC%8C%E8%AF%B7%E8%A7%A3%E9%87%8A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1816190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1816190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%E6%82%A8%E4%BD%BF%E7%94%A8%3CSPAN%3EHSE_SRV_ID_ERASE_FW%3C%2FSPAN%3E%E6%93%A6%E9%99%A4%E6%8E%A7%E5%88%B6%E5%99%A8%E6%97%B6%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%20api%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815600%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%99%84%E4%B8%8A%E6%95%B4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815588%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E8%BF%87%E6%88%91%E4%B8%8E%E6%82%A8%E5%88%86%E4%BA%AB%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%AF%B7%E4%B8%8E%E6%88%91%E5%88%86%E4%BA%AB%E4%BD%A0%E4%BB%AC%E7%9A%84%E4%B8%BB%E8%A6%81%E8%AE%A1%E5%88%92%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815582%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%E8%AF%B7%E4%BB%8B%E7%BB%8D%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%E4%B8%BB%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BA%AB%E4%B8%8A%E5%8F%AA%E6%9C%89%E4%B8%80%E5%9D%97%E6%A3%8B%E7%9B%98%E8%80%8C%E4%B8%94%E6%98%AF%E6%96%B0%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815563%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%9C%89%E4%BA%86%E6%96%B0%E8%91%A3%E4%BA%8B%E4%BC%9A%E3%80%82%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708948550506.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F265036i6562E61CB478184D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1708948550506.png%22%20alt%3D%22lukaszadrapa_0-1708948550506.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E6%88%90%E5%8A%9F%E5%AE%89%E8%A3%85%E4%BA%86%E5%9B%BA%E4%BB%B6%E3%80%82%E6%88%91%E5%88%9A%E5%88%9A%E5%8F%96%E6%B6%88%E4%BA%86%E5%AF%B9%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E7%9A%84%E6%A3%80%E6%9F%A5%E3%80%82%E8%BF%99%E6%98%AF%E6%88%91%E5%81%9A%E7%9A%84%E5%94%AF%E4%B8%80%E6%94%B9%E5%8F%98%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20HSE_SRV_ID_ERASE_FW%20%E6%9C%8D%E5%8A%A1%E6%88%90%E5%8A%9F%E6%93%A6%E9%99%A4%E5%9B%BA%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%98%E6%98%AF%E4%B8%8D%E6%98%8E%E7%99%BD%E4%B8%BA%E4%BB%80%E4%B9%88%E5%9C%A8%E4%BD%A0%E9%82%A3%E8%BE%B9%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E4%BD%A0%E8%BF%98%E6%9C%89%E6%9B%B4%E5%A4%9A%E7%9A%84%E6%9D%BF%E5%90%97%EF%BC%9F%E5%AE%83%E4%BB%AC%E9%83%BD%E8%A1%A8%E7%8E%B0%E5%87%BA%E5%90%8C%E6%A0%B7%E7%9A%84%E8%A1%8C%E4%B8%BA%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1815474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1815474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%3C%2FP%3E%3CP%3E%20%20%20%E6%9C%89%E4%BB%80%E4%B9%88%E6%96%B0%E8%BF%9B%E5%B1%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1814467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1814467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%9C%A8%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E4%B8%8A%E8%AE%BE%E7%BD%AE%E6%9D%A1%E4%BB%B6%E7%9A%84%E5%9B%BA%E4%BB%B6%EF%BC%8C%E4%BD%86%20hse%20gpr%20resgiter%20%E8%BF%98%E6%98%AF%E6%B2%A1%E6%9C%89%E6%9B%B4%E6%96%B0%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708676777819.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264721iA4F29D438A1284BD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1708676777819.png%22%20alt%3D%22vikmonti7804_0-1708676777819.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1814437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1814437%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%BF%99%E8%BE%B9%E6%9C%89%E4%B8%AA%E5%B0%8F%E9%97%AE%E9%A2%98%E2%80%94%E2%80%94%E6%88%91%E5%8F%91%E7%8E%B0%E6%88%91%E7%9A%84%E4%B8%A4%E4%B8%AA%E6%9D%BF%E4%B8%8A%E9%83%BD%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%202.6.0%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E8%80%8C%E4%B8%94%E6%97%A0%E6%B3%95%E5%88%A0%E9%99%A4%EF%BC%88%E8%BF%99%E4%B8%AA%E5%8A%9F%E8%83%BD%E6%98%AF%E5%9C%A8%202.40.0%20%E7%89%88%E6%9C%AC%E4%B8%AD%E6%B7%BB%E5%8A%A0%E7%9A%84%EF%BC%89%E3%80%82%E6%88%91%E5%B0%86%E5%9C%A8%E6%98%9F%E6%9C%9F%E4%B8%80%E8%8E%B7%E5%BE%97%E5%85%A8%E6%96%B0%E7%9A%84%E6%9D%BF%EF%BC%8C%E6%88%91%E4%BC%9A%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%98%E6%98%AF%E6%A3%80%E6%9F%A5%E4%BA%86%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%8F%AA%E6%98%AF%E4%B8%8D%E4%BC%9A%E5%9C%A8%E6%AF%8F%E6%AC%A1%20RESET%20%E5%90%8E%E6%97%A0%E6%9D%A1%E4%BB%B6%E5%9C%B0%E5%AF%B9%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%9C%A8%E5%91%A8%E4%B8%80%E5%91%8A%E8%AF%89%E4%BD%A0%E4%BB%AC%E6%88%91%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E8%B0%83%E8%AF%95%E5%B9%B6%E6%A3%80%E6%9F%A5%E4%B8%BA%E4%BB%80%E4%B9%88%20hse%20gpr%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%BD%8D%E6%B2%A1%E6%9C%89%E8%A2%AB%E8%AE%BE%E7%BD%AE%EF%BC%8C%E8%80%8C%E4%B8%94%20sbaf%20%E6%B2%A1%E6%9C%89%E5%AE%8C%E6%88%90%E5%AE%89%E8%A3%85%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813763%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%9F%A5%E6%89%BE%E8%AF%A5%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224860%22%20target%3D%22_blank%22%3E%40vikmonti7804%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E8%AF%A5%E9%A1%B9%E7%9B%AE%EF%BC%9F%E6%88%91%E4%BC%9A%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1813711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1813711%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E9%9A%8F%E9%99%84%E7%9A%84%E5%9B%BE%E7%89%87%EF%BC%8CAB_Swap%20%E7%9A%84%E6%A0%87%E5%A4%B4%E4%B9%9F%E5%9C%A8%E5%86%85%E5%AD%98%E4%B8%AD%E6%89%80%E4%BB%A5%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%9B%BA%E4%BB%B6%E5%B7%B2%E5%9C%A8%E5%86%85%E5%AD%98%E4%B8%AD%E9%97%AA%E5%AD%98%EF%BC%8Cutest%20%E5%8C%BA%E5%9F%9F%E7%9A%84%E5%80%BC%E4%B8%BA%20AABBCCDDDDCBBAA%20%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20utest%20%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8CHSE%20GPR%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%BD%8D%200%20%E6%9C%AA%E8%AE%BE%E7%BD%AE%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%EF%BC%9F%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20RESET%20%E5%90%8E%20SBAF%20%E6%B2%A1%E6%9C%89%E5%B0%86%20hse%20%E5%9B%BA%E4%BB%B6%E5%AE%89%E8%A3%85%E5%9C%A8%E5%AE%89%E5%85%A8%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E7%B4%A7%E6%80%A5%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708596640252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264536i89A663620CCD852C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1708596640252.png%22%20alt%3D%22vikmonti7804_0-1708596640252.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812942%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AA%E6%98%AF%E5%9C%A8%E9%81%B5%E5%BE%AA%20s32k344%20%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%B8%BA%20s32k312%20%E5%88%9B%E5%BB%BA%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B9%B6%E4%BB%8E%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E4%B8%AD%E5%AF%BC%E5%85%A5%E4%BA%86%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E5%9C%A8%E5%86%85%E5%AD%98%E7%AA%97%E5%8F%A3%E7%9A%84%200x1b000000%20%E4%BD%8D%E7%BD%AE%E7%9C%8B%E5%88%B0%200xaabbccdd%EF%BC%8C%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%E3%80%82%E4%B8%80%E5%88%87%E9%83%BD%E4%B8%8E%20s32k344%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E7%9B%B8%E5%90%8C%EF%BC%8C%E5%8F%AA%E6%98%AF%E6%88%91%E6%9B%B4%E6%94%B9%E4%BA%86%E9%93%BE%E6%8E%A5%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%E5%86%85%E5%AD%98%E4%BD%8D%E7%BD%AE%E3%80%82%E8%AF%B7%E6%82%A8%E6%8F%90%E4%BE%9B%E7%B4%A7%E6%80%A5%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%96%E8%80%85%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%B0%8F%E5%9E%8B%E7%94%B5%E8%AF%9D%E8%BF%9B%E8%A1%8C%E5%9C%A8%E7%BA%BF%E8%B0%83%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E5%92%8C%E7%A8%8B%E5%BA%8F%E7%9A%84%E7%89%87%E6%AE%B5%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_0-1708531086237.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264315iE0EDA2AD10EFECE3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_0-1708531086237.png%22%20alt%3D%22vikmonti7804_0-1708531086237.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_1-1708531115954.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264316iFEF84EEEF1A434E6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_1-1708531115954.png%22%20alt%3D%22vikmonti7804_1-1708531115954.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vikmonti7804_2-1708531147534.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F264317iF134C0887931C929%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vikmonti7804_2-1708531147534.png%22%20alt%3D%22vikmonti7804_2-1708531147534.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E5%A4%96%E8%AE%BE%E7%BB%93%E6%9E%84%E4%B8%AD%E6%B2%A1%E6%9C%89%E5%AE%9A%E4%B9%89%20HSE%20GPR%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%9C%89%E5%BF%85%E8%A6%81%E7%9B%B4%E6%8E%A5%E6%A3%80%E6%9F%A5%E5%86%85%E5%AD%98%E3%80%82%E5%A6%82%E6%9E%9C%E5%9C%A8%200x4039C028%20%E5%A4%84%E7%9C%8B%E5%88%B0%200xC1010000%EF%BC%8C%E5%88%99%E6%98%BE%E7%84%B6%E6%B2%A1%E6%9C%89%E5%AE%89%E8%A3%85%20HSE%20FW%E3%80%82%3C%2FP%3E%0A%3CP%3E0x1B000000%20%E7%9A%84%20HSE%20%E5%8A%9F%E8%83%BD%E9%97%AA%E5%AD%98%E6%98%AF%E5%90%A6%E5%B7%B2%E7%BC%96%E7%A8%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%BF%98%E6%9C%89%E4%B8%80%E4%BB%B6%E4%BA%8B--%E6%88%91%E8%AE%B0%E5%BE%97%E5%A6%82%E6%9E%9C%E4%BD%BF%E7%94%A8%22without%20IVT%22%20%E6%96%B9%E6%B3%95%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%EF%BC%8C%E9%97%AA%E5%AD%98%E4%B8%AD%E4%B8%8D%E5%8F%AF%E8%83%BD%E6%9C%89%E6%9C%89%E6%95%88%E7%9A%84%20IVT%E3%80%82%E5%90%A6%E5%88%99%EF%BC%8C%E5%AE%83%E5%B0%B1%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E7%B2%89%E8%89%B2%2Fbin%20%E6%96%87%E4%BB%B6%E4%B8%8E%E6%9F%90%E4%BA%9B%E9%A1%B9%E7%9B%AE%E4%B8%80%E8%B5%B7%E5%8A%A0%E8%BD%BD%EF%BC%8C%E5%88%99%E6%9C%89%E5%BF%85%E8%A6%81%E5%88%A0%E9%99%A4%20IVT%E3%80%82%E6%88%96%22%EF%BC%8C%E5%BF%85%E9%A1%BB%E4%BD%BF%E7%94%A8%20IVT%22%20%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812756%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%8D%A2%E5%8D%A1%E6%96%AF%20%E3%80%81%20%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%20S32DS%20%E7%9A%84%E4%BB%BB%E4%BD%95%E5%A4%96%E8%AE%BE%E7%AA%97%E5%8F%A3%E4%B8%AD%E7%9C%8B%E5%88%B0%E8%BF%99%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%3CSPAN%3E0x4039C028%20%E5%9C%B0%E5%9D%80%3C%2FSPAN%3E%E7%9C%8B%E5%88%B0%200xC1010000%20%E7%9A%84%E5%80%BC%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%20%20%20%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%BA%20s32k312%20%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%86%E5%9C%A8%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%BF%90%E8%A1%8C%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E5%AE%83%E7%9B%B4%E6%8E%A5%E8%B7%B3%E8%BD%AC%E5%88%B0%E9%BB%98%E8%AE%A4%E6%89%8B%E6%9F%84%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E8%BF%9B%E5%85%A5%E4%B8%BB%E7%95%8C%E9%9D%A2%EF%BC%8C%E8%AF%B7%E4%BD%A0%E4%BB%AC%E5%B8%AE%E5%8A%A9%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%B7%B2%E6%94%BE%E5%85%A5%E9%97%AA%E5%AD%98%E4%B8%AD%EF%BC%8C%E4%BD%86%E6%98%AF%20utest%20%E7%94%B1%E4%BA%8E%E6%B2%A1%E6%9C%89%E8%BF%9B%E5%85%A5%E4%B8%BB%E7%95%8C%E9%9D%A2%E8%80%8C%E6%9C%AA%E5%90%AF%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1812005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1812005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E6%A3%80%E6%9F%A5%20HSE%20GPR%20%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%200x4039C028%20%E4%B8%AD%E7%9A%84%E7%AC%AC%200%20%E4%BD%8D%E3%80%82%E5%A6%82%E6%9E%9C%E4%B8%BA%20%221%22%EF%BC%8C%E5%88%99%E8%A1%A8%E7%A4%BA%22HSE%20FW%20%E5%AD%98%E5%9C%A8%EF%BC%8CSBAF%20%E5%BC%95%E5%AF%BC%E7%9A%84%20HSE%20%E5%9B%BA%E4%BB%B6%22%20%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%9C%A8%20HSE_B%20%E5%9B%BA%E4%BB%B6%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E7%89%88%E6%9C%AC%202.2%20%E4%B8%AD%E6%89%BE%E5%88%B0%E8%BF%99%E4%B8%AA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1811847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1811847%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%20%20%E5%A6%82%E6%9E%9C%E6%88%91%E8%83%BD%E5%A4%9F%E6%88%90%E5%8A%9F%E5%AE%89%E8%A3%85%20HSE%20%E5%9B%BA%E4%BB%B6%EF%BC%8C%E5%A6%82%E4%BD%95%E9%AA%8C%E8%AF%81%E8%AF%A5%E5%9B%BA%E4%BB%B6%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E5%AE%89%E8%A3%85%E5%9C%A8%E5%AE%89%E5%85%A8%E5%AD%98%E5%82%A8%E5%99%A8%E4%B8%AD%E6%88%96%E6%88%90%E5%8A%9F%E5%AE%89%E8%A3%85%E5%9C%A8%E5%AD%98%E5%82%A8%E5%99%A8%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%A3%80%E6%9F%A5%E5%86%85%E5%AD%98%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1809755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1809755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9B%BA%E4%BB%B6%E4%BB%A5%E5%8A%A0%E5%AF%86%E5%BD%A2%E5%BC%8F%E4%BD%9C%E4%B8%BA%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E6%8F%90%E4%BE%9B%E3%80%82%E6%98%AF%E7%9A%84%EF%BC%8CHSE%20FW%20%E4%BB%A3%E7%A0%81%E5%8C%85%E4%BB%85%E5%8C%85%E5%90%AB%E4%BA%8C%E8%BF%9B%E5%88%B6%EF%BC%88%E7%B2%89%E8%89%B2%EF%BC%89%E6%96%87%E4%BB%B6%E5%92%8C%E7%9B%B8%E5%BA%94%E7%9A%84%20API%20%E6%A0%87%E5%A4%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%8A%B3%E7%89%B9%E5%B7%B4%E8%B5%AB%E7%94%A8%E6%88%B7%E8%BF%98%E5%8F%AF%E4%BD%BF%E7%94%A8%20HSE%20DEMOAPP%20%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%E5%B9%B6%E6%A3%80%E6%9F%A5%20HSE%20%E5%8A%9F%E8%83%BD%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1708065109693.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F263436i6D824F1E7A23ED65%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1708065109693.png%22%20alt%3D%22lukaszadrapa_0-1708065109693.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8C%E8%AF%A5%E6%BC%94%E7%A4%BA%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%E5%8A%B3%E7%89%B9%E5%B7%B4%E8%B5%AB%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%E5%AE%83%E4%B8%8D%E8%83%BD%E4%B8%8E%20Pemicro%20%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A3%E5%A6%82%E6%82%A8%E5%9C%A8%E4%B8%8A%E8%BF%B0%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E6%88%96%20HSE%20FW%20RM%20%E4%B8%AD%E7%9C%8B%E5%88%B0%E7%9A%84%E9%82%A3%E6%A0%B7%EF%BC%8C%E5%9B%BA%E4%BB%B6%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%AE%89%E8%A3%85%E6%88%96%E4%B8%8D%E4%BD%BF%E7%94%A8%20IVT%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%AE%89%E8%A3%85%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%B2%A1%E6%9C%89IVT%E7%9A%84%E5%AE%89%E8%A3%85%E6%AF%94%E8%BE%83%E5%AE%B9%E6%98%93%EF%BC%8C%E4%BD%86%E6%98%AF%E4%BD%A0%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E8%83%BD%E5%A4%9F%E5%B0%86%E5%8E%9F%E5%A7%8B%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%8A%A0%E8%BD%BD%E5%88%B0%E9%97%AA%E5%AD%98%E7%9A%84%E5%B7%A5%E5%85%B7%EF%BC%8C%E8%80%8CPemicro%E8%B0%83%E8%AF%95%E5%99%A8%E5%88%99%E4%B8%8D%E6%98%AF%E8%BF%99%E6%A0%B7%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%22%E4%B8%8E%20IVT%22%20%E6%96%B9%E6%B3%95%E6%9B%B4%E4%B8%BA%E6%96%B9%E4%BE%BF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E6%B2%A1%E6%9C%89%E4%B8%BA%E6%AF%8F%E4%B8%AA%E8%A1%8D%E7%94%9F%E7%A8%8B%E5%BA%8F%E6%8F%90%E4%BE%9B%20S32K344_HSE_FW_INSTALL%E3%80%82%E8%BF%99%E5%8F%AA%E6%98%AF%E4%B8%80%E4%B8%AA%E7%A4%BA%E4%BE%8B%EF%BC%8C%E7%94%A8%E6%88%B7%E5%8F%AF%E8%87%AA%E8%A1%8C%E5%88%9B%E5%BB%BA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%88%E6%AF%8F%E4%B8%AA%E5%AE%A2%E6%88%B7%E7%9A%84%E8%A6%81%E6%B1%82%E5%92%8C%E7%94%9F%E4%BA%A7%E5%B7%A5%E5%85%B7%2F%E8%83%BD%E5%8A%9B%E5%90%84%E4%B8%8D%E7%9B%B8%E5%90%8C%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9A%3CBR%20%2F%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%20S32%20Design%20Studio%20%E4%B8%AD%E7%9B%B4%E6%8E%A5%E4%B8%BA%20S32K312%20%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%E3%80%82%E7%84%B6%E5%90%8E%E5%A4%8D%E5%88%B6%20S32K344_HSE_FW_INSTALL%20%E4%B8%AD%E7%9A%84%E6%BA%90%E6%96%87%E4%BB%B6%EF%BC%8C%E6%9B%B4%E6%96%B0%20boot_header.c%20%E4%B8%AD%E7%9A%84%20HseFwHeader_StartAddress%E3%80%82%E7%84%B6%E5%90%8E%E4%BF%AE%E6%94%B9%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%20-%20%E4%BD%BF%E7%94%A8%20S32K344_HSE_FW_INSTALL%20%E4%B8%AD%E7%9A%84%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E4%BD%9C%E4%B8%BA%E6%A8%A1%E6%9D%BF%E3%80%82%E5%A6%82%E6%9E%9C%E6%8C%89%E7%85%A7%E6%88%91%E4%B9%8B%E5%89%8D%E7%9A%84%E5%BB%BA%E8%AE%AE%E9%98%85%E8%AF%BB%20readme.md%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%B8%80%E5%AE%9A%E6%9C%89%E6%8C%87%E5%90%91%20bin%2Fpink%20%E6%96%87%E4%BB%B6%E7%9A%84%E9%93%BE%E6%8E%A5%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%AE%83%E5%B7%B2%E9%93%BE%E6%8E%A5%E5%88%B0%E9%A1%B9%E7%9B%AE%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E5%8F%AA%E6%9C%89%E5%9C%A8%E5%9C%B0%E5%9D%80%200x1B000000%20%E5%A4%84%E8%BE%93%E5%85%A5%E4%B8%8E%200xFFFFFFFFFFFFFFFF%20%E4%B8%8D%E5%90%8C%E7%9A%84%E4%BB%BB%E4%BD%95%E5%80%BC%EF%BC%8C%E4%BB%A3%E7%A0%81%E6%89%8D%E8%83%BD%E5%90%AF%E7%94%A8%20HSE%20%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E3%80%82%E7%84%B6%E5%90%8E%E6%BB%A1%E8%B6%B3%E6%89%80%E6%9C%89%E5%AE%89%E8%A3%85%E6%9D%A1%E4%BB%B6%E2%80%94%E2%80%94HSE%E5%8A%9F%E8%83%BD%E6%A0%87%E5%BF%97%E5%B7%B2%E5%90%AF%E7%94%A8%EF%BC%8CIVT%E6%8C%87%E5%90%91%E9%97%AA%E5%AD%98%E4%B8%AD%E7%9A%84%E6%9C%89%E6%95%88%E7%B2%89%E8%89%B2%E5%9B%BE%E5%83%8F%EF%BC%8C%E5%9B%A0%E6%AD%A4SBAF%E5%B0%86%E5%9C%A8%E4%B8%8B%E6%AC%A1RESET%E5%90%8E%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1809037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1809037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3Es32k312%20%E7%9A%84%E5%9B%BA%E4%BB%B6%E5%8F%AA%E6%98%AF%E6%8E%A5%E5%8F%A3%E5%92%8C%E4%B8%BB%E6%9C%BA%E4%B9%8B%E7%B1%BB%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%8C%E5%AE%83%E4%B8%8D%E6%98%AF%E5%AE%8C%E6%95%B4%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%8F%AF%E4%BB%A5%E5%83%8F%20s32k344%20hse%20%E6%BC%94%E7%A4%BA%E7%A4%BA%E4%BE%8B%E4%B8%80%E6%A0%B7%E5%B0%86%20HSE%20%E5%9B%BA%E4%BB%B6%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E9%97%AA%E5%AD%98%E5%88%B0%E6%8E%A7%E5%88%B6%E5%99%A8%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E5%B0%86%20HSE%20%E5%9B%BA%E4%BB%B6%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E9%97%AA%E5%AD%98%E5%88%B0%20cntroller%20%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8F%AA%E6%8F%90%E4%BE%9B%E4%BA%86%20.bin%20%E6%96%87%E4%BB%B6%E3%80%82%E6%96%87%E4%BB%B6%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E4%BA%86%E5%86%85%E7%BD%AE%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%20PE%20%E5%BE%AE%E5%9E%8B%E5%92%8C%E8%AF%84%E4%BC%B0%E6%9D%BF%E4%BD%86%E6%97%A0%E6%B3%95%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%EF%BC%8C%E5%AE%83%E5%8F%AA%E8%83%BD%E6%94%AF%E6%8C%81%20.elf%20%E5%92%8C%20.hex%E9%94%89%E5%88%80%E8%AF%B7%E5%B8%AE%E6%88%91%E5%B0%86%20.bin%20%E9%97%AA%E5%AD%98%E5%88%B0%E6%8E%A7%E5%88%B6%E5%99%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1809034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1809034%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3ES32K312%20%E7%9A%84%20HSE%20%E5%9B%BA%E4%BB%B6%E4%BB%A3%E7%A0%81%E5%8C%85%E4%BB%85%E5%8C%85%E5%90%AB%20bin%20%E6%96%87%E4%BB%B6%E4%BB%A5%E5%8F%8A%E4%B8%80%E4%BA%9B%E7%94%A8%E4%BA%8E%E5%88%9B%E5%BB%BA%E9%A1%B9%E7%9B%AE%E7%9A%84%E6%8E%A5%E5%8F%A3%E5%92%8C%E4%B8%BB%E6%9C%BA%E6%96%87%E4%BB%B6%E3%80%82%E5%AE%83%E4%B8%8D%E5%83%8F%20s32k344%20%E7%9A%84%20HSE%20%E6%BC%94%E7%A4%BA%E7%A4%BA%E4%BE%8B%E9%82%A3%E6%A0%B7%E6%98%AF%E4%B8%80%E4%B8%AA%E5%AE%8C%E6%95%B4%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E9%9D%A2%E4%B8%B4%E7%9D%80%E4%BD%BF%E7%94%A8%E8%AF%84%E4%BC%B0%E6%9D%BF%E8%B0%83%E8%AF%95%E5%99%A8%E5%92%8C%20PE%20%E5%BE%AE%E5%9E%8B%E8%B0%83%E8%AF%95%E5%99%A8%E5%88%B7%E6%96%B0%20HSE%20%E5%9B%BA%E4%BB%B6%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%AE%83%E4%BB%85%E6%94%AF%E6%8C%81%20.elf%20%E5%92%8C%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%E8%AF%B7%E5%B8%AE%E6%88%91%E5%B0%86%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E5%88%B7%E6%96%B0%E5%88%B0%E8%AF%84%E4%BC%B0%E6%9D%BF%E4%B8%8A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1808928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1808928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224860%22%20target%3D%22_blank%22%3E%40vikmonti7804%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EHSE%20%E5%9B%BA%E4%BB%B6%E5%8F%AF%E4%BB%A5%E5%9C%A8%20S32K3%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20%E6%A0%87%E5%87%86%E8%BD%AF%E4%BB%B6%E5%8C%85%E4%B8%AD%E6%89%BE%E5%88%B0%EF%BC%9Ahttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fswlicensing%2Fsso%2FdownloadSoftware.sp%3Fcatid%3DSW32K3-STDSW-D%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%89%93%E5%BC%80%22Automotive%20SW%20-%20S32K3%20-%20HSE%20Firmware%22%20%EF%BC%8C%E6%82%A8%E5%B0%86%E7%9C%8B%E5%88%B0%E6%89%80%E6%9C%89%E5%8F%AF%E7%94%A8%E7%89%88%E6%9C%AC%EF%BC%8C%E5%8C%85%E6%8B%AC%20S32K312%20%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A4%BA%E4%BE%8B%20S32K344_HSE_FW_INSTALL%20%E6%98%BE%E7%A4%BA%E4%BA%86%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%E7%9A%84%E9%80%89%E9%A1%B9%E3%80%82%E6%88%91%E5%BB%BA%E8%AE%AE%E9%98%85%E8%AF%BB%E8%AF%B4%E6%98%8E%EF%BC%9A%3CBR%20%2F%3Ec%3A%5CNXP%5CS32K3_HSE_DemoExamples_1_0_0%5CS32K3_HSE_DemoExamples%5CDevice_Configuration%5CS32K344_HSE_FW_INSTALL%5CReadme.md%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E8%BF%98%E6%8F%90%E4%BE%9B%E4%BA%86%20AN744810%20%E5%8F%B7%E6%96%87%E4%BB%B6%20%22HSE%20FW%20install%20for%20S32K3xx%22%EF%BC%8C%E5%85%B6%E4%B8%AD%E4%BB%8B%E7%BB%8D%E4%BA%86%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85%E5%9B%BA%E4%BB%B6%E3%80%82%E5%8F%AF%E5%9C%A8%E5%AE%89%E5%85%A8%E6%96%87%E4%BB%B6%E9%83%A8%E5%88%86%E7%9A%84%E6%96%87%E6%A1%A3%E4%B8%AD%E6%89%BE%E5%88%B0%EF%BC%9A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fs32-automotive-platform%2Fs32k-auto-general-purpose-mcus%2Fs32k3-microcontrollers-for-automotive-general-purpose%3AS32K3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Fs32-automotive-platform%2Fs32k-auto-general-purpose-mcus%2Fs32k3-microcontrollers-for-automotive-general-purpose%3AS32K3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F224860%22%20target%3D%22_blank%22%3E%23hello%40vikmonti7804%3C%2FA%3E%E4%BD%A0%E5%BE%97%E5%88%B0%E4%B8%8A%E8%BF%B0%E9%97%AE%E9%A2%98%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E4%BA%86%E5%90%97%EF%BC%9F%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764857943379.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368644i592958693E4B6065%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sanjana_k_0-1764857943379.png%22%20alt%3D%22Sanjana_k_0-1764857943379.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%B8%AE%E6%88%91%E4%BB%AC%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B7%B2%E7%BB%8F%E5%81%9A%E4%BA%86%E5%BE%88%E5%A4%9A%E5%8A%AA%E5%8A%9B%EF%BC%8C%E4%BD%86%E8%BF%98%E6%98%AF%E4%B8%8D%E7%9F%A5%E9%81%93%E8%AF%A5%E6%80%8E%E4%B9%88%E5%8A%9E%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%EF%BC%8C%E6%88%91%E4%BB%AC%E7%9A%84%E5%9B%BA%E4%BB%B6%E4%BB%A3%E7%A0%81%E6%9C%AC%E8%BA%AB%E5%8D%A1%E4%BD%8F%E4%BA%86%EF%BC%8C%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E8%BF%99%E6%A0%B7%EF%BC%8C%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%E3%80%82%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_0-1764856626000.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368640iC3DE810D0B7AFC41%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sanjana_k_0-1764856626000.png%22%20alt%3D%22Sanjana_k_0-1764856626000.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%9B%BA%E4%BB%B6%E5%8D%87%E7%BA%A7%E5%B9%B6%E9%80%9A%E8%BF%87%E4%BA%86%E9%AA%8C%E8%AF%81%EF%BC%8C%E4%BD%86%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E6%88%91%E7%9A%84%E5%9B%BA%E4%BB%B6%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E3%80%82%20%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%23Hello%40lukaszadrapa%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E5%8A%A9%E6%88%91%E4%BB%AC%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E4%BB%AC%E7%9A%84%20HSE%20%E5%9B%BA%E4%BB%B6%E5%B7%B2%E6%88%90%E5%8A%9F%E9%97%AA%E5%AD%98%EF%BC%8C%E4%BD%86%E9%97%AA%E5%AD%98%E5%90%8E%E5%9B%BA%E4%BB%B6%3CSTRONG%3E%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E7%B3%BB%E7%BB%9F%E6%AF%8F%E6%AC%A1%E9%83%BD%E4%BC%9A%E5%8D%A1%E5%9C%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E7%82%B9%E4%B8%8A%EF%BC%8C%E6%97%A0%E6%B3%95%E7%BB%A7%E7%BB%AD%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sanjana_k_1-1764857212653.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F368643iAB002B507DAF0A5F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sanjana_k_1-1764857212653.png%22%20alt%3D%22Sanjana_k_1-1764857212653.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E5%87%A0%E4%B8%AA%E7%96%91%E9%97%AE%EF%BC%9A%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E5%9C%A8%E9%97%AA%E5%AD%98%E5%9B%BA%E4%BB%B6%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E8%BF%90%E8%A1%8C%E4%BB%BB%E4%BD%95%E5%85%B6%E4%BB%96%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%A6%82%E5%AF%86%E9%92%A5%E7%9B%AE%E5%BD%95%E7%A4%BA%E4%BE%8B%E6%88%96%E4%BB%BB%E4%BD%95%E5%85%88%E5%86%B3%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%97%A9%E4%BA%9B%E6%97%B6%E5%80%99%EF%BC%8C%E6%88%91%E4%BB%AC%E5%88%B7%E6%96%B0%E4%BA%86%3CSTRONG%3E2.1%20%E7%89%88%20HSE%20%E5%9B%BA%E4%BB%B6%3C%2FSTRONG%3E%EF%BC%8C%E4%BD%86%E7%8E%B0%E5%9C%A8%E6%88%91%E4%BB%AC%E5%B0%86%E5%9B%BA%E4%BB%B6%E6%9B%B4%E6%94%B9%E4%B8%BA%3CSTRONG%3E2.55%20%E7%89%88%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%E5%8F%98%E5%8C%96%E4%BC%9A%E5%AF%BC%E8%87%B4%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E4%BB%AC%E8%AF%BB%E5%8F%96%E7%9A%84%20SBUF%20%E7%89%88%E6%9C%AC%E6%98%AF%200x00500000%3C%2FSTRONG%3E%E3%80%82%3CBR%20%2F%3E2.55%20%E7%89%88%E5%9B%BA%E4%BB%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%E6%9B%B4%E6%96%B0%E5%88%B0%E6%96%B0%E5%9B%BA%E4%BB%B6%E7%89%88%E6%9C%AC%E6%97%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%AF%B9%3CSTRONG%3EHSE_FW_INSTALL%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%3C%2FSTRONG%3E%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E7%89%B9%E5%AE%9A%E6%9B%B4%E6%94%B9%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%E6%88%91%E4%BB%AC%E5%9C%A8%E6%8F%90%E4%BE%9B%E5%9B%BA%E4%BB%B6%E7%9A%84%E5%90%8C%E6%97%B6%E8%BF%98%E6%8F%90%E4%BE%9B%E4%BA%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%8E%A5%E5%8F%A3%EF%BC%8C%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E5%9C%A8%E5%93%AA%E9%87%8C%E4%BD%BF%E7%94%A8%E5%AE%83%E4%BB%AC%EF%BC%9F%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E4%BB%AC%E6%98%AF%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E5%AF%BC%E8%87%B4%E5%9B%BA%E4%BB%B6%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20firmware%20installation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%23%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243050%22%20target%3D%22_blank%22%3E%20Hello%40sandor_b%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%98%AF%E5%90%A6%E6%94%B6%E5%88%B0%E6%9C%89%E5%85%B3%E6%AD%A4%E9%97%AE%E9%A2%98%E7%9A%84%E6%9C%80%E6%96%B0%E6%B6%88%E6%81%AF%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98--%E6%88%91%E4%BB%AC%E7%9A%84%E7%A8%8B%E5%BA%8F%E5%8D%A1%E5%9C%A8%E4%BA%86%E8%BF%99%E6%9D%A1%E7%BA%BF%E4%B8%8A%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%89%BE%E5%88%B0%E4%BA%86%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E8%AF%B7%E4%B8%8E%E6%88%91%E4%BB%AC%E5%88%86%E4%BA%AB%E3%80%82%E5%AE%83%E7%9C%9F%E7%9A%84%E4%BC%9A%3C%2FP%3E%3C%2FLINGO-BODY%3E
