HSE data reflected in memory only after multiple soft resets
abdul_rahiman_csg
Steps followed:
1. Provide the HSE ELF file (containing HSE data bytes programmed at HSE memory locations) to Cyclone image creator
2. Create a Cyclone .sap file to enable and program HSE.
3. Flash the .sap file on the S32K312 board using the Cyclone debugger via JTAG.
4. Perform a power cycle.
5. Load the workspace and verify HSE data in memory.
6. Perform multiple soft resets via the debugger.
Observed behavior:
• After the initial power cycle, the HSE data is not immediately reflected in memory.
• The HSE data becomes visible in memory only after multiple soft resets. (Issue)
• Also tried allowing with delay, still the same behavior
Question:
• Why are multiple soft resets required for the HSE data to be reflected in memory?
• Is there a recommended workaround (e.g.,reset sequence, or configuration change)?
Tags (3)
lukaszadrapa
Hi @abdul_rahiman_csg
First of all, could you please explain what do you mean by "Provide the HSE ELF file (containing HSE data bytes programmed at HSE memory locations)"?
When HSE firmware is installed, only HSE has exclusive access rights to HSE secure memory (HSE firmware, HSE data). Secure memory is removed from memory map and user can't access it at all.
Lukas
abdul_rahiman_csg
This ELF contains HSE data programmed in the address ranges
0x004D2000–0x004D2060 and
0x1B000000–0x1B000360
Tags (2)
lukaszadrapa
This does not make sense from microcontroller point of view. It seems to be related to tools. Could you try to discuss this with Pemicro directly?
https://www.pemicro.com/support/index.cfm
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-2291377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHSE%20data%20reflected%20in%20memory%20only%20after%20multiple%20soft%20resets%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2291377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3ESteps%20followed%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E1.%20Provide%20the%20HSE%20ELF%20file%20(containing%20HSE%20data%20bytes%20programmed%20at%20HSE%20memory%20locations)%20to%20Cyclone%20image%20creator%3CBR%20%2F%3E2.%20Create%20a%20Cyclone%20.sap%20file%20to%20enable%20and%20program%20HSE.%3CBR%20%2F%3E3.%20Flash%20the%20.sap%20file%20on%20the%20S32K312%20board%20using%20the%20Cyclone%20debugger%20via%20JTAG.%3CBR%20%2F%3E4.%20Perform%20a%20power%20cycle.%3CBR%20%2F%3E5.%20Load%20the%20workspace%20and%20verify%20HSE%20data%20in%20memory.%3CBR%20%2F%3E6.%20Perform%20multiple%20soft%20resets%20via%20the%20debugger.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3EObserved%20behavior%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%80%A2%20After%20the%20initial%20power%20cycle%2C%20the%20HSE%20data%20is%20not%20immediately%20reflected%20in%20memory.%3CBR%20%2F%3E%E2%80%A2%20The%20HSE%20data%20becomes%20visible%20in%20memory%20only%20after%20multiple%20soft%20resets.%20(Issue)%3CBR%20%2F%3E%E2%80%A2%20Also%20tried%20allowing%20with%20delay%2C%20still%20the%20same%20behavior%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3EQuestion%3A%3C%2FSTRONG%3E%3CBR%20%2F%3E%E2%80%A2%20Why%20are%20multiple%20soft%20resets%20required%20for%20the%20HSE%20data%20to%20be%20reflected%20in%20memory%3F%3CBR%20%2F%3E%E2%80%A2%20Is%20there%20a%20recommended%20workaround%20(e.g.%2Creset%20sequence%2C%20or%20configuration%20change)%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2291486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20data%20reflected%20in%20memory%20only%20after%20multiple%20soft%20resets%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2291486%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247683%22%20target%3D%22_blank%22%3E%40abdul_rahiman_csg%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EFirst%20of%20all%2C%20could%20you%20please%20explain%20what%20do%20you%20mean%20by%20%22Provide%20the%20HSE%20ELF%20file%20(containing%20HSE%20data%20bytes%20programmed%20at%20HSE%20memory%20locations)%22%3F%26nbsp%3B%3C%2FP%3E%0A%3CP%3EWhen%20HSE%20firmware%20is%20installed%2C%20only%20HSE%20has%20exclusive%20access%20rights%20to%20HSE%20secure%20memory%20(HSE%20firmware%2C%20HSE%20data).%20Secure%20memory%20is%20removed%20from%20memory%20map%20and%20user%20can't%20access%20it%20at%20all.%26nbsp%3B%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2291603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20data%20reflected%20in%20memory%20only%20after%20multiple%20soft%20resets%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2291603%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22abdul_rahiman_csg_2-1768208452453.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22abdul_rahiman_csg_2-1768208452453.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22abdul_rahiman_csg_2-1768208452453.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F372441iFFEDF197FD80D6A6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22abdul_rahiman_csg_2-1768208452453.png%22%20alt%3D%22abdul_rahiman_csg_2-1768208452453.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eabdul_rahiman_csg_2-1768208452453.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22abdul_rahiman_csg_1-1768208292577.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22abdul_rahiman_csg_1-1768208292577.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22abdul_rahiman_csg_1-1768208292577.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F372440i9B187B2302021542%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22abdul_rahiman_csg_1-1768208292577.png%22%20alt%3D%22abdul_rahiman_csg_1-1768208292577.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eabdul_rahiman_csg_1-1768208292577.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3EThis%20ELF%20contains%20HSE%20data%20programmed%20in%20the%20address%20ranges%3CBR%20%2F%3E%3CSTRONG%3E0x004D2000%E2%80%930x004D2060%20and%20%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSTRONG%3E0x1B000000%E2%80%930x1B000360%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2292297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20data%20reflected%20in%20memory%20only%20after%20multiple%20soft%20resets%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2292297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247683%22%20target%3D%22_blank%22%3E%40abdul_rahiman_csg%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThis%20does%20not%20make%20sense%20from%20microcontroller%20point%20of%20view.%20It%20seems%20to%20be%20related%20to%20tools.%20Could%20you%20try%20to%20discuss%20this%20with%20Pemicro%20directly%3F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Fsupport%2Findex.cfm%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.pemicro.com%2Fsupport%2Findex.cfm%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
