HSE FW installation steps
anilsp31PA
As per steps mentioned in the Demo Application as well as i AN13465, can I use following simple steps to program the HSE FW?
1. Write “HSE FW feature flag” in the UTEST area with 0xAABBCCDDDDCCBBAA.
2. Program the encrypted image of HSE FW at start location of code flash area i.e. 0x00400000.
3. Give a reset by Power cycle of the board.
So will the above steps install the HSE-FW for the first time? Or is anything more needed?
Anil
Tags (2)
VaneB
Hi @anilsp31PA
HSE Firmware can be installed using one of the following 3 methods:
  • Installation via IVT
  • Programming an encrypted FW‑IMG at the default location IVT_START
  • Programming an encrypted FW‑IMG using the MU interface
Installation via IVT is required to perform the following steps:
  • Enable the HSE feature flag by programming an 8‑byte value not consisting entirely of 0xFF into the UTEST address 0x1B000000
  • Set the HSE firmware storage address in the IVT (refer to Section 32.5.3 of the S32K3xx Reference Manual, Rev. 12)
  • Program the HSE firmware into P‑Flash
  • Reset the MCU
For detailed guidance, please refer to the dedicated HSE firmware installation example provided as part of the S32K3 MCUs for General Purpose HSE Demo Examples.
As a simplified alternative, the firmware can be installed by programming the encrypted FW‑IMG at IVT_START. The following steps are required:
  • Enable the HSE feature flag, as described above
  • Program the .pink file at the start address 0x00400000
  • Reset the MCU
With this method, there must be no valid IVT present at the default location IVT_START. More details about this condition are discussed in the following thread:
S32K312 HSE without IVT Install Not Successful
BR, VaneB
VaneB
Hi @anilsp31PA
  • Reset the MCU
  • Reset the MCU
BR, VaneB
anilsp31PA
It worked.
Thanks for your support.
Anil
%3CLINGO-SUB%20id%3D%22lingo-sub-2358684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHSE%20FW%20installation%20steps%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EAs%20per%20steps%20mentioned%20in%20the%20Demo%20Application%20as%20well%20as%20i%20AN13465%2C%20can%20I%20use%20following%20simple%20steps%20to%20program%20the%20HSE%20FW%3F%3C%2FP%3E%3CP%3E1.%20Write%26nbsp%3B%E2%80%9CHSE%20FW%20feature%20flag%E2%80%9D%20in%20the%20UTEST%20area%20with%26nbsp%3B0xAABBCCDDDDCCBBAA.%3C%2FP%3E%3CP%3E2.%26nbsp%3BProgram%20the%20encrypted%20image%20of%20HSE%20FW%20at%20start%20location%20of%20code%20flash%20area%20i.e.%200x00400000.%3C%2FP%3E%3CP%3E3.%20Give%20a%20reset%20by%20Power%20cycle%20of%20the%20board.%3C%2FP%3E%3CP%3ESo%20will%20the%20above%20steps%20install%20the%20HSE-FW%20for%20the%20first%20time%3F%20Or%20is%20anything%20more%20needed%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EAnil%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20FW%20installation%20steps%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358814%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229232%22%20target%3D%22_blank%22%3E%40anilsp31PA%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EHSE%20Firmware%20can%20be%20installed%20using%20one%20of%20the%20following%203%20methods%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EInstallation%20via%20IVT%3C%2FLI%3E%0A%3CLI%3EProgramming%20an%20encrypted%20FW%E2%80%91IMG%20at%20the%20default%20location%20IVT_START%3C%2FLI%3E%0A%3CLI%3EProgramming%20an%20encrypted%20FW%E2%80%91IMG%20using%20the%20MU%20interface%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EInstallation%20via%20IVT%20is%20required%20to%20perform%20the%20following%20steps%3A%3C%2FP%3E%0A%3CUL%20class%3D%22lia-list-style-type-circle%22%3E%0A%3CLI%3EEnable%20the%20HSE%20feature%20flag%20by%20programming%20an%208%E2%80%91byte%20value%20not%20consisting%20entirely%20of%200xFF%20into%20the%20UTEST%20address%200x1B000000%3C%2FLI%3E%0A%3CLI%3ESet%20the%20HSE%20firmware%20storage%20address%20in%20the%20IVT%20(refer%20to%20Section%2032.5.3%20of%20the%20S32K3xx%20Reference%20Manual%2C%20Rev.%2012)%3C%2FLI%3E%0A%3CLI%3EProgram%20the%20HSE%20firmware%20into%20P%E2%80%91Flash%3C%2FLI%3E%0A%3CLI%3EReset%20the%20MCU%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EFor%20detailed%20guidance%2C%20please%20refer%20to%20the%20dedicated%20HSE%20firmware%20installation%20example%20provided%20as%20part%20of%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DS32K3_HSE_DemoExamples%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3ES32K3%20MCUs%20for%20General%20Purpose%20HSE%20Demo%20Examples%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EAs%20a%20simplified%20alternative%2C%20the%20firmware%20can%20be%20installed%20by%20programming%20the%20encrypted%20FW%E2%80%91IMG%20at%20IVT_START.%20The%20following%20steps%20are%20required%3A%3C%2FP%3E%0A%3CUL%20class%3D%22lia-list-style-type-circle%22%3E%0A%3CLI%3EEnable%20the%20HSE%20feature%20flag%2C%20as%20described%20above%3C%2FLI%3E%0A%3CLI%3EProgram%20the%20.pink%20file%20at%20the%20start%20address%200x00400000%3C%2FLI%3E%0A%3CLI%3EReset%20the%20MCU%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3EWith%20this%20method%2C%20there%20must%20be%20no%20valid%20IVT%20present%20at%20the%20default%20location%20IVT_START.%20More%20details%20about%20this%20condition%20are%20discussed%20in%20the%20following%20thread%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K312-HSE-without-IVT-Install-Not-Successful%2Ftd-p%2F2096756%22%20target%3D%22_blank%22%3ES32K312%20HSE%20without%20IVT%20Install%20Not%20Successful%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%2C%20VaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2359311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20HSE%20FW%20installation%20steps%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2359311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20worked.%3C%2FP%3E%3CP%3EThanks%20for%20your%20support.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EAnil%3C%2FP%3E%3C%2FLINGO-BODY%3E
