Getting started with Freemaster tool, S32k116 not connecting
MohameddRIAD
I have installed Freemaster 2.0 and connected my S32k116 evaluation board to my usb port, I've followed the guide and adjusted the communication on the project with the following settings
PORT: Open SDA
Speed: 115200
when I try to start the communication an error happens with log window attached below.
MohameddRIAD
hello,
thank you for your swift response , my problem was solved apparently I didn't setup the jumpers correctly for usb
_Leo_
Thank you so much for your interest in our products and for using our community.
Could you tell me which example code are you using? And can you try with the FreeMASTER Tool 3.2 please?
Have a nice day!
