Generate Clock on Port
已解决
跳至解决方案
1,697 次查看
hafifi
Hello All
I'm using S32K388 board
I have configure PIN_D_14 as system clock run. I need to know how to generate clock 20MHZ from PIN_D_14?
Hossam
标记 (1)
1 解答
1,676 次查看
VaneB
Hi @hafifi
Similar situations has been discussed before. Please take a look at the following community thread; it might give you some useful insights:
Expected CLKOUT_RUN frequency not observed in the mapped GPIO
If the information there does not fully address your needs, please let me know.
BR, VaneB
在原帖中查看解决方案
2 回复数
1,677 次查看
VaneB
Hi @hafifi
BR, VaneB
1,609 次查看
hafifi
Hi @VaneB
Thank you for support.
BR,
hafifi
