GPIO Pin state and Electrical specification at microcontroller in VLPS stage
1,658件の閲覧回数
Chinnan
Could you please help me to know what's the microcontroller (S32K144) GPIO pin's state and its electrical specifications in Deep sleep mode (VLPS)?
#S32K144, # VLPS, #GPIO
タグ(3)
1,640件の閲覧回数
VaneB
Hi @Chinnan
Table 39-4 of the RM says that GPIO/PORT are OFF. This talks about GPIO/PORT module inside the chip, not about pin structure. The module is turned off but the pins retain their configuration and their state. So, electrical characteristics are exactly the same as in normal run mode.
I hope this will help you.
B.R.
VaneB
