FlexIO use in LIN
FlexIO use in LIN
CaoRq
Hi NXP
     I am using FlexIO for LIN in S32K358. When I use the example in RTD, I meet a problem about it
    When I send LIN frame by FlexIO , the LinStatus is always tx busy and can't be ok , I hope you can tell me how to solve it
    Thank you in  advance
PetrS
do you have LIN transceiver connected properly? It is active and with right termination?
What is a signal seen on LIN line?
BR, Petr
