FlexCAN FLTCONF and ACK Error
2,274件の閲覧回数
raviranjankumar
Hi All,
I am working on S32K144 FlexCAN driver. I am using SNHVD230 CAN transceiver.  I am communicating with test bench (simulator) which will support CAN.
When I active the transmit buffer by writing 0xC, the data is transmitting on the bus. I am getting FLTCONF and ACK Error.
When I communicated with another controller I am getting data from the simulator. I am not getting what is the issue. I configured CAN like given example code in S32K Design Studio.
Please help me. Waiting for your response.
Thanks and Regards,
Ravi Ranjan Kumar
1,994件の閲覧回数
danielmartynek
I the transmitter expects to get ACK so you always need another node that would acknowledge the message.
