Flash Erase not happened
ganeshvaka2
Hello all,
I am working on LIN Bootloader. When we flash the software we need to erase memory .
I was requesting erase memory it going to WDT IRQ Handler
we are using memcopy from there only we are getting issue
if any know the issue please resend
Thank you
lukaszadrapa
this would require more details and more debugging. Can I see the failing code? Where does it crash exactly? What you are copying by memcpy?
Lukas
ganeshvaka2
Hello @lukaszadrapa
Thank you for your Response
We are using unified_bootloader_framework  for S32K bootloader code using S32K116.we are add Flash function in MyRamcode
can you please check Memcopy
Here crashing the code
Thanks and Regards
Ganesh Babu Vaka
lukaszadrapa
could you send me that project? Please upload compiled one, so I can only load elf file without modification.
Lukas
