Facing error
3,519件の閲覧回数
Shrini
I have created a project for timer peripheral. I took example code (ftm_periodic_interrupt_s32k144) for reference. I have configured everything, same as example code. After building my project I'm getting errors. i.e., multiple definition of () first defined here. This type of error I'm getting 53 times with different  API's.
3,455件の閲覧回数
Senlent
Your steps are fine, but here is not the same as ours,
I don't know what caused this result. Maybe you can uninstall the SDK and reinstall it. There is already version 4.0.3.
10 返答(返信)
3,494件の閲覧回数
Senlent
Hi@Shrini
Please do not modify the files in your project directory
3,491件の閲覧回数
Shrini
Hi@Senlent I don't understand. What did you do? Some other files are attached in the zip file. How did you add them? Please let me know.
3,482件の閲覧回数
Senlent
I didn't do anything, just created a new project and referred to the same configuration as you
3,479件の閲覧回数
Shrini
Actually, the file which I have sent you, that does not contain linker_files, startup, src.bak files... I think it's my fault while creating the project I think I skipped some steps. So could you please send me the entire steps or procedure for this particular project?
3,475件の閲覧回数
Senlent
Hi@Shrini
1.create new project
2.configure peripherals
3.Generate configuration code
4.Copy main.c, compile, done!
3,462件の閲覧回数
Shrini
Hi@Senlent,
Check the attached zip file and please correct the mistake.
3,456件の閲覧回数
Senlent
3,402件の閲覧回数
Shrini
Thank you @Senlent for your suggestion. I will reinstall the SDK.
3,511件の閲覧回数
Senlent
Hi@Shrini
I can't give the exact cause of the error according to the picture, you can export your project and I'll check it for you.
3,504件の閲覧回数
Shrini
Hello@Senlent Please find the attached file.
