FS26 Wake strategy
FS26 Wake strategy
mogilipuri_harish
hello team,
we are using FS26 SBC in our designs. we planning to wake up the SBC using below configuration.
Wake1:
the wake1 pin of SBC will be high when the external enable (BECM) is high and LDO output is LOW.
Wake2:
the wake2 pins is connected to reset pin of uC (S32K312)
can please confirm whether this strategy is correct or not??
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
I do not see any issue with the logic. As we know, the WAKEx pins can detect wake-up event on high level or low level.
Please make sure you configure the correct event detection polarity on the WAKEx pins.
Anyway, I do recommend to perform you own tests before any conclusion.
I hope this information helps.
David
