FPU example for S32K144
bryan_hong
Senior Contributor I
Dear NXP
I want to get example FPU example for S32K144
thanks
Bryan
Senlent
Hi@bryan_hong
you can check the "Disassembly" to see the difference.
by the way, if you already enabled FPU but it still fails, you can check "Optimization Level" is set to None or not, I found that this option has an impact on the FPU settings.
Senlent
Hi@bryan_hong
you can follow below method to enable use FPU
1.For a new project.
2.For an existing project
bryan_hong
Dear @Senlent
thanks for your comments.
I know how to set FPU
Btw, I want to know how to check FPU,
If there is an example or method to check FPU, plz guide to me
thanks
Bryan
Senlent
Hi@bryan_hong
bryan_hong
Dear @Senlent
Belows must be checked for FPU ?
Senlent
Hi@bryan_hong
I only tested the optimization options.
I did't test these options,but I think this should not affect the FPU.
bryan_hong
Dear @Senlent
I think it would be better to not tell customer about that 4 optimazation.
thanks
Bryan
