Ethernet initialisation issues in AVTP project
1,327件の閲覧回数
ssattva1
I am working on AVTP implementation using AVB stack provided by NXP
I am specifically working on s32k358_baremetal_acf_example project and I am facing issues after flashing the elf. I did not face any issues with building the project (make sure RTD version is 4.0 , not 5.0). My ethernet module initialisation is not getting done after flashing.
Issues:
  • Program goes to HW fault immediately after flashing , reason being " MemManage: The processor attempted an instruction fetch from a location that does not permit execution. HardFault: A fault has been escalated to a hard fault." After clicking reset button in the debug window then it enters into main.c
  • In the function EMACLLD_ClockInit_HwSwitch() , the clock switch is not happening and upon observing the registers  I come to know that the clock switch request fails and FIRC is the source instead of EMAC_EXTERNAL_TX_RMII. "010b - Switch after the request failed because of an inactive target clock and the current clock is FIRC."
  • Upon further digging , I decide to compare it with LWIP baremetal project . The above registers show success after Clock_Ip_Init () in device_init(), not so the case with AVTP project.  I am using the same board and PHY , yet I dont know why it shows target clock inactive when it comes to AVTP project.
  • Even if I comment out the EMACLLD_ClockInit_HwSwitch() function and make appropriate clock configs in the peripheral tool , it again gets stuck at DMA init
  • Please help me resolve this blocker.
    HW USED: S32K358 eval board
    PHY : ADTJA1101-RMII
タグ(3)
3 返答(返信)
1,320件の閲覧回数
PavelL
Hello @ssattva1 ,
I have successfully run RGMII with the TJA1103-SDBR on the S32K3X8EVB-Q289.
However, RMII requires some hardware modifications to the board. For details, please refer to section 13.2 of the S32K3X8EVB-Q289 Hardware User Manual (S32K3X8EVB-Q289HWUM.pdf).
Pavel
1,292件の閲覧回数
ssattva1
Hi @PavelL , Lwip example works without making those changes in HW for RMII.
I found this thing recently, when I probe into resistor 65 in ADTJA1101, which is the resistor along REFCLK, the voltage level is around 2V for LWIP project , but it drops down to 1V as soon as I run AVTP project. Could you help me with this?
1,245件の閲覧回数
PavelL
Hello @ssattva1 ,
I apologize for the delayed response — I was on vacation.
It's great to hear that the LWIP example works for you.
Regarding the voltage drop on REFCLK, this seems like a hardware conflict. Please verify that the RMII pin configuration matches between the LWIP example and your AVTP project. Specifically, the emac_mii_rmii_tx_clk pin should be configured as input.
In other words, since one example works, I recommend comparing its configuration with the other project to identify any discrepancies.
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-2149081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAVTP%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AFNXP%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%99%E3%82%8BAVB%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6AVTP%E5%AE%9F%E8%A3%85%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ssattva1_0-1754643186207.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ssattva1_0-1754643186207.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351549i200946C26275D1AD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ssattva1_0-1754643186207.png%22%20alt%3D%22ssattva1_0-1754643186207.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%20s32k358_baremetal_acf_example%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%8A%E3%82%8A%E3%80%81elf%20%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20(RTD%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%205.0%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%204.0%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%E3%80%82%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E5%BE%8C%E3%81%AB%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%95%8F%E9%A1%8C%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E7%9B%B4%E5%BE%8C%E3%81%AB%20HW%20%E9%9A%9C%E5%AE%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%90%86%E7%94%B1%E3%81%AF%E3%80%81%E3%80%8CMemManage%3A%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E6%89%80%E3%81%8B%E3%82%89%E5%91%BD%E4%BB%A4%E3%83%95%E3%82%A7%E3%83%83%E3%83%81%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8D%E3%81%A7%E3%81%99%E3%80%82HardFault%3A%20%E9%9A%9C%E5%AE%B3%E3%81%8C%E3%83%8F%E3%83%BC%E3%83%89%E9%9A%9C%E5%AE%B3%E3%81%AB%E3%82%A8%E3%82%B9%E3%82%AB%E3%83%AC%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%81%A7%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81main.c%E3%81%AB%E5%85%A5%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ssattva1_1-1754643620648.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ssattva1_1-1754643620648.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351551i3122D9204BA0430B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ssattva1_1-1754643620648.png%22%20alt%3D%22ssattva1_1-1754643620648.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E9%96%A2%E6%95%B0%20EMACLLD_ClockInit_HwSwitch()%20%E3%81%A7%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%9A%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E8%A6%B3%E5%AF%9F%E3%81%99%E3%82%8B%E3%81%A8%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%80%81EMAC_EXTERNAL_TX_RMII%20%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%20FIRC%20%E3%81%8C%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%22%3CSPAN%3E010b%20-%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E9%9D%9E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%20FIRC%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%A6%81%E6%B1%82%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AE%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%80%82%22%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ssattva1_0-1754643881076.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ssattva1_0-1754643881076.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351553i31C9733BFBC2795D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ssattva1_0-1754643881076.png%22%20alt%3D%22ssattva1_0-1754643881076.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%E3%81%95%E3%82%89%E3%81%AB%E8%A9%B3%E3%81%97%E3%81%8F%E8%AA%BF%E3%81%B9%E3%81%9F%E7%B5%90%E6%9E%9C%E3%80%81LWIP%20%E3%83%99%E3%82%A2%E3%83%A1%E3%82%BF%E3%83%AB%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%80%81device_init()%20%E5%86%85%E3%81%AE%20Clock_Ip_Init()%20%E5%BE%8C%E3%81%AE%E6%88%90%E5%8A%9F%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81AVTP%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AECASE%E3%81%AFSO%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%90%8C%E3%81%98%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%20PHY%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81AVTP%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8C%E9%9D%9E%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E7%90%86%E7%94%B1%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLI%3E%3CLI%3EEMACLLD_ClockInit_HwSwitch()%20%E9%96%A2%E6%95%B0%E3%82%92%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%A6%E3%80%81%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E9%81%A9%E5%88%87%E3%81%AA%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%A7%8B%E6%88%90%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%82%82%E3%80%81DMA%20%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%A7%E5%86%8D%E3%81%B3%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22ssattva1_1-1754644217547.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22ssattva1_1-1754644217547.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351554i8C43CFA6C5ED2697%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22ssattva1_1-1754644217547.png%22%20alt%3D%22ssattva1_1-1754644217547.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%E3%81%93%E3%81%AE%E9%9A%9C%E5%AE%B3%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%3A%20S32K358%20%E8%A9%95%E4%BE%A1%E3%83%9C%E3%83%BC%E3%83%89%3CBR%20%2F%3EPHY%3A%20ADTJA1101-RMII%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152101%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Ethernet%20initialisation%20issues%20in%20AVTP%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152101%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243530%22%20target%3D%22_blank%22%3E%40ssattva1%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%BF%94%E4%BA%8B%E3%81%8C%E9%81%85%E3%82%8C%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BC%91%E6%9A%87%E4%B8%AD%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3ELWIP%20%E3%81%AE%E4%BE%8B%E3%81%8C%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A3%E3%81%9F%E3%81%A8%E8%81%9E%E3%81%84%E3%81%A6%E3%81%86%E3%82%8C%E3%81%97%E3%81%8F%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EREFCLK%20%E3%81%AE%E9%9B%BB%E5%9C%A7%E9%99%8D%E4%B8%8B%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E7%AB%B6%E5%90%88%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82LWIP%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%A8%20AVTP%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E9%96%93%E3%81%A7%20RMII%20%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%E3%80%81emac_mii_rmii_tx_clk%20%E3%83%94%E3%83%B3%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%811%20%E3%81%A4%E3%81%AE%E4%BE%8B%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E4%BB%96%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A8%E6%AF%94%E8%BC%83%E3%81%97%E3%81%A6%E3%80%81%E7%9B%B8%E9%81%95%E7%82%B9%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%99%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Ethernet%20initialisation%20issues%20in%20AVTP%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233505%22%20target%3D%22_blank%22%3E%40PavelL%3C%2FA%3E%20%E3%80%81Lwip%20%E3%81%AE%E4%BE%8B%E3%81%AF%E3%80%81RMII%20%E3%81%AE%20HW%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%AA%E3%81%8F%E3%81%A6%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%9C%80%E8%BF%91%E3%80%81REFCLK%20%E3%81%AB%E6%B2%BF%E3%81%A3%E3%81%9F%E6%8A%B5%E6%8A%97%E5%99%A8%E3%81%A7%E3%81%82%E3%82%8B%20ADTJA1101%20%E3%81%AE%E6%8A%B5%E6%8A%97%E5%99%A8%2065%20%E3%82%92%E8%AA%BF%E3%81%B9%E3%82%8B%E3%81%A8%E3%80%81LWIP%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%81%8C%E7%B4%84%202V%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81AVTP%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%81%99%E3%81%90%E3%81%AB%201V%20%E3%81%BE%E3%81%A7%E4%BD%8E%E4%B8%8B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Ethernet%20initialisation%20issues%20in%20AVTP%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F243530%22%20target%3D%22_blank%22%3E%40ssattva1%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3ES32K3X8EVB-Q289%20%E4%B8%8A%E3%81%AE%20TJA1103-SDBR%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20RGMII%20%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81RMII%20%E3%81%A7%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CEM%3ES32K3X8EVB-Q289%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%3C%2FEM%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E(S32K3X8EVB-Q289HWUM.pdf)%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%99%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
