EEE functionality in S32K1xx- timing issues
1,576件の閲覧回数
vinu_jose
We are using EEE functionality in S32K1xx. 32 Kb FlexNVM is partitioned as an E-flash and 4Kb of FlexRAM is used as EEE memory. But, we observe that, to write 10 bytes to FlexRAM area, it is consuming 700us. Is this normal ?
タグ(2)
1,425件の閲覧回数
danielmartynek
The timing can be found in the S32K1xx Datasheet rev. 9 Table 23, 24.
https://www.nxp.com/docs/en/data-sheet/S32K-DS.pdf
