EB license activation failed.
3,294 次查看
BluesJiang
I use the latest activation code, but I can't activate the EB thesos.
Here is the log:
ERROR: flxActAppActivationSend (50040,41147,10248)
The quantity specified exceeds maximum quantity allowed (0).
Connection to FlexNet Operations Server failed.
I also tried offline activation. It's also failed.The log is under below:
Manual Node-Locked License Activation processing ...
ERROR: Processing response (50019,41200,10246)
3 回复数
3,269 次查看
BluesJiang
Thanks a lot. Your code is valid and I can continue on my work.
3,272 次查看
petervlna
The actual free licenses are depleted. I have sent you code which you can use.
Peter
2,779 次查看
ArgieC
Hi, I got problem with activating my EB tresos too. I got this message when trying to activate using the activation code:
ERROR: flxActSvrActivationSend (50040,41147,10248)
The license does not allow served activation.
