EB Tresos verification step failed
1,200件の閲覧回数
Rohidask24
I am trying to integrate MCAL package and during the generation i am getting verification error as follow: "Failed to run generator "Dio_TS_T40D2M20I0R0_UniqueNGGeneratorId" (mode: "verify") for module "Dio_TS_T40D2M20I0R0"" along with "Missing parameter buildfile" error. The files are getting generated, but verification get fails. What could be the reason.?
1,180件の閲覧回数
Julián_AragónM
Hi @Rohidask24,
I can see you have entered the same case through the following thread: EB Tresos status is showing failed to run generator - NXP Community.
I will continue to support you through that community post in order to avoid any confusion.
Julián
