EB Studio config S32K312's LIN module as Slave model
1,224 次查看
shiqi_seventeen
Hello Team
Is there any example(pictures , documents,videos)  config S32K312's LIN module as Slave model by EB Tresos?Or how can find any passages about it?
标记 (1)
1 回复
1,210 次查看
CongDang
Lin Node Type on Ebtresos supports configuring LIN  as Slave/Master model. You can find the Lin Node Type in LinChannel configuration:
This was also introduced in Um document.
