Debug problem on RD-BESSK358BMU
BillWen
Hi NXP:
Currently, I want to flash and debug RD-BESSK358BMU EVB with NXP S32K3 BESS Application Version 0.8.0 Demo code (I didn't change anything), and I met some problem, I can debug in the first time, when I run debug in second time, it will be fail. (I can flash other easy sample code).
After this problem, I even can't erase the image by j-flash tool. Do you have any experience about this issue?
The Attachment is console log.
BR, BillWen
Robin_Shen
Due to a problem with this old firmware, FS26 keeps resetting the S32K358. I'm afraid you need to disconnect R228 to re-download the program for the S32K358.
Sorry for the inconvenience we bring you!
Robin_Shen
Hi BillWen,
Please contact FAE to obtain the latest August_2024_Release which has fixed this issue.
Robin
- If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
BillWen
Hi Robin_Shen:
The problem is that I can't erase now, I don't know how to do. Do you have any recommendation?
BR, BillWen
Robin_Shen
BillWen
Hi Robin_Shen:
Sorry, I can't understand what you mean. Do you mean that I need rework the EVB board (remove R228) then I can use j flash erase image?
BR, BillWen
Robin_Shen
Yes. You need rework the EVB board (remove R228).
If you have an oscilloscope or logic analyzer, you should be able to measure that the low level signal resetting the S32K3.
BillWen
Hi Robin_Shen:
Yes for your help, I can erase image after remove R228.
Final question, where can I get newest version software for BESS s32k358? Is this release private or public? Or I only can get it from distributor's FAE?
BR, BillWen
Robin_Shen
private. Please contact FAE.
BillWen
Hi Robin_Shen:
Really thanks for your help. I will contact our distributor's FAE.
BR, BillWen
%3CLINGO-SUB%20id%3D%22lingo-sub-2147416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDebug%20problem%20on%20%20RD-BESSK358BMU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147416%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%3A%3C%2FP%3E%3CP%3ECurrently%2C%20I%20want%20to%20flash%20and%20debug%26nbsp%3BRD-BESSK358BMU%20EVB%20with%20NXP%20S32K3%20BESS%20Application%20Version%200.8.0%20Demo%20code%20(I%20didn't%20change%20anything)%2C%20and%20I%20met%20some%20problem%2C%20I%20can%20debug%20in%20the%20first%20time%2C%20when%20I%20run%20debug%20in%20second%20time%2C%20it%20will%20be%20fail.%20(I%20can%20flash%20other%20easy%20sample%20code).%3C%2FP%3E%3CP%3EAfter%20this%20problem%2C%20I%20even%20can't%20erase%20the%20image%20by%20j-flash%20tool.%20Do%20you%20have%20any%20experience%20about%20this%20issue%3F%3C%2FP%3E%3CP%3EThe%20Attachment%20is%20console%20log.%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CP%3EBR%2C%20BillWen%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debug%20problem%20on%20%20RD-BESSK358BMU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Robin_Shen%3A%3CBR%20%2F%3EReally%20thanks%20for%20your%20help.%20I%20will%20contact%20our%20distributor's%20FAE.%3CBR%20%2F%3EThanks%3CBR%20%2F%3EBR%2C%20BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debug%20problem%20on%20%20RD-BESSK358BMU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Eprivate.%20Please%20contact%20FAE.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debug%20problem%20on%20%20RD-BESSK358BMU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148252%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Robin_Shen%3A%3CBR%20%2F%3EYes%20for%20your%20help%2C%20I%20can%20erase%20image%20after%20remove%20R228.%3CBR%20%2F%3EFinal%20question%2C%20where%20can%20I%20get%20newest%20version%20software%20for%20BESS%20s32k358%3F%20Is%20this%20release%20private%20or%20public%3F%20Or%20I%20only%20can%20get%20it%20from%20distributor's%20FAE%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%3CBR%20%2F%3EBR%2C%20BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debug%20problem%20on%20%20RD-BESSK358BMU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes.%20You%20need%20rework%20the%20EVB%20board%20(remove%20R228).%3C%2FP%3E%0A%3CP%3EIf%20you%20have%20an%20oscilloscope%20or%20logic%20analyzer%2C%20you%20should%20be%20able%20to%20measure%20that%20the%20low%20level%20signal%20resetting%20the%20S32K3.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2148061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debug%20problem%20on%20%20RD-BESSK358BMU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2148061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Robin_Shen%3A%3CBR%20%2F%3E%3CBR%20%2F%3ESorry%2C%20I%20can't%20understand%20what%20you%20mean.%20Do%20you%20mean%20that%20I%20need%20rework%20the%20EVB%20board%20(remove%20R228)%20then%20I%20can%20use%20j%20flash%20erase%20image%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%3CBR%20%2F%3EBR%2C%20BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debug%20problem%20on%20%20RD-BESSK358BMU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDue%20to%20a%20problem%20with%20this%20old%20firmware%2C%20FS26%20keeps%20resetting%20the%20S32K358.%20I'm%20afraid%20you%20need%20to%20disconnect%20R228%20to%20re-download%20the%20program%20for%20the%20S32K358.%3C%2FP%3E%0A%3CP%3ESorry%20for%20the%20inconvenience%20we%20bring%20you!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debug%20problem%20on%20%20RD-BESSK358BMU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147883%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Robin_Shen%3A%3CBR%20%2F%3EThe%20problem%20is%20that%20I%20can't%20erase%20now%2C%20I%20don't%20know%20how%20to%20do.%20Do%20you%20have%20any%20recommendation%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%3CBR%20%2F%3EBR%2C%20BillWen%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Debug%20problem%20on%20%20RD-BESSK358BMU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%3EBillWen%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EPlease%20contact%20FAE%20to%20obtain%20the%20latest%20%3CSTRONG%3EAugust_2024_Release%3C%2FSTRONG%3E%20which%20has%20fixed%20this%20issue.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3ERobin%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22ACCEPT%20AS%20SOLUTION%22%20button.%20Thank%20you!%3C%2FP%3E%0A%3CP%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
