Cryto driver not working
646 次查看
adijoshi
HI ,
One of our BMS customer using S32k344 has the following issue
I am using the crypto_1 mcal to do hashing. For some reason, when I run the job, the hash buffer is does not get filled in at all and just stays with whatever was in it before.
638 次查看
lukaszadrapa
Hi @adijoshi
Is the hash buffer forced to non-cacheable RAM? All data objects used for communication with HSE must be forced to non-cacheable RAM. HSE can't see the cache. Or you can simply turn off the data cache to see if it makes a difference.
Lukas
