Cortex M4F PendSV with FPU
1,493 次查看
LijieDu
xPortPendSVHandler:
ldr r3, =pxCurrentTCB
ldr r2, [r3] /* r2 = pxCurrentTCB. */
ldr r1, [r2] /* r1 = Location where the context should be saved. */
/*------------ Save Context. ----------- */
mrs r3, control
mrs r0, psp
isb
add r0, r0, #0x20 /* Move r0 to location where s0 is saved. */
tst lr, #0x10
ittt eq
vstmiaeq r1!, {s16-s31} /* Store s16-s31. */
vldmiaeq r0, {s0-s16} /* Copy hardware saved FP context into s0-s16. */
vstmiaeq r1!, {s0-s16} /* Store hardware saved FP context. */
sub r0, r0, #0x20 /* Set r0 back to the location of hardware saved context. */
stmia r1!, {r3-r11, lr} /* Store CONTROL register, r4-r11 and LR. */
ldmia r0, {r4-r11} /* Copy hardware saved context into r4-r11. */
stmia r1!, {r0, r4-r11} /* Store original PSP (after hardware has saved context) and the hardware saved context. */
str r1, [r2] /* Save the location from where the context should be restored as the first member of TCB. */
/*---------- Select next task. --------- */
mov r0, #configMAX_SYSCALL_INTERRUPT_PRIORITY
#if ( configENABLE_ERRATA_837070_WORKAROUND == 1 )
cpsid i /* ARM Cortex-M7 r0p1 Errata 837070 workaround. */
#endif
msr basepri, r0
dsb
isb
cpsie i /* ARM Cortex-M7 r0p1 Errata 837070 workaround. */
#endif
bl vTaskSwitchContext
mov r0, #0
msr basepri, r0
/*------------ Program MPU. ------------ */
add r2, r2, #4 /* r2 = Second item in the TCB which is xMPUSettings. */
dmb /* Complete outstanding transfers before disabling MPU. */
ldr r0, =0xe000ed94 /* MPU_CTRL register. */
ldr r3, [r0] /* Read the value of MPU_CTRL. */
bic r3, #1 /* r3 = r3 & ~1 i.e. Clear the bit 0 in r3. */
str r3, [r0] /* Disable MPU. */
ldr r0, =0xe000ed9c /* Region Base Address register. */
ldmia r2!, {r4-r11} /* Read 4 sets of MPU registers [MPU Region # 0 - 3]. */
stmia r0, {r4-r11} /* Write 4 sets of MPU registers [MPU Region # 0 - 3]. */
#ifdef configTOTAL_MPU_REGIONS
#if ( configTOTAL_MPU_REGIONS == 16 )
ldmia r2!, {r4-r11} /* Read 4 sets of MPU registers [MPU Region # 4 - 7]. */
stmia r0, {r4-r11} /* Write 4 sets of MPU registers. [MPU Region # 4 - 7]. */
ldmia r2!, {r4-r11} /* Read 4 sets of MPU registers [MPU Region # 8 - 11]. */
stmia r0, {r4-r11} /* Write 4 sets of MPU registers. [MPU Region # 8 - 11]. */
#endif /* configTOTAL_MPU_REGIONS == 16. */
#endif
orr r3, #1 /* r3 = r3 | 1 i.e. Set the bit 0 in r3. */
str r3, [r0] /* Enable MPU. */
dsb /* Force memory writes before continuing. */
/*---------- Restore Context. ---------- */
ldr r1, [r2] /* r1 = Location of saved context in TCB. */
ldmdb r1!, {r0, r4-r11} /* r0 contains PSP after the hardware had saved context. r4-r11 contain hardware saved context. */
msr psp, r0
stmia r0!, {r4-r11} /* Copy the hardware saved context on the task stack. */
ldmdb r1!, {r3-r11, lr} /* r3 contains CONTROL register. r4-r11 and LR restored. */
msr control, r3
tst lr, #0x10
ittt eq
vldmdbeq r1!, {s0-s16} /* s0-s16 contain hardware saved FP context. */
vstmiaeq r0!, {s0-s16} /* Copy hardware saved FP context on the task stack. */
vldmdbeq r1!, {s16-s31} /* Restore s16-s31. */
str r1, [r2] /* Save the location where the context should be saved next as the first member of TCB. */
bx lr
I don't understand why it is S0~S16?
S0~S15 and status reg are pushed into stack by hardware, why copy it again?
Hope get your direction and advice!
3 回复数
1,468 次查看
davidtosenovjan
There seems to be an error in the code. Could you please indicate where this code is taken from?
1,457 次查看
LijieDu
 Hi davidtosenovjan
It comes from :FreeRTOS-Kernel/portable/IAR/ARM_CM4F_MPU at main · FreeRTOS/FreeRTOS-Kernel · GitHub
Hope to get your advice, thanks very much
1,433 次查看
davidtosenovjan
The code in the FreeRTOS-Kernel/portable/IAR/ARM_CM4F_MPU directory is maintained by Amazon.com, Inc.
You can do so by opening an issue or a pull request on the GitHub repository. The FreeRTOS team actively monitors these channels.
%3CLINGO-SUB%20id%3D%22lingo-sub-2136881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B8%A6%20FPU%20%E7%9A%84%20Cortex%20M4F%20PendSV%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136881%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ExPortPendSVHandler%EF%BC%9A%3C%2FP%3E%3CP%3Eldr%20r3%2C%20%3DpxCurrentTCB%3CBR%20%2F%3Eldr%20r2%2C%20%5Br3%5D%20%2F*%20r2%20%3D%20pxCurrentTCB%E3%80%82*%2F%3CBR%20%2F%3Eldr%20r1%2C%20%5Br2%5D%20%2F*%20r1%20%3D%20%E4%BF%9D%E5%AD%98%E4%B8%8A%E4%B8%8B%E6%96%87%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82*%2F%3C%2FP%3E%3CP%3E%2F*------------%20%E4%BF%9D%E5%AD%98%E4%B8%8A%E4%B8%8B%E6%96%87%E3%80%82-----------%20*%2F%3CBR%20%2F%3Emrs%20r3%E3%80%81control%3CBR%20%2F%3Emrs%20r0%E3%80%81psp%3CBR%20%2F%3Eisb%3C%2FP%3E%3CP%3Eadd%20r0%2C%20r0%2C%20%230x20%20%2F*%20%E5%B0%86%20r0%20%E7%A7%BB%E8%87%B3%E4%BF%9D%E5%AD%98%20s0%20%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82*%2F%3CBR%20%2F%3Etst%20lr%2C%20%230x10%3CBR%20%2F%3Eittt%20eq%3CBR%20%2F%3Evstmiaeq%20r1!%2C%20%7Bs16-s31%7D%2F*%20%E5%AD%98%E5%82%A8%20s16-s31%E3%80%82*%2F%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3Evldmiaeq%20r0%2C%20%7Bs0-s16%7D%2F*%20%E5%B0%86%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E7%9A%84%20FP%20%E4%B8%8A%E4%B8%8B%E6%96%87%E5%A4%8D%E5%88%B6%E5%88%B0%20s0-s16%E3%80%82*%2F%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3Evstmiaeq%20r1!%2F*%20%E5%AD%98%E5%82%A8%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E7%9A%84%20FP%20%E4%B8%8A%E4%B8%8B%E6%96%87%E3%80%82*%2F%3CBR%20%2F%3Esub%20r0%2C%20r0%2C%20%230x20%20%2F*%20%E5%B0%86%20r0%20%E8%AE%BE%E5%9B%9E%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E7%9A%84%E4%B8%8A%E4%B8%8B%E6%96%87%E4%BD%8D%E7%BD%AE%E3%80%82*%2F%3C%2FP%3E%3CP%3E%E5%AD%98%E5%82%A8%20R1%E3%80%81%7BR3-R11%E3%80%81LR%7D%E3%80%82%2F*%20%E5%AD%98%E5%82%A8%20CONTROL%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%81r4-r11%20%E5%92%8C%20LR%E3%80%82*%2F%3CBR%20%2F%3Eldmia%20r0%2C%20%7Br4-r11%7D%2F*%20%E5%B0%86%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E7%9A%84%E4%B8%8A%E4%B8%8B%E6%96%87%E5%A4%8D%E5%88%B6%E5%88%B0%20r4-r11%E3%80%82*%2F%3CBR%20%2F%3Estmia%20r1!%2C%20%7Br0%2C%20r4-r11%7D%2F*%20%E5%AD%98%E5%82%A8%E5%8E%9F%E5%A7%8B%20PSP%EF%BC%88%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E4%B8%8A%E4%B8%8B%E6%96%87%E5%90%8E%EF%BC%89%E5%92%8C%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E7%9A%84%E4%B8%8A%E4%B8%8B%E6%96%87%E3%80%82*%2F%3CBR%20%2F%3Estr%20r1%2C%20%5Br2%5D%20%2F*%20%E5%B0%86%E6%81%A2%E5%A4%8D%E4%B8%8A%E4%B8%8B%E6%96%87%E7%9A%84%E4%BD%8D%E7%BD%AE%E4%BF%9D%E5%AD%98%E4%B8%BA%20TCB%20%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%88%90%E5%91%98%E3%80%82*%2F%3C%2FP%3E%3CP%3E%2F*----------%20%E9%80%89%E6%8B%A9%E4%B8%8B%E4%B8%80%E9%A1%B9%E4%BB%BB%E5%8A%A1%E3%80%82---------*%2F%20%3CBR%20%2F%3E%20mov%20r0%EF%BC%8C%23configMAX_SYSCALL_INTERRUPT_PRIORITY%20%3CBR%20%2F%3E%20%23if%20(configenable_errata_837070_%E5%8F%98%E9%80%9A%E6%96%B9%E6%B3%95%20%3D%3D%201)%20cpsid%20i%20%2F*%20ARM%20Cortex-M7%20r0p1%20%E5%8B%98%E8%AF%AF%20837070%20%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3CBR%20%2F%3E*%2F%20%3CBR%20%2F%3E%20%23endif%20%3CBR%20%2F%3E%20msr%20basepri%EF%BC%8Cr0%20%3CBR%20%2F%3E%20dsb%20%3CBR%20%2F%3E%20isb%20%3CBR%20%2F%3E%20%23if%20(configenable_errata_837070_%E5%8F%98%E9%80%9A%E6%96%B9%E6%B3%95%20%3D%3D%201)%20cpsie%20i%20%2F*%20ARM%20Cortex-M7%20r0p1%20%E5%8B%98%E8%AF%AF%20837070%20%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3CBR%20%2F%3E*%2F%3CBR%20%2F%3E%23endif%3CBR%20%2F%3Ebl%20vTaskSwitchContext%3CBR%20%2F%3Emov%20r0%2C%20%230%3CBR%20%2F%3Emsr%20basepri%2C%20r0%3C%2FP%3E%3CP%3E%2F*------------%20MPU%20%E7%A8%8B%E5%BA%8F%E3%80%82------------%20*%2F%3CBR%20%2F%3Eldr%20r3%2C%20%3DpxCurrentTCB%3CBR%20%2F%3Eldr%20r2%2C%20%5Br3%5D%20%2F*%20r2%20%3D%20pxCurrentTCB%E3%80%82*%2F%3CBR%20%2F%3Eadd%20r2%2C%20r2%2C%20%234%20%2F*%20r2%20%3D%20TCB%20%E4%B8%AD%E7%9A%84%E7%AC%AC%E4%BA%8C%E9%A1%B9%EF%BC%8C%E5%8D%B3%20xMPUSettings%E3%80%82*%2F%3C%2FP%3E%3CP%3Edmb%20%2F*%20%E5%9C%A8%E7%A6%81%E7%94%A8%20MPU%20%E4%B9%8B%E5%89%8D%E5%AE%8C%E6%88%90%E6%9C%AA%E5%AE%8C%E6%88%90%E7%9A%84%E4%BC%A0%E8%BE%93%E3%80%82*%2F%3CBR%20%2F%3Eldr%20r0%2C%20%3D0xe000ed94%20%2F*%20MPU_CTRL%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82*%2F%3CBR%20%2F%3Eldr%20r3%2C%20%5Br0%5D%20%2F*%20%E8%AF%BB%E5%8F%96%20MPU_CTRL%20%E7%9A%84%E5%80%BC%E3%80%82*%2F%3CBR%20%2F%3Ebic%20r3%2C%20%231%20%2F*%20r3%20%3D%20r3%26amp%3B%20~1%20%E5%8D%B3%E6%B8%85%E9%99%A4%20r3%20%E4%B8%AD%E7%9A%84%200%20%E4%BD%8D%E3%80%82*%2F%3CBR%20%2F%3Estr%20r3%2C%20%5Br0%5D%20%2F*%20%E7%A6%81%E7%94%A8%20MPU%E3%80%82*%2F%3C%2FP%3E%3CP%3Eldr%20r0%2C%20%3D0xe000ed9c%20%2F*%20%E5%8C%BA%E5%9F%9F%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82*%2F%3CBR%20%2F%3Eldmia%20r2!%2C%20%7Br4-r11%7D%2F*%20%E8%AF%BB%E5%8F%96%204%20%E7%BB%84%20MPU%20%E5%AF%84%E5%AD%98%E5%99%A8%20%5BMPU%20Region%20%23%200%20-%203%5D%E3%80%82*%2F%3CBR%20%2F%3Estmia%20r0%2C%20%7Br4-r11%7D%2F*%20%E5%86%99%E5%85%A5%204%20%E7%BB%84%20MPU%20%E5%AF%84%E5%AD%98%E5%99%A8%20%5BMPU%20%E5%8C%BA%E5%9F%9F%20%23%200%20-%203%5D%E3%80%82*%2F%3C%2FP%3E%3CP%3E%23ifdef%20configTOTAL_MPU_REGIONS%3CBR%20%2F%3E%23if%20(%20configTOTAL_MPU_REGIONS%20%3D%3D%2016%20)%3CBR%20%2F%3Eldmia%20r2!%2C%20%7Br4-r11%7D%2F*%20%E8%AF%BB%E5%8F%96%204%20%E7%BB%84%20MPU%20%E5%AF%84%E5%AD%98%E5%99%A8%20%5BMPU%20Region%20%23%204%20-%207%5D%E3%80%82*%2F%3CBR%20%2F%3Estmia%20r0%2C%20%7Br4-r11%7D%2F*%20%E5%86%99%E5%85%A5%204%20%E7%BB%84%20MPU%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%5BMPU%20%E5%9C%B0%E5%8C%BA%20%23%204%20-%207%5D%E3%80%82*%2F%3CBR%20%2F%3Eldmia%20r2!%2C%20%7Br4-r11%7D%2F*%20%E8%AF%BB%E5%8F%96%204%20%E7%BB%84%20MPU%20%E5%AF%84%E5%AD%98%E5%99%A8%20%5BMPU%20%E5%8C%BA%E5%9F%9F%20%23%208%20-%2011%5D%E3%80%82*%2F%3CBR%20%2F%3Estmia%20r0%2C%20%7Br4-r11%7D%2F*%20%E5%86%99%E5%85%A5%204%20%E7%BB%84%20MPU%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%5BMPU%20%E5%8C%BA%E5%9F%9F%20%23%208%20-%2011%5D%E3%80%82*%2F%3CBR%20%2F%3E%23endif%20%2F*%20configTOTAL_MPU_REGIONS%20%3D%3D%2016%E3%80%82*%2F%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3Eldr%20r0%2C%20%3D0xe000ed94%20%2F*%20MPU_CTRL%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82*%2F%3CBR%20%2F%3Eldr%20r3%2C%20%5Br0%5D%20%2F*%20%E8%AF%BB%E5%8F%96%20MPU_CTRL%20%E7%9A%84%E5%80%BC%E3%80%82*%2F%3CBR%20%2F%3Eorr%20r3%2C%20%231%20%2F*%20r3%20%3D%20r3%20%7C%201%20%E5%8D%B3%E8%AE%BE%E7%BD%AE%20r3%20%E4%B8%AD%E7%9A%84%E7%AC%AC%200%20%E4%BD%8D%E3%80%82*%2F%3CBR%20%2F%3Estr%20r3%2C%20%5Br0%5D%20%2F*%20%E5%90%AF%E7%94%A8%20MPU%E3%80%82*%2F%3CBR%20%2F%3Edsb%20%2F*%20%E5%9C%A8%E7%BB%A7%E7%BB%AD%E4%B9%8B%E5%89%8D%E5%BC%BA%E5%88%B6%E5%86%99%E5%85%A5%E5%86%85%E5%AD%98%E3%80%82*%2F%3C%2FP%3E%3CP%3E%2F*----------%20%E6%81%A2%E5%A4%8D%E4%B8%8A%E4%B8%8B%E6%96%87%E3%80%82----------%20*%2F%3CBR%20%2F%3Eldr%20r3%2C%20%3DpxCurrentTCB%3CBR%20%2F%3Eldr%20r2%2C%20%5Br3%5D%20%2F*%20r2%20%3D%20pxCurrentTCB%E3%80%82*%2F%3CBR%20%2F%3Eldr%20r1%2C%20%5Br2%5D%20%2F*%20r1%20%3D%20TCB%20%E4%B8%AD%E4%BF%9D%E5%AD%98%E7%9A%84%E4%B8%8A%E4%B8%8B%E6%96%87%E4%BD%8D%E7%BD%AE%E3%80%82*%2F%3C%2FP%3E%3CP%3Eldmdb%20r1!%2C%20%7Br0%2C%20r4-r11%7D%2F*%20r0%20%E5%8C%85%E5%90%AB%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E4%B8%8A%E4%B8%8B%E6%96%87%E5%90%8E%E7%9A%84%20PSP%E3%80%82r4-r11%20%E5%8C%85%E5%90%AB%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E7%9A%84%E4%B8%8A%E4%B8%8B%E6%96%87%E3%80%82*%2F%3CBR%20%2F%3Emsr%20psp%2C%20r0%3CBR%20%2F%3Estmia%20r0!%2C%20%7Br4-r11%7D%2F*%20%E5%9C%A8%E4%BB%BB%E5%8A%A1%E6%A0%88%E4%B8%AD%E5%A4%8D%E5%88%B6%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E7%9A%84%E4%B8%8A%E4%B8%8B%E6%96%87%E3%80%82*%2F%3CBR%20%2F%3Eldmdb%20r1!%2C%20%7Br3-r11%2C%20lr%7D%2F*%20r3%20%E5%8C%85%E5%90%AB%20CONTROL%20%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82r4-r11%20%E5%92%8C%20LR%20%E6%81%A2%E5%A4%8D%E3%80%82*%2F%3CBR%20%2F%3Emsr%20control%2C%20r3%3C%2FP%3E%3CP%3Etst%20lr%2C%20%230x10%3CBR%20%2F%3Eittt%20eq%3CBR%20%2F%3Evldmdbeq%20r1!%2C%20%7Bs0-s16%7D%2F*%20s0-s16%20%E5%8C%85%E5%90%AB%E7%A1%AC%E4%BB%B6%E4%BF%9D%E5%AD%98%E7%9A%84%20FP%20%E4%B8%8A%E4%B8%8B%E6%96%87%E3%80%82*%2F%3CBR%20%2F%3Evstmiaeq%20r0!%2C%20%7Bs0-s16%7D%2F*%20%E5%A4%8D%E5%88%B6%E4%BB%BB%E5%8A%A1%E6%A0%88%E4%B8%AD%E4%BF%9D%E5%AD%98%E7%9A%84%E7%A1%AC%E4%BB%B6%20FP%20%E4%B8%8A%E4%B8%8B%E6%96%87%E3%80%82*%2F%3CBR%20%2F%3Evldmdbeq%20r1!%2C%20%7Bs16-s31%7D%2F*%20%E6%81%A2%E5%A4%8D%20s16-s31%E3%80%82*%2F%3C%2FP%3E%3CP%3Estr%20r1%2C%20%5Br2%5D%20%2F*%20%E5%B0%86%E4%B8%8B%E4%B8%80%E6%AC%A1%E4%BF%9D%E5%AD%98%E4%B8%8A%E4%B8%8B%E6%96%87%E7%9A%84%E4%BD%8D%E7%BD%AE%E4%BF%9D%E5%AD%98%E4%B8%BA%20TCB%20%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E6%88%90%E5%91%98%E3%80%82*%2F%3CBR%20%2F%3Ebx%20lr%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E4%B8%BA%E4%BB%80%E4%B9%88%E6%98%AF%3CFONT%20color%3D%22%23FF0000%22%3ES0%3C%2FFONT%3E~S16%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ES0~S15%20%E5%92%8C%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E5%B7%B2%E8%A2%AB%E7%A1%AC%E4%BB%B6%E6%8E%A8%E5%85%A5%E5%A0%86%E6%A0%88%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E8%BF%98%E8%A6%81%E5%86%8D%E5%A4%8D%E5%88%B6%E4%B8%80%E6%AC%A1%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%B8%8C%E6%9C%9B%E5%BE%97%E5%88%B0%E6%82%A8%E7%9A%84%E6%8C%87%E5%AF%BC%E5%92%8C%E5%BB%BA%E8%AE%AE%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2138321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Cortex%20M4F%20PendSV%20with%20FPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFreeRTOS-Kernel%2Fportable%2FIAR%2FARM_CM4F_MPU%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%E7%94%B1%20Amazon.com%20%E7%BB%B4%E6%8A%A4%E3%80%81Inc.%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%20GitHub%20%E4%BB%A3%E7%A0%81%E5%BA%93%E4%B8%AD%E6%8F%90%E4%BA%A4%E9%97%AE%E9%A2%98%E6%88%96%E6%8B%89%E5%8A%A8%E8%AF%B7%E6%B1%82%E3%80%82FreeRTOS%20%E5%9B%A2%E9%98%9F%E7%A7%AF%E6%9E%81%E7%9B%91%E6%B5%8B%E8%BF%99%E4%BA%9B%E9%A2%91%E9%81%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Cortex%20M4F%20PendSV%20with%20FPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137775%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22LijieDu_0-1753141549396.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22LijieDu_0-1753141549396.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348648i9625467BF90FF6EB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22LijieDu_0-1753141549396.png%22%20alt%3D%22LijieDu_0-1753141549396.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20davidtosenovjan%3C%2FP%3E%3CP%3E%E5%AE%83%E6%9D%A5%E8%87%AA%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreeRTOS%2FFreeRTOS-Kernel%2Ftree%2Fmain%2Fportable%2FIAR%2FARM_CM4F_MPU%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3AFreeRTOS-Kernel%2Fportable%2FIAR%2FARM_CM4F_MPU%20at%20main%20-%20FreeRTOS%2FFreeRTOS-Kernel%20-%20GitHub%3C%2FA%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%BE%97%E5%88%B0%E6%82%A8%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Cortex%20M4F%20PendSV%20with%20FPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22HwtZe%22%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E4%BB%A3%E7%A0%81%E4%B8%AD%E4%BC%BC%E4%B9%8E%E6%9C%89%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E8%AF%B4%E6%98%8E%E8%BF%99%E6%AE%B5%E4%BB%A3%E7%A0%81%E7%9A%84%E5%87%BA%E5%A4%84%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
