Clock FIRC & PLL settings
1,093 次查看
Dev15
Hi Team,
I'm using RTD 3.0.0, S32K312, SDK 3.5 version and trying to configure PWM channels. The core clock is set to FIRC and could see a warning.
Please help to resolve it.
Thank you
标记 (1)
1 回复
1,082 次查看
VaneB
Hi @Dev15
As you select FIRC as the clock source you need to disable the PLL as mentioned in the warning. the warning would not be a problem.
B.R.
VaneB
