Check WEL bit fail in Qspi_Ip_Example_S32K344
7,871 次查看
FelixQi
The version information of the example is as below:
* Autosar Version : 4.7.0
* Autosar Revision : ASR_REL_4_7_REV_0000
* Autosar Conf.Variant :
* SW Version : 3.0.0
* Build Version : S32K3_RTD_3_0_0_D2303_ASR_REL_4_7_REV_0000_20230331
The Serial Flash I use is W25Q16. I've attached the Datasheet as attachment.
I've configured the Mem LUT Operand in below table of ConfigTools:
Write Enable is 06h and Read Status Register-1 is 05h
FelixQi_1-1723536866860.pngFelixQi_1-1723536866860.pngFelixQi_2-1723536893974.pngFelixQi_2-1723536893974.pngFelixQi_3-1723536920511.pngFelixQi_3-1723536920511.png
But when I run the example, when run Qspi_Ip_EraseBlock() in main.c
it runs into Qspi_Ip_WriteEnable(),
After /* send WREN command */, when /* check WEL bit */, the WEL is expected to be 1, but it is read as 0. So the program runs into Mem_ExFls_ExampleAssert().
Is there any wrong configuration or do I miss some important configuration? Expect to your reply. Thanks!
标记 (1)
7,625 次查看
FelixQi
I've missed the READ instruction in the Read Status Register-1 sequence. The problem was solved already.
6 回复数
7,626 次查看
FelixQi
7,828 次查看
davidtosenovjan
What is your /WP pin connection?
7,807 次查看
FelixQi
Thank you for your reply!
The /WP(IO2) pin of Flash is connected to PTD12 of S32K344 currently.
7,796 次查看
davidtosenovjan
If so, do you drive this pin to logic 0?
7,750 次查看
FelixQi
I don't drive this pin to logic 0 in source code.
I've measured this pin by oscilloscope and it keeps logic 1 during the whole process.
I also tried not connecting this pin, but still meet the same problem.
Besides, I've tried another command "Read JEDEC ID". Below is the sequence in the Flash User Manual:
 After I send the read command, I could measure there is data output through DO.
But all data in ReadData keep as 0 after running below  API:
qspiStatus = Qspi_Ip_RunReadCommand(instance, 21, 0U, ReadData, NULL_PTR, 3U);//Read JEDEC ID
21 is the LUT index of ReadDeviceId:
/* 21: ReadDeviceId */
(Qspi_Ip_InstrOpType)((Qspi_Ip_InstrOpType)QSPI_IP_LUT_INSTR_CMD | (Qspi_Ip_InstrOpType)QSPI_IP_LUT_PADS_1 | (Qspi_Ip_InstrOpType)159U),
(Qspi_Ip_InstrOpType)(QSPI_IP_LUT_INSTR_STOP)
It seems that the Flash could response the command but the S32K344 could not read correctly.
I've not sure where the problem exists.
7,743 次查看
FelixQi
I've noticed that the value of register QUADSPI->RBDR[0] remains 0x00000000 all the time.
%3CLINGO-SUB%20id%3D%22lingo-sub-1930948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%A3%80%E6%9F%A5%20Qspi_Ip_Example_S32K344%20%E4%B8%AD%E7%9A%84%20WEL%20%E4%BD%8D%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1930948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A4%BA%E4%BE%8B%E7%9A%84%E7%89%88%E6%9C%AC%E4%BF%A1%E6%81%AF%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E*%20Autosar%E7%89%88%E6%9C%AC%EF%BC%9A4.7.0%3CBR%20%2F%3E*%20Autosar%20%E4%BF%AE%E8%AE%A2%E7%89%88%EF%BC%9AASR_REL_4_7_REV_0000%3CBR%20%2F%3E%20*%20Autosar%20Conf.Variant%EF%BC%9A%3CBR%20%2F%3E%20*%20%E8%BD%AF%E4%BB%B6%E7%89%88%E6%9C%AC%EF%BC%9A3.0.0%3CBR%20%2F%3E*%E6%9E%84%E5%BB%BA%E7%89%88%E6%9C%AC%EF%BC%9AS32K3_RTD_3_0_0_D2303_ASR_REL_4_7_REV_0000_20230331%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E4%B8%B2%E8%A1%8CFlash%E6%98%AFW25Q16%E3%80%82%E6%88%91%E5%B7%B2%E5%B0%86%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%BD%9C%E4%B8%BA%E9%99%84%E4%BB%B6%E9%99%84%E5%8A%A0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E4%B8%8B%E9%9D%A2%E7%9A%84%20ConfigTools%20%E8%A1%A8%E4%B8%AD%E9%85%8D%E7%BD%AE%E4%BA%86%20Mem%20LUT%20Operand%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%86%99%E5%85%A5%E4%BD%BF%E8%83%BD%E4%B8%BA%2006h%EF%BC%8C%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8-1%20%E4%B8%BA%2005h%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FelixQi_0-1723536821803.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FelixQi_0-1723536821803.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293118iB32FD5C6D471EF83%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22FelixQi_0-1723536821803.png%22%20alt%3D%22FelixQi_0-1723536821803.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFelixQi_0-1723536821803.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FelixQi_1-1723536866860.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FelixQi_1-1723536866860.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293119iB07C996A48C5C340%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22FelixQi_1-1723536866860.png%22%20alt%3D%22FelixQi_1-1723536866860.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFelixQi_1-1723536866860.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FelixQi_2-1723536893974.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FelixQi_2-1723536893974.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293120iE3103010A7E01720%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22FelixQi_2-1723536893974.png%22%20alt%3D%22FelixQi_2-1723536893974.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFelixQi_2-1723536893974.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FelixQi_3-1723536920511.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FelixQi_3-1723536920511.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293121i4BA05B78DD294076%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22FelixQi_3-1723536920511.png%22%20alt%3D%22FelixQi_3-1723536920511.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFelixQi_3-1723536920511.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E6%97%B6%EF%BC%8C%E5%9C%A8%20main.c%20%E4%B8%AD%E8%BF%90%E8%A1%8C%20Qspi_Ip_EraseBlock()%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FelixQi_4-1723537152600.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FelixQi_4-1723537152600.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293126i492891EE6B042199%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22FelixQi_4-1723537152600.png%22%20alt%3D%22FelixQi_4-1723537152600.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFelixQi_4-1723537152600.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E8%BF%90%E8%A1%8C%E5%88%B0%20Qspi_Ip_WriteEnable()%EF%BC%8C%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FelixQi_5-1723537253658.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FelixQi_5-1723537253658.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293127iA22943FCFF52950F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22FelixQi_5-1723537253658.png%22%20alt%3D%22FelixQi_5-1723537253658.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFelixQi_5-1723537253658.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2F*%E5%8F%91%E9%80%81WREN%E5%91%BD%E4%BB%A4*%2F%E4%B9%8B%E5%90%8E%EF%BC%8C%E5%BD%93%2F*%E6%A3%80%E6%9F%A5WEL%E4%BD%8D*%2F%E6%97%B6%EF%BC%8CWEL%E9%A2%84%E6%9C%9F%E4%B8%BA1%EF%BC%8C%E4%BD%86%E8%AF%BB%E5%88%B0%E7%9A%84%E5%8D%B4%E6%98%AF0%EF%BC%8C%E5%9B%A0%E6%AD%A4%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%E5%88%B0Mem_ExFls_ExampleAssert()%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E4%BB%BB%E4%BD%95%E9%94%99%E8%AF%AF%E7%9A%84%E9%85%8D%E7%BD%AE%E6%88%96%E8%80%85%E6%88%91%E6%98%AF%E5%90%A6%E9%94%99%E8%BF%87%E4%BA%86%E4%B8%80%E4%BA%9B%E9%87%8D%E8%A6%81%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%9F%E6%9C%9F%E5%BE%85%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1936813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%A3%80%E6%9F%A5%20Qspi_Ip_Example_S32K344%20%E4%B8%AD%E7%9A%84%20WEL%20%E4%BD%8D%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1936813%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%BC%8F%E6%8E%89%E4%BA%86%3CSPAN%3E%E8%AF%BB%E5%8F%96%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8-1%E5%BA%8F%E5%88%97%E4%B8%AD%E7%9A%84READ%E6%8C%87%E4%BB%A4%E3%80%82%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1933405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%A3%80%E6%9F%A5%20Qspi_Ip_Example_S32K344%20%E4%B8%AD%E7%9A%84%20WEL%20%E4%BD%8D%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1933405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%E5%AF%84%E5%AD%98%E5%99%A8%20QUADSPI-%26gt%3BRBDR%5B0%5D%20%E7%9A%84%E5%80%BC%E5%A7%8B%E7%BB%88%E4%BF%9D%E6%8C%81%E4%B8%BA%200x00000000%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1933334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%A3%80%E6%9F%A5%20Qspi_Ip_Example_S32K344%20%E4%B8%AD%E7%9A%84%20WEL%20%E4%BD%8D%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1933334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B9%B6%E6%B2%A1%E6%9C%89%E5%9C%A8%E6%BA%90%E4%BB%A3%E7%A0%81%E4%B8%AD%E5%B0%86%E8%AF%A5%E5%BC%95%E8%84%9A%E9%A9%B1%E5%8A%A8%E4%B8%BA%E9%80%BB%E8%BE%91%200%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E9%80%9A%E8%BF%87%E7%A4%BA%E6%B3%A2%E5%99%A8%E6%B5%8B%E9%87%8F%E4%BA%86%E8%BF%99%E4%B8%AA%E5%BC%95%E8%84%9A%EF%BC%8C%E5%AE%83%E5%9C%A8%E6%95%B4%E4%B8%AA%E8%BF%87%E7%A8%8B%E4%B8%AD%E4%BF%9D%E6%8C%81%E9%80%BB%E8%BE%91%201%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E5%B0%9D%E8%AF%95%E8%BF%87%E4%B8%8D%E8%BF%9E%E6%8E%A5%E8%BF%99%E4%B8%AA%E5%BC%95%E8%84%9A%EF%BC%8C%E4%BD%86%E4%BB%8D%E7%84%B6%E9%81%87%E5%88%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%88%91%E8%BF%98%E5%B0%9D%E8%AF%95%E4%BA%86%E5%8F%A6%E4%B8%80%E4%B8%AA%E5%91%BD%E4%BB%A4%E2%80%9C%E8%AF%BB%E5%8F%96%20JEDEC%20ID%E2%80%9D%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%20Flash%20%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E5%BA%8F%E5%88%97%EF%BC%9A%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sequence%20of%20Read%20JEDEC%20ID.PNG%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sequence%20of%20Read%20JEDEC%20ID.PNG%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293529i8E04F2CF9A8FAF26%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sequence%20of%20Read%20JEDEC%20ID.PNG%22%20alt%3D%22Sequence%20of%20Read%20JEDEC%20ID.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESequence%20of%20Read%20JEDEC%20ID.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8F%91%E9%80%81%E8%AF%BB%E5%8F%96%E5%91%BD%E4%BB%A4%E5%90%8E%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%B5%8B%E9%87%8F%E9%80%9A%E8%BF%87DO%E6%9C%89%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E8%BF%90%E8%A1%8C%E4%BB%A5%E4%B8%8B%20API%20%E5%90%8E%EF%BC%8CReadData%20%E4%B8%AD%E7%9A%84%E6%89%80%E6%9C%89%E6%95%B0%E6%8D%AE%E9%83%BD%E4%BF%9D%E6%8C%81%E4%B8%BA%200%EF%BC%9A%3C%2FP%3E%3CP%3EqspiStatus%20%3D%20Qspi_Ip_RunReadCommand(instance%2C%2021%2C%200U%2C%20ReadData%2C%20NULL_PTR%2C%203U)%3B%2F%2F%E8%AF%BB%E5%8F%96JEDEC%20ID%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CP%3E21%20%E6%98%AF%20ReadDeviceId%20%E7%9A%84%20LUT%20%E7%B4%A2%E5%BC%95%EF%BC%9A%3C%2FP%3E%3CP%3E%2F*%2021%3A%20%E8%AF%BB%E5%8F%96%E8%AE%BE%E5%A4%87ID%20*%2F%3CBR%20%2F%3E%20%EF%BC%88Qspi_Ip_InstrOpType%EF%BC%89%EF%BC%88%EF%BC%88Qspi_Ip_InstrOpType%EF%BC%89QSPI_IP_LUT_INSTR_CMD%20%7C%20%EF%BC%88Qspi_Ip_InstrOpType%EF%BC%89QSPI_IP_LUT_PADS_1%20%7C%20%EF%BC%88Qspi_Ip_InstrOpType%EF%BC%89159U%EF%BC%89%EF%BC%8C%3CBR%20%2F%3E%20%EF%BC%88Qspi_Ip_InstrOpType%EF%BC%89%EF%BC%88QSPI_IP_LUT_INSTR_STOP%EF%BC%89%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%20Flash%20%E5%8F%AF%E4%BB%A5%E5%93%8D%E5%BA%94%E5%91%BD%E4%BB%A4%EF%BC%8C%E4%BD%86%20S32K344%20%E6%97%A0%E6%B3%95%E6%AD%A3%E7%A1%AE%E8%AF%BB%E5%8F%96%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1932877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%A3%80%E6%9F%A5%20Qspi_Ip_Example_S32K344%20%E4%B8%AD%E7%9A%84%20WEL%20%E4%BD%8D%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1932877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E7%9A%84%E8%AF%9D%EF%BC%8C%E6%82%A8%E6%98%AF%E5%90%A6%E5%B0%86%E8%AF%A5%E5%BC%95%E8%84%9A%E9%A9%B1%E5%8A%A8%E4%B8%BA%E9%80%BB%E8%BE%91%200%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1932561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%A3%80%E6%9F%A5%20Qspi_Ip_Example_S32K344%20%E4%B8%AD%E7%9A%84%20WEL%20%E4%BD%8D%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1932561%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%81%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FelixQi_0-1723684800815.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FelixQi_0-1723684800815.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293372i9E4CA7FEED0FB89A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22FelixQi_0-1723684800815.png%22%20alt%3D%22FelixQi_0-1723684800815.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFelixQi_0-1723684800815.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22FelixQi_1-1723684880713.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22FelixQi_1-1723684880713.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293373iA9E84337A27BAB92%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22FelixQi_1-1723684880713.png%22%20alt%3D%22FelixQi_1-1723684880713.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EFelixQi_1-1723684880713.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EFlash%E7%9A%84%2FWP(IO2)%E5%BC%95%E8%84%9A%E7%9B%AE%E5%89%8D%E8%BF%9E%E6%8E%A5%E5%88%B0S32K344%E7%9A%84PTD12%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1932061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%A3%80%E6%9F%A5%20Qspi_Ip_Example_S32K344%20%E4%B8%AD%E7%9A%84%20WEL%20%E4%BD%8D%E5%A4%B1%E8%B4%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1932061%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E7%9A%84%20%2FWP%20%E5%BC%95%E8%84%9A%E8%BF%9E%E6%8E%A5%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22davidtosenovjan_0-1723642866094.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22davidtosenovjan_0-1723642866094.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F293315i4096B307FC07F38F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22davidtosenovjan_0-1723642866094.png%22%20alt%3D%22davidtosenovjan_0-1723642866094.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edavidtosenovjan_0-1723642866094.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
