Center Aligned PWM
Center Aligned PWM
Canberk
I tried to generate center aligned PWM for BLDC motor application. I applied the steps that in the 3-phase Sensorless PMSM Motor Control Kit with S32K344 using RTD Low Level API Application Note's center aligned PWM title. But PWM that I created still edge aligned. Probably there are some key parts that I need to know. How can I generate center aligned PWM.
