Can not flash s32K144
1,460件の閲覧回数
cuongtran
I tried to flash the s32K144 device using S32 DS and I got the above error.  Can you help me out on this?.
Thanks.
3 返答(返信)
1,368件の閲覧回数
jorge_a_vazquez
Hi Cuong Tran
You forgot to attach the image of the error code that you have.
Jorge Alcala
1,368件の閲覧回数
cuongtran
Here is the error.
Thanks.
Cuong Tran, P. Eng.
Senior Software Engineer
Mechatronics
CLOSURES TECHNICAL CENTRE
521 Newpark Blvd., P.O. Box 354 Stn. Main
Newmarket, Ontario L3Y 4X7 Canada
OFFICE: +1 905-898-6744 x2187
e-mail:cuong.tran@magna.com
1,368件の閲覧回数
jorge_a_vazquez
Hi Cuong Tran
Did you create the launch configuration? or it is a project imported from other environment?
Please verify that you have the following configuration in your configuration:
Jorge Alcala
