Can Standby RAM retain data after a reset?
ソリューションへジャンプ
3,161件の閲覧回数
Pusoy
Standby RAM is a memory area separated from SRAM, and according to the reference manual, SRAM will lose data after a reset. However, standby RAM is not initialized in the startup_cm7.s .
1. Can Standby RAM retain data after a destructive reset?
タグ(3)
3,149件の閲覧回数
Senlent
Hi@Pusoy
the SRAM contents is invalid after Destructive reset.
3 返答(返信)
2,969件の閲覧回数
JonAnder_Amante
Thank you for all but I have a big problem when I try to debug my projects. The problem is that when I debug the project, it should start uin the memory flash but the project starts in the sram and I don´t know what is the problem. Could you help me because I am very worried.
Thank you for all
3,150件の閲覧回数
Senlent
Hi@Pusoy
2,968件の閲覧回数
JonAnder_Amante
Thank you for all
