Can Raspberry Pi communicate with MCSPTE1AK144 kit?
920件の閲覧回数
aaronli-uga
I have purchased several MCSPTE1AK144 kits constructing a motor network. And I want to use the Raspberry Pi as a control center to control all the motor's behavior. Is this doable? If so, could anyone give me some help?
901件の閲覧回数
lukaszadrapa
I can see no problem with this. I saw that Raspberry Pi has interfaces like SPI or I2C, so you can quite easily connect these boards. Then it just depends on your application.
Lukas
