CSEC_DRV_MPCompress Usage ??
english0815
Is there an example to use Miyaguchi-Prenell compression feature ? I have not idea how to use API to initialized, compression and uninitiated in S32SDK_S32K1XX_RTM_4.0.2 SDK?
lukaszadrapa
this command is used in SDK examples. You can take a look at:
c:\NXP\S32DS.3.4\S32DS\software\S32SDK_S32K1XX_RTM_4.0.2\examples\S32K144\driver_examples\system\csec_keyconfig\
It's used in function deriveKey() in file:
c:\NXP\S32DS.3.4\S32DS\software\S32SDK_S32K1XX_RTM_4.0.2\examples\S32K144\driver_examples\system\csec_keyconfig\src\csec_utils.c
Lukas
