CAN common mode bus voltage
Shruthi_C
HI
Can I please get the information about maximum allowed common mode bus voltage of CAN in S32K146
Thanks & Regards,
Shruthi C
lukaszadrapa
Hi @Shruthi_C
this question is not related to S32K1 microcontroller but rather to external CAN transceiver. S32K1 does not have in-built CAN transceiver, there's only CAN module with TX and RX pins. Please check documentation of your transceiver for details about the common mode voltage.
Lukas
Shruthi_C
HI Lukas,
Thanks for the support
Shruthi C
