CAN PE uses peripheral clock
10,721件の閲覧回数
chai_997128
1. The CAN PE clock uses a peripheral clock of 60M, and CAN can communicate normally without frequency division
2. When using 12 division frequency and the clock size is 5M, communication cannot be normal.
3. Unable to run correctly when using CAN PE clock and peripheral clock 60M, propagation segment 5, synchronization segment 1 is 3, and synchronization segment 2 is 1
4. When using CAN PE clock and peripheral clock 60M, the transmission segment is 7, synchronization segment 1 is 4, and synchronization segment 2 is 1, it can operate correctly
What is the reason for this? I would like to know how to communicate normally with a 12 division frequency and a clock size of 5M
25 返答(返信)
1,724件の閲覧回数
chai_997128
CTRL->CLKSRC is set to 1.
Are you using s32kF146?
1,876件の閲覧回数
Senlent
Hi@chai_997128
I didn't find any problem with this configuration, if there is any problem please let me know, I will take some time to test this code
1,730件の閲覧回数
chai_997128
hi @Senlent May I ask if there are any results?
1,844件の閲覧回数
chai_997128
Under this configuration, CAN cannot operate normally,please help check.thanks!
1,945件の閲覧回数
chai_997128
s32kf146
