CAN BusOff recovery indication issue
Shivanee
We are using the NXP S32K148 MCU with RTD version 1.0.1, and the CAN driver is configured using the S32 Design Studio (S2DS) configurator tool.
AutoRecovery Bus-Off is disabled (BOFFREC = 1).
When errors are intentionally introduced on the CAN bus to force the ECU into Bus-Off state, the CAN driver triggers Bus-Off interrupts.
The Bus-Off interrupt is observed only four times, even though the bus remains in Bus-Off state.
For each of these four interrupts, the driver reports Bus-Off indication to the upper layers, and recovery is attempted from the upper layer.
It is not expected for the CAN driver to perform recovery because the Bus-Off condition is intentional for testing purposes.
Expected Behavior
The Bus-Off interrupt should continue to trigger as long as the ECU remains in Bus-Off state, until the ECU transitions to sleep mode.
In Bus-Off state, Tx/Rx messages are disabled, which will cause the CAN Network Management (CanNM) timeout to expire and initiate the sleep sequence.
Therefore, until the ECU enters sleep mode, the Bus-Off condition will persist on the bus, and the Bus-Off interrupt should keep triggering.
Questions for NXP
Why does the CAN driver trigger the Bus-Off interrupt only four times while the ECU remains in Bus-Off state?
Is any additional handling required at the application level to maintain expected behavior?
Are there any considerations or best practices for manual Bus-Off recovery without polling, especially when AutoRecovery is disabled?
Julián_AragónM
Hi @Shivanee,
I've replied to your internal support ticket.
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2249558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECAN%20BusOff%20recovery%20indication%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EWe%20are%20using%20the%20NXP%20S32K148%20MCU%20with%20RTD%20version%201.0.1%2C%20and%20the%20CAN%20driver%20is%20configured%20using%20the%20S32%20Design%20Studio%20(S2DS)%20configurator%20tool.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EAutoRecovery%20Bus-Off%20is%20disabled%20(BOFFREC%20%3D%201).%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EWhen%20errors%20are%20intentionally%20introduced%20on%20the%20CAN%20bus%20to%20force%20the%20ECU%20into%20Bus-Off%20state%2C%20the%20CAN%20driver%20triggers%20Bus-Off%20interrupts.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EThe%20Bus-Off%20interrupt%20is%20observed%20only%20four%20times%2C%20even%20though%20the%20bus%20remains%20in%20Bus-Off%20state.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EFor%20each%20of%20these%20four%20interrupts%2C%20the%20driver%20reports%20Bus-Off%20indication%20to%20the%20upper%20layers%2C%20and%20recovery%20is%20attempted%20from%20the%20upper%20layer.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EIt%20is%20not%20expected%20for%20the%20CAN%20driver%20to%20perform%20recovery%20because%20the%20Bus-Off%20condition%20is%20intentional%20for%20testing%20purposes.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EExpected%20Behavior%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EThe%20Bus-Off%20interrupt%20should%20continue%20to%20trigger%20as%20long%20as%20the%20ECU%20remains%20in%20Bus-Off%20state%2C%20until%20the%20ECU%20transitions%20to%20sleep%20mode.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EIn%20Bus-Off%20state%2C%20Tx%2FRx%20messages%20are%20disabled%2C%20which%20will%20cause%20the%20CAN%20Network%20Management%20(CanNM)%20timeout%20to%20expire%20and%20initiate%20the%20sleep%20sequence.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3ETherefore%2C%20until%20the%20ECU%20enters%20sleep%20mode%2C%20the%20Bus-Off%20condition%20will%20persist%20on%20the%20bus%2C%20and%20the%20Bus-Off%20interrupt%20should%20keep%20triggering.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EQuestions%20for%20NXP%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EWhy%20does%20the%20CAN%20driver%20trigger%20the%20Bus-Off%20interrupt%20only%20four%20times%20while%20the%20ECU%20remains%20in%20Bus-Off%20state%3F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EIs%20any%20additional%20handling%20required%20at%20the%20application%20level%20to%20maintain%20expected%20behavior%3F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EAre%20there%20any%20considerations%20or%20best%20practices%20for%20manual%20Bus-Off%20recovery%20without%20polling%2C%20especially%20when%20AutoRecovery%20is%20disabled%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20CAN%20BusOff%20recovery%20indication%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250598%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F219991%22%20target%3D%22_blank%22%3E%40Shivanee%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI've%20replied%20to%20your%20internal%20support%20ticket.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E
