C40 Code Memory Allocation – Hard Fault When Changing Sector
1,282件の閲覧回数
GaneshBhagwat
I’m working with the C40 flash memory driver and used the following configuration, which works fine with the default project settings:
#define EXAMPLE_MASTER_ID         (0U)
#define EXAMPLE_SECTOR_START_ADDR (0x00600000U)
#define EXAMPLE_SECTOR_TEST       (C40_CODE_ARRAY_0_BLOCK_1_S256)
#define EXAMPLE_BUFFER_SIZE       (64U) // or 128U
However, when I change the settings to:
#define EXAMPLE_SECTOR_START_ADDR (0x00500000U)
#define EXAMPLE_SECTOR_TEST       (C40_CODE_ARRAY_0_BLOCK_0_S128)
the program hits a hard fault.
Could anyone clarify what might cause this issue?
From my understanding, possible causes could be:
  • The selected start address overlaps with a protected or reserved flash region.
  • The sector/block size definition (C40_CODE_ARRAY_0_BLOCK_0_S128) doesn’t match the actual memory map for the device.
  • Attempting to write or erase from a block where the code is currently executing.
  • Misalignment with the flash controller’s sector boundaries.
I’ve attached an image showing the issue in more detail.
Thanks and Regards,
Ganesh Bhagwat
1,263件の閲覧回数
Senlent
Hi@GaneshBhagwat
This should be an Read-While-Write Event Error(RWE), you need to put flash operation into SRAM to avoid RWE.
Please refer to this post:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K312-C40-Ip-SRAM-RTD-500-DS35/ta-p/2074245
%3CLINGO-SUB%20id%3D%22lingo-sub-2151017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EC40%20%E3%82%B3%E3%83%BC%E3%83%89%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%20%E2%80%93%20%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E5%A4%89%E6%9B%B4%E6%99%82%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20C40%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E6%AC%A1%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%23define%20EXAMPLE_MASTER_ID%20%20%20%20%20%20%20%20%20(0U)%0A%23define%20EXAMPLE_SECTOR_START_ADDR%20(0x00600000U)%0A%23define%20EXAMPLE_SECTOR_TEST%20%20%20%20%20%20%20(C40_CODE_ARRAY_0_BLOCK_1_S256)%0A%23define%20EXAMPLE_BUFFER_SIZE%20%20%20%20%20%20%20(64U)%20%2F%2F%20or%20128U%3C%2FPRE%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E8%A8%AD%E5%AE%9A%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%23define%20EXAMPLE_MASTER_ID%20%20%20%20%20%20%20%20%20(0U)%0A%23define%20EXAMPLE_SECTOR_START_ADDR%20(0x00500000U)%0A%23define%20EXAMPLE_SECTOR_TEST%20%20%20%20%20%20%20(C40_CODE_ARRAY_0_BLOCK_0_S128)%0A%23define%20EXAMPLE_BUFFER_SIZE%20%20%20%20%20%20%20(64U)%20%2F%2F%20or%20128U%3C%2FPRE%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AB%3CSTRONG%3E%E9%87%8D%E5%A4%A7%E3%81%AA%E9%9A%9C%E5%AE%B3%3C%2FSTRONG%3E%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%AF%E4%BD%95%E3%81%AA%E3%81%AE%E3%81%8B%E3%80%81%E3%81%A0%E3%82%8C%E3%81%8B%E6%98%8E%E7%A2%BA%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%E3%80%81CAN%E5%8E%9F%E5%9B%A0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E9%96%8B%E5%A7%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%E3%80%81%E4%BF%9D%E8%AD%B7%E3%81%BE%E3%81%9F%E3%81%AF%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E9%A0%98%E5%9F%9F%E3%81%A8%E9%87%8D%E8%A4%87%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%2F%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AE%E5%AE%9A%E7%BE%A9%20(C40_CODE_ARRAY_0_BLOCK_0_S128)%20%E3%81%8C%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9E%E3%83%83%E3%83%97%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E7%8F%BE%E5%9C%A8%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%9F%E3%81%AF%E6%B6%88%E5%8E%BB%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E5%A2%83%E7%95%8C%E3%81%A8%E3%81%AE%E4%B8%8D%E6%95%B4%E5%90%88%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%82%92%E3%82%88%E3%82%8A%E8%A9%B3%E7%B4%B0%E3%81%AB%E7%A4%BA%E3%81%99%E7%94%BB%E5%83%8F%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AC%E3%83%8D%E3%83%BC%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%90%E3%82%B0%E3%83%AF%E3%83%83%E3%83%88%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20C40%20Code%20Memory%20Allocation%20%E2%80%93%20Hard%20Fault%20When%20Changing%20Sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CSPAN%3E%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244803%22%3E%40GaneshBhagwat%3C%2Fa%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%20Read-While-Write%20%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%20%E3%82%A8%E3%83%A9%E3%83%BC%20(RWE)%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81RWE%20%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%93%8D%E4%BD%9C%E3%82%92%20SRAM%20%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%A1%E3%82%89%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K312-C40-Ip-SRAM-RTD-500-DS35%2Fta-p%2F2074245%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
