Bus Fault A precise synchronous data access error has occurred.
ShrikantM
* Project : RTD AUTOSAR 4.4
* Platform : CORTEXM
* Peripheral : C40_IP IPV_QSPI
* Dependencies : none
* Autosar Version : 4.4.0
* Autosar Revision : ASR_REL_4_4_REV_0000
* Autosar Conf.Variant :
* SW Version : 2.0.1
* Build Version : S32K3_RTD_2_0_1_D2207_ASR_REL_4_4_REV_0000_20220707
What could be the reason of Bus Fault: A precise (synchronous) data access error has occurred.?
To recover the ECU , we need to do the erase the ECU and flash the hex again.
How to solve this issue?
Senlent
Hi@ShrikantM
Please try to read the MCRS register to check which problem could be.
Spoiler
