Building error
Building error
mgomez
I have this errors: Does anybody know what each of them is?
1) #error "Software Version Numbers of Flexio_Uart_Ip_Defines.h and Flexio_Uart_Ip_Types.h are different"
2) #error "Software Version Numbers of Flexio_Uart_Ip_VS_0_PBcfg.h and Flexio_Uart_Ip_Types.h are different"
3) fatal error: CDD_Bms_common.h: No such file or directory
4) fatal error: Siul2_Port_Ip_Cfg.h: No such file or directory
5) make: *** [generate/src/subdir.mk:194: generate/src/Flexio_Uart_Ip_VS_0_PBcfg.o] Error 1
6) make: *** [src/subdir.mk:29: src/Bjb.o] Error 1
7) make: *** [src/subdir.mk:29: src/Cmu.o] Error 1
make: *** [src/subdir.mk:29: src/Common.o] Error 1
9) make: *** [src/subdir.mk:29: src/main.o] Error 1
10) request for member 'PhyTD' in something not a structure or union
11) unknown type name 'Bms_TDType'
thank you!
TomasVaverka
Hello Maitane,
Please let us know if the answer here helps to fix these errors.
Tomas
