Bootloader for s32k144
ソリューションへジャンプ
3,471件の閲覧回数
AnwarSheik
 I am noobie trying to write a bootloader for s32k144 using can communication.
I successfully relocated the vector table from 0x00000000 to 0x00008000 of the application code
The problem is i dont know how to write the bootloader code without erasing the application code
i am using s32kds for arm ide, when ever i tried to flash the bootloader code it is erasing the entire flash including my application code placed at 0x00008000.
i want to place the bootloader 0x00000000 and application at 0x00008000 please  guide me how to do this
@JozefKozon @jann_ @guoweisun @TomasVaverka
タグ(1)
3,461件の閲覧回数
lukaszadrapa
Hi Anwar,
if you need to keep some memory content during the programming by S32DS, there's a nice article from Erich Styger:
https://mcuoneclipse.com/2014/07/13/preserving-memory-ranges-with-eclipse-and-pe-gdb-server/
In short, you need to go to Debug Configurations, here select PEmicro Debugger tab and then click on Advanced Options. In that window you can set Preserve areas.
Lukas
2 返答(返信)
3,462件の閲覧回数
lukaszadrapa
Hi Anwar,
Lukas
3,435件の閲覧回数
AnwarSheik
Thanks @lukaszadrapa
the above solution is working
