BLDC door control
BLDC door control
1,672 次查看
erikraynolds
Is there available NXP reference design for ASILBSYSTM ASIL B System Solution For BDC Motor | NXP Semiconductors with use of BLDC motor for automotive application for door control module SW & HW?
标记 (1)
1,653 次查看
jane3144fitzgibbon
It's great to see interest in leveraging NXP's ASIL B system solution for a BLDC motor in automotive door control applications! While the reference design for the ASILBSYSTM solution is comprehensive, incorporating both hardware and software aspects, I’d Aquí recommend checking if it includes specific examples tailored to door control modules. This would ensure a faster and more seamless integration process. NXP's expertise in safety-critical systems and BLDC motor control should make this solution highly reliable for automotive standards. It would be fascinating to explore how adaptable the reference design is for other automotive applications beyond door control—such as power steering or window regulators—using the same base.
1,656 次查看
_Leo_
Thank you so much for your interest in our products and for using our community.
We have various Automotive Motor Control Solutions, which are implemented with MCUs that support individually ASIL B/D level (depending on the MCU).
Hope it helps you.
Have a nice day!
