BLDC Motor Control by Single phase
sarwath
Hello Community,
Is it possible to rotate the 3 phase bldc motor with any one phase(a/b/c).
I want to control the 3 phase bldc motor with any one phase by duty cycle.
Could anyone please help me on this.
Thanks in advance,
Sarwath
Tags (2)
sarwath
Thanks for your response @petervlna .
I will convey the same to my team.
BR,
Sarwath
petervlna
I had consulted your query with motor control expert.
If we understood you requirement correctly, then we do not have any experience here.
BLDC is commonly controlled by 2 active and 1 disconnected phase.
If only 1 phase will be active, that will create a big issues which we are not able to answer/identify.
Peter
